Question about Samsung Televison & Video
HLR5667W DLP replacemnt bulb won't fit. I bought the right replacement which is a BP96-00826A and the replacement has a metal backing that is round. When I pulled out the original bulb housing, its flat. When trying to slide he replacement into the television, the metal (backend) of the housing wouldnt slide through.. any ideas??
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
Look at the old lamp it has a part # tag on it.
The correct part # is BP96-01073A
with the flat side without the metal bulge
There are two versions of your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Nov 15, 2009
Samsung hl-r5667w DLP no picture,
Hello, are there any sounds coming from your television? If something happened to the colorwheel I dont think the TV would come on at all, I would by instinct take a look at replacing the DMD chip.
Jan 01, 2014 | Samsung HLR5667W 56" Rear Projection HDTV
My Samsung DLP HLR5667W went blank. Just before it went out, I was unable to control volume/mute. I replaced the lamp ($175 a Walt's ripoff shop) and the TV worked for four hours then died again
I would guess that it could be the main board going bad. Check all our connections and wiring. You should call places like Tri-State Module and they can probably send you a part or repair for way less than 500 bucks.
Mar 31, 2013 | Samsung HLR5667W 56" Rear Projection HDTV
Shadow appeared on my DLP TV after replacing the lamp
this is a light tunnel failure this component will have to be replaced and is a part of the light engine
Feb 14, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
I have a Samsung HLR5667W DlP. The TV was taking longer to warm up until one day I heard a screeching sound and the tv went black. When I turned it on again it made a whining/crunching sound with no...
this is the colourwheel there are video clips on YOU TUBE type in replace color wheel will show how to replace dont know how much they cost to buy
Nov 08, 2009 | Samsung Televison & Video
My Samsung HLR5667W DLP won't come on. Lamp lite blinking
Feel better now?
Tried a new lamp or is it now very old and damaged the main board?
Sep 20, 2017 | Samsung HLR5667W 56" Rear Projection HDTV
I can't seeem to find out how to put the new lamp back into the t.v
if this is either of the 51" or 56" DLP tv's, it is very simple.
-Make sure tv is UNPLUGGED!
-Open the side compartment on left side of tv as you are facing it from the front.
-Take off the door and you will see the lamp housing.There are 2 screws facing you.Unscrew these and set the screws aside.
-Now pull on the housing a little and it should slide out.You may need to wiggle it a little.
-Set housing down on table or somewhere with good light.Make sure not to touch bulb of either the old lamp or new as oils from fingers can distort picture.
-Now,undo screws on shiny metal piece.There are 2.Take off metal housing piece.
-You now see the back of the bulb.If you look at the lamp from the front,you will notice where the 2 wires are fitted into a bracket with 2 screws.
-Unscrew those screws to loosen the bracket.The replacement lamp should have the exact same bracket.If not you can just undo the wires to the old lamp and connect the same wire harness to the new one.
-once the wire bracket is unscrewed, pull it out of its fitting and then unscrew the 4 screws holding the lamp in.
-Take notice of how the shiny metal clamp-fitting is situated to hold the lamp in place so you can put it back on the right way.
-Once loosened, the bulb should be able to come out and you can put the new one right in it's place. Make sure to keep the top wire connector on the bulb at about 11 o'clock and that a nub on the bulb fits through a spacer on the shiny metal clamp-fitting.
-Now tighten the 4 screws on the clamp-fitting and make sure the wire screw connectors on bulb are tight as well.
-Take the now loose rubber-covered wires and tighten them into the bracket-fitting the way the old ones were,with plugs and lamp facing the same way.
-With everything now tight,put metal housing back on and tighten the 2 screws down.
-Take the whole unit and slowly slide it back into the tv making sure that the plugs slide into their rightful place.This should be easy,but may require a wiggle or two.
-Now screw in the 2 screws you have left into the plastice mounting piece. Re-attach the door and plug the tv in.Wait a few minutes and then turn on tv.
-It should work.If not, unplug tv and check all connections.
TIP:Do not put a cold bulb in and then turn on immediately.I like to let the bulb sit in the tv with it plugged in for a while until the bulb is warmed and ready.
Good Luck! -Chris
Mar 10, 2009 | Vivitek V37835 46 in. LCD Television
Changing lamp on lg dlp
On my unit there's a panel on the lower right hand side, remove the 2 screws with a screw driver. Inside you should see a compartment that is metal and has a thin metal handle. Remove the Black screw on the top left hand side. Then pull the unit out with the handle. Inside the unit holds the bulb, just replace and go through these steps in reverse to place back together.
Aug 11, 2008 | LG RU-52SZ51D 52" Rear Projection...
Samsung HLR5667W lamp replace
I have the exact same issue that ididitmyself described above. I have a vertical gray line shadow that is hindering the quality of the image for a few weeks. My TV's model number is HLR5667. It has been 25 months since I bought it. Any help resolving this would be greatly appreciated. I hope that Samsung representatives read these posts and take corrective action to their products and assist us in guiding us to resolve this issue. This is negatively reflecting on their image in the eyes of consumers.
Jan 04, 2008 | Samsung HLR5667W 56" Rear Projection HDTV
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
