How do i use my backup disk from my windows 7 to use it to reboot my windows xp lab-top
  • 458 Answers
First Off, you can't jump from XP to Windows 7 without a Complete Fresh Install of 7... Second, you will need the XP cd to boot the XP machine, not a windows 7 backup.. You can however use an OEM windows 7 disk to boot the XP machine, though it won't upgrade..
Posted on Nov 15, 2009
Tip
Upgrade Windows XP to Windows 7 - it can be done!
Windows XP has been around for over 12 years. With that much time in use, there are bound to be situations where exporting data, finding install disks, installing the new OS, reinstalling the program and then restoring the data is not a viable option or is doomed to fail. What can you do if you are faced with this situation? Simply, upgrade the system to Windows 7!
Despite Microsoft's claim that there is no upgrade path from Windows XP to Windows 7, there is a way to make this happen. As a consultant, I am faced with this issue several times a month and fully expect this to rise as more companies transition to Windows 7. The reasons to upgrade the existing system range from legacy databases that cannot easily be exported and imported, software that is permanently associated with the specific PC hardware and software that require a hardware dongle that does not work with newer PC's. Regardless of the reason, there is a way to upgrade Windows XP to Windows 7.
Let me say at this point that the process to upgrade Windows XP to Windows 7 is involved and there are some things you will need to prepare for to make this process successful. If you have Windows XP 64 bit, you can upgrade to Windows 7 64 bit. If you have Windows XP 32 bit (as most installs are), you will have to use Windows 7 32 bit.
Tools you will need:
1. Download Windows Upgrade Advisor
2. External hard drive
3. Windows Vista Business Edition Service Pack 1 (no license needed)
4. Windows 7 Professional with license
The Prep:
As with any major change, you need to create a backup of the existing system. Use your favorite method of backing up the OS, data and system settings (I prefer to use Ghost to get an entire image of the hard drive in a short period of time).
Create the backup of Windows XP:
Before continuing, disconnect all hardware from the PC and uninstall all printers, scanners and any other hardware devices that will need a new Windows 7 driver. This step will save you time troubleshooting a failed device once Windows 7 is installed.
Also, verify the Administrator account log in and password or setup a new local Administrator level user login and password.
Run Windows Upgrade Advisor. This will indicate if there are any software or hardware that is currently in use that absolutely will NOT work with Windows 7. Evaluate all non-compatible software and hardware issue with the user and see if this is a "show stopper".
You can still proceed with the upgrade and see if you can make the software or hardware to work by changing the compatibility settings in Windows 7.
The Process:
With Windows XP running, put the Windows Vista Business disk in and start the upgrade process. When prompted, choose UPGRADE. (This process can take some time so be patient.) Let this finish and the system will reboot. Verify Windows Vista is properly installed by logging in using the local Administrator account.
Reboot Windows Vista at least 2 times, logging in each time, to ensure the new OS is working correctly.
With Windows Vista running, insert the Windows 7 disk and start the upgrade process. Choose the UPGRADE option again and let this complete (again, this will take some time so be patient). Once Windows 7 is installed, the system will reboot. Use the local Administrator account to login and test the OS to ensure it installed properly.
Test everything:
Test everything - log into each program and verify access and functionality. Do not skimp on this step - get the user to log in and watch them run their programs.
Once initial testing is complete, re-install the printers, scanners and other hardware that will need updated drivers to work correctly.
I have followed these steps numerous times and it has worked perfectly each time. Removing the printers and hardware before upgrading will save you time and was a lesson I learned after my first upgrade.
on Nov 09, 2013 | Microsoft Windows 7 Professional for PC
Tip
Upgrade Windows XP to Windows 7 - it is possible!
The Prep:
The Process:
Test everything:
on Nov 09, 2013 | Microsoft Windows XP Professional
Recover data from my backup
Which operating system and what data do you need to recover ???
You can create a backup disk with Microsoft Windows 7 or any other version of the operating system.
This disk will contain the files, programs and settings that you chose to save during the backup operation.
Yet, this disk does little good for you if you do not know how to retrieve that backup data.
Luckily, Microsoft offers a simple process for restoring this data to your operating system.
Even a basic computer user should have no problem restoring her backed up data from a backup disk.
Insert your Windows 7 installation DVD into your optical drive.
Reboot your computer and press a key to boot from the disk once prompted.
Click "Repair your computer."
Choose the hard drive that contains your copy of Windows 7.
Click "Windows complete PC restore."
The latest backup data will be selected by default. I
n the event you wish to restore earlier backup data, press "restore from a different backup."
Click "Next."
Your computer will now restore the backup data into Microsoft Windows 7.
Sep 27, 2011 | Gateway 506GR PC Desktop
Please connected Creative labs,inc.N10225 model no.VF0090 free download
ftp://vieuxpc.homeftp.net/Creative_Cam_VF0090_Win_98-Me-XP.zip
Jul 14, 2011 | Creative Labs Instant Webcam
I have ask you already how to install the dual boot os(Windows xp and Windows 7 ), but i don't complete yet .Can you explain to me again step_by_step in great detail ? because when i install windows xp...
Hello, this is how I dual boot my laptop with windows xp and windows 7
1. Backup all you important files, use an external hard-disk if possible
2. Make sure you have two drives or partitions: usually drive C and D
3. Insert your xp cd, do a quick format of drive C and install
4. Boot into windows xp and format format drive D if necessary
5. Insert your windows 7 DVD and follow the prompts. When it asks you to upgrade or new install, choose new installation
6. When you are asked to choose a location choose drive D
7. Complete your windows 7 installation
8. Thats it, you can now install drivers and programs
When installation is complete you will see both os options: windows 7 and previous version of windows (i.e xp)
I have done this numerous times without the need for any other step or software. The only rule is to is to install xp first, then windows 7.
All the best
Jul 11, 2011 | Computers & Internet
Creative labs pd1110 driver download for xp??
http://us.creative.com/support/downloads/download.asp?Product_ID=627&Product_Name=WebCam+NX&OSName=Windows+XP&OS=10&DriverType=0&details=1
Jun 09, 2011 | Creative Labs Video Blaster WebCam NX
I have a PC with C2D E7200 2.53GHz Processor, 250GB HDD & 2 GB RAM, I HAve 5 Partition on the HDD and i have partitioned it as C: 20.5GB__D: 68.3GB__E: 68.3GB__F: 38.3GB__G: 37.2 GB. On C Partition WIN...
#1 Use windows backup in Windows 7 to create a full system backup of the OS to DVD or a removable drive. (And well as any data on any other partition)
#2 Repartition drive to roughtly 50 50 split
#3 Install XP to partition 1, Install 7 to partition 2 then restore the backup of 7 to partition 2,
Nov 22, 2010 | Microsoft Windows XP Professional With...
I have a laptop with window 7, i try to reformat it but it can't is there any solution to change my o.s window 7 to xp...
You cannot perform an automatic downgrade (e.g. via an Upgrade function) from W7 to XP: you will need to perform a full XP installation on top of W7 from a self booting XP Installation CD.
By doing a FULL XP installation, you will loose all settings and all Applications software and drivers will need to be re-installed ... not for the faint hearted!!! The install will give you the option to reformat the drive ... but i do not recommend it !!!
I strongly suggest that you backup your existing W7 system to allow you to re-copied certains files (e.g. Document folders). Also separately backups your Internet (IE, Firefox, Chrome, etc) settings/favorites so that you can restore them under XP.
Make sure that you have all the required XP drivers for your specific Laptop available on your hard disk.
Hope it helps and good luck!
Sep 27, 2010 | Microsoft Computers & Internet
GA-EP43-UD3L Reboots while loading Windows
its due to bios problem , upgrage bios from biostar web
Oct 26, 2009 | Gigabyte GA-EP43-UD3L Motherboard
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
