Question about Roper RAX7244KQ Top Load Washer
The water just trickles into the machine - Roper RAX7244KQ Top Load Washer
    Brigadier General:
  • 4,088 Answers
Make sure there is adequate pressure at the supply faucets. The supply hoses should have filter screens on the supply ends that may be plugged with debris from the water supply. Reverse the hose ends and try to flush the screens into a bucket. Check the inlets to the washer for similar screens that may be plugged. The screens may or may not be removable--if not, open the top of the machine, remove the solenoid pack for the inlets and blow them out in reverse with compressed air. If all else fails, replace the solenoid pack.
Posted on Nov 15, 2009
When we use the cold water it is just trickling in. I cleaned the water inlet screen for the cold water on the back of the machine but it is still only a trickle. Is there another screen inside the back...
Often there is a screen at the inlet of the hose also...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
Hot water entering machine is only a trickle. It
Check the filter trap on the back of the washer where the hot water fill hose connects to the inlet valve, you wil have to shut the hot water valve off first, then remove the hose at the washer and inspect the little filter screen thats in the valve where the hose screws onto the washer, it probably has trapped enough sediment to restrict the flow of hot water into the washer.
Good Luck !
Mar 14, 2010 | Washing Machines
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
Rinse cycle water flows out to a trickle- regular wash cycle flows normal- water valve?
Flows out where , drain or into machine ? If into machine , Most washers have a cold rinse into machine . If your using hot fill and you get a trickle , then problem is a clogged screen at the valve or a bad water valve .
Jul 06, 2009 | Washing Machines
Cold water will only trickle into washing machine
Check your water pressure if thats good check the screens on your hoses, if thst good go to the water inlet valves that allow water into your tub
Jun 09, 2009 | Washing Machines
Water trickles slowly into the machine.
Turn off the water.
Switch on the machine and let it try to start filling, that will take the mains pressure off the hose, switch off the machine
Take off the hose at the washer end and check to see how much dirt there is in the small filter inside the inlet solenoid
Most of them pull out for cleaning , be gentle they are nearly all made of plastc and can crack
May 27, 2009 | Roper RAS6233KQ Top Load Washer
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Apr 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Roper RAX7244KQ Top Load Washer Logo
42 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
