Question about Refrigerators
Ice maker is not making ice Often just turning off the switch inside the ice maker and then turning it on re-starts the ice making. We have done this several times. We have un-plugged the frig and after 5 minutes re-plugged it. The wand in the ice maker is down and the water has not been turned off. We have not touched or tried to adjust the wand since warnings posted say not to do so. Cannot check the tray since there is no description to show what the tray is.
  • david tobias May 11, 2010
    what brand is it
  • 78 Answers
Bad ice maker
Posted on Nov 15, 2009
How do I get the ice maker to start making ice again
Turn the water back on to the ice maker and also check the off/on switch inside the freezer door.
Dec 09, 2014 | Refrigerators
Tip
What to do if your ice maker stops working
Many refrigerators now come with built-in ice makers. Ice makers are very convenient, but occasionally they'll develop problems. Why pay a repairman to come out if the fix is easy and you can do it yourself?
Here are some tips for fixing an ice maker that stopped working.
- Check the on/off switch
Freezers with automatic ice makers have a switch that is used to turn the ice-making feature on or off. This switch is typically a rod above the ice box; when it's lowered, the ice maker is on, and when it's raised the ice maker is off. If the ice box fills up with ice, the ice can force the rod up, turning off the ice maker. Check this bar to be sure it is in the lowered position.
- Check if the auger or chute is clogged
Your ice maker has a chute where the ice falls from the freezer into the external tray (where a glass is placed). There is also an auger inside the freezer that rotates to drive the ice forward from the ice box into the chute. Check the chute for large chunks of ice that may be clogging it up, and check the auger for ice cubes or chunks that might have gotten wedged between the auger and the freezer, causing the auger to be unable to rotate.
- Check the water line
If you still haven't found the problem, check the water line leading into the freezer. This water line has its own valve. Make sure the valve is open, allowing water into the freezer to create the ice.
on Jan 23, 2011 | Refrigerators
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
Oct 12, 2013 | Frigidaire Refrigerators
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice Maker will not stop making ice
the beam is defective. Its called an optic eye it does tell the IM that the bins full and cuts power to IM when beams dont see each other.
Nov 04, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker
If there is not other problem it will start to work after there is water in the ice mold and it freezes. It will then dump and refill with water.
You can Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 02, 2009 | Refrigerators
The individual cubes turn into a huge block of ice
After the ice maker dump the ice it calls for water and pour water for no more than 7 seconds if is more and overflow the ice tray will leak on the ice bin and freezes all together , that means that the circuit board inside the ice maker is bad and need to be replaced but it will cost you almost as replace the ice maker and is easier ,two screws on the top of the ice maker and one in the bottom,a plug between the ice maker and the freezer wall ,and the plastic tube from what the water come into the ice maker.
Apr 07, 2009 | LG LRFD22850 Bottom Freezer Refrigerator...
Kenmore freezer on the bottom. Ice-maker switch is turned on but no ice is being made?
Check your incoming water line for kinks. Make sure the water valve is turned on.
Replace the water filter.
Check inside the freezer and make sure the ice maker power cord is plugged in.
Mar 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
Apr 12, 2008 | Refrigerators
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
