I have a mitsubishi hsu595 vcr and when i try to record something an error e2 comes up on the vcr normally you would have to put in a channel example 9.please help.Thanks!
  • 350 Answers
E2 indicates that the loading motor is locked in the unload direction. I am not sure if this applies to the actual Mitsubishi model you have, but have you tried holding the power button on for more than 8 seconds, as that resets the error code on some models.
If the power button suggestion doesn't work I would unplug the unit, then take the top cover off and (carefully!) wiggle the arm that wraps the tape around the head, as if the problem is caused by an iffy sensor that could get it moving. (also generally shake the cogs in the mechanism)
If your feeling competent at taking things apart and putting them together again take the top of the machine (after removing mains power) and look towards the RHS of the deck mechanism and you will see a "Helter-Skelter" shaped piece of plastic which is part of the loading mechanism. Remove the "Pinch Roller" first.
If you carefully remove this taking care to note its orientation (note the position of the small index holes at its base) and that of the gears around it (A closeup pic taken with a digital camera comes in handy here) you can clean/degrease its inner shaft with isopropyl alcohol and a pipe cleaner, regrease it and re-assemble...it sticks due to hardened grease and causes error messages. Or you just replace the machine as it is older and who knows what could go bad next. It's up to you. I hope this helps and good luck!
Posted on Nov 15, 2009
I cant operate my vcr there's a code on it L2 I can't change the channel or record nothing it's theL2
Haveing looked around the web I can only find results for the E2 code for this model.
This means that when the tape was in the machine it tried to unload the tape and got stuck. There could be numorous causes for this that would require investigate. Till the fault is cleared the machine will be unoperational.
Nov 30, 2014 | Mitsubishi HS-U446 VCR
Recording from Sky
you need to connect the satellite box directly to the VCR and record
Sep 09, 2008 | Televison & Video
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
Doesn't give me the option to change the channel when timer recording
If you are recording something on the VCR, it won't let you change the channel. If not, you need to make sure the RC is set to the vcr in question (mine has VCR1 and VCR2)
You can set it up the way I've done for years...put cable line into VCR first, the VCR to TV..you then can watch and record 2 separate channels.
May 09, 2009 | Proscan PSVR73 VHS VCR
E2 Front
I needed help with an error message E2 (Front) on my Magnivox DVD Recorder MSR90D06 not a 30" TV. I will try to locate the manual and replace the wires on the back of the DVD to see if I can get it to work. Thanks anyway.
Dec 26, 2008 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
DVD/VCR combo won't record off of the t.v. even after programmed
Do you have a scart lead connected to E1 or E2 on the recorder.
Feb 19, 2008 | Televison & Video
Sony SLV-798 HF VCR
on alot of vcrs if you already have a set time for one channel to record at a later time if you dant set the earliest first it wont let you change it but im not sure if you already have one set ahead of time or not
Feb 09, 2008 | Televison & Video
E2 error
Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
Jan 11, 2008 | Mitsubishi HS-U445 VHS VCR
Set vcr to record a program later
The VCR has to be off for the timed record to work.
Oct 30, 2007 | Mitsubishi HS-U510 VHS VCR
Record one channel while watchign another
Ouirkygirl, a TV\VCR combo can only watch TV on a channel & record THAT channel. If the monitor is connected directly to the VCR then u should be able to RECORD what u see. Do you have a separate channel changer [buttons that say up\down channel ?] on the face of the VCR portion? If so, then u should be able to change the channel ON the VCR, record that channel, then change the channel ON the TV, .... I don't think so,.........any thing is possable
please explain your words :: "but when I record something it jumps to tha channel evern if I am watching something else at the time."
Aug 24, 2007 | Sharp 13VT-K100 13 in. Combo
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
