Question about Acer Extensa 5420-5687 Notebook
The display on my acer extensa 5420-5687 will go black from time to time. All i have to do is close the cover and open it up and the display will be back on again. I may have to do this several times before it stays on. Is my inverter board bad, or is it my lcd?
  • 458 Answers
Most likely the Power Inveter... though both the power inverter and a failing LCD bulb will produce the same symptoms... Usually when the LCD Bulb starts to go, it will give off Pastel Colors.. Pinks/Oranges.. And Dim or Brighten in a flickering manner... Power inverters when starting to fail will do what you are explaining.. And go on and off until eventually complete failure....
If you have a Sleep Switch/Pin in the upper base of the laptop, check to see if that is sticking ..
Posted on Nov 15, 2009
Testimonial: "I'll try the inverter board. I'm not seeing any pastel colors. They run about $20 on ebay!!!"
    Problem Solver:
  • 19 Answers
If its your lcd screen then it will stay black unless its the cable from your screen to the motherboard. or its your motherboard. with this problem theres not a cheap test to do. either you gamble on the screen or you gamble on the board. either way your looking at a 200 dollar test if you do the repair yourself.reason why is most screens now a days are attached to the cable.
  • 62 Answers
The power saver mode on your laptop is set too high.
Check your power options under Control Panel.
Show me where the power button is
http://www.insidemylaptop.com/replace-broken-display-hinge-in-acer-extensa-4620z-laptop/
Scroll down to the photo under Step 1.
On the cover that is being lifted in the air, look at the button at the bottom/right.
Circle that is open at the top, with a line coming through the opening, halfway.
Power On button.
Doesn't work? Perhaps you have a bad Power On switch.
(Located under the Power On plastic button)
For additional questions post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Acer Extensa 4620 Notebook
My laptop is Acer Extensa 7620G...I want to change the plastic casing of LCD as it has cracked..I have unscrewed the screen but finding difficulty to take off the hinges..please help
Screws ... under plastic with little covers ...typical covers is always hidden ... don't forget if something block your plastic,and you can not open in 90 % cases is screws ... I need see this model Acer Extensa..
Aug 23, 2010 | Acer Extensa 7620-4021 Notebook
Screen flickering
That really depends on when it flickers, does it flicker when you move the display open or closed or when you press some part of the laptop?
If it happens when you press a part of the laptop, the display cable could be loose, thats unlikely.
I recently had a similiar problem with a toshiba laptop, the screen would flicker when pressed on the bottom left side of the laptop.
I checked the wires and they where fine, in the end I seem to have fixed the issue by pressing on the top cover where the issue happens and at the same time from the bottom from the same spot, what I did on that laptop, there was a cover that I could remove so I could press directly on the mainboard, pressing directly on the mainboard with my fingers and at the same time pressing down from the top seem to have fixed the problem on that laptop.
Sep 11, 2009 | Acer Extensa 5420-5687 Notebook
I need instructions for installing Acer keyboard a2797.001
I'm not sure which model Acer you have but the pic of the keyboard looks simular to the Acer Extensa or TravelMate series laptops. If so, there's a plastic cover just above the keyboard, but under the screen that covers the display hinge. Open the display fully and gently pry up on the hinge cover. Then slide the horizontal bar next to the opening about a quarter of an inch and lift it off. You should then be abl to pry up on the keyboard to remove it.
Sep 08, 2009 | Acer KB.A2707.001 Keyboard
White screen or some times white vertical lines at start up
I had similar problem. Sometimes the screen goes white while working under windows and repositioning the display, but most of the time it goes white during power up. I decided to check the display cabling by removing the speaker/power-button panel and display coverings. Although I couldn't find a loose cable, the display was consistently working properly. I put it back together and so far so good.
To expose the wiring:
1. Power off, unplug power cord, and remove battery.
2. Open display all the way flat with the keyboard.
3. The speaker/power-button panel is also the cover for the display hinges. You can pry the panel off by prying up the hinge covers from the sides facing center.
4. The inside display covering is fasten with four screws in the corners covered by the rubber bumpers.
5. The outer display shell is attached by 6 screws. 2 on each hinge and 1 on either side of the LCD unit.
6. The mic and camera cables can be unpluged by gentle prying the plugs out.
Jul 10, 2009 | Acer Extensa 5420-5687 Notebook
Display issues - White screen
its not driver issue. it is about LCD DATA CABLE that comes from mainboard and goes to LCD.
need to take it to service.
May 27, 2009 | Acer Extensa 5420-5687 Notebook
White screen if i close lid and open it
your LCD panel cable could be disconnection. you need do follow steps
1) open LCD lid front cover, and loosen lid back cover, looking for a cable and a plug (plug in the socket) at back of panel, take out it clean all pins then reseat it.
2) if not fixed, you need change the LCD cable, because this symptom most cause the cable disconnection at plug and socket or itself..
hope help you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 27, 2009 | Acer Extensa 4620 Notebook
disable hibernation and disable the option make it "do nothing when i close my screen lid"
Mar 10, 2009 | Acer Extensa 4620 Notebook
Acer Extensa 4420 display goes black
Sounds like it could be that your Laptop is going into Sleep or standby mode,,,you can adjust these settings and times in "Control panel"
Jan 18, 2009 | Acer Aspire 3680 Laptop
How do you open up an acer extensa e210 pc to look at the RAM. Iv undone the (black) screws at the side of th Pc and tried to slide it off but it will not move. Do i need to undo anything else? Or could...
try to the front cover there should be tabs at the bottom presws them in and pull the bottom of the cover out then is should be able to be taken off then there should be a screw behind the front cover for the side cover
Aug 14, 2008 | Acer Computers & Internet
Acer Extensa 5420-5687 Notebook Logo
537 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
