Question about Whirlpool GR478LXPS Electric Kitchen Range
Whirlpool WEP84800 Range - Clicking Sound from Control Panel
Hi - We have just purchased a used Whirlpool WEP84800 Electric Range. It was supposed to be in great condition but when we turn on the oven we hear a "clicking" sound coming from the control panel at the top of the stove accompanied by a low buzzing sound as the oven elements heat up and clicks again every time the elements reheat. Any ideas why this is happening?? thanks in advance.
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
ranger25
  • 72 Answers
SOURCE: my electric glass top stove won't heat up?
They have a thermal overload resistor in the burner itself and they have a propensity to burn out, or it could be the infinite switch. You will have to check resistance across the leads that correspond to each pinout. You can find this out by backtracing the wire to each terminal on the block. Replacement of either part is the only option, there are no safe alternatives to repair them. Hope this helps. BTW, you can go here for parts.
www.appliancepartsdepot.com
Posted on Jan 28, 2008
SOURCE: need color code/wiring diagram info for Enterprise electric range installation of thermostat
I need the Oven knob for the front panel. The numbers have rubbed off on mine. Thanks, in advance, for your help!
Posted on Jul 28, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
Maytag317
  • 1136 Answers
SOURCE: Whirlpool Range Stove Top Indicator Light Stays Lit
Hi, You will need to change the burner switch as well. It shorted out when the element went bad.
Please let me know if I can assist you with part # or anything else.
Vic
Posted on May 30, 2009
Can you just replace the start button or do you have to replace the entire control panel on a Whirlpool Electric Kitchen range Model RF114PXSB????
Hi, there. While we cannot assist with repairs I can offer links to our troubleshooting, use and care guides, replacment parts, parts lists, and service line should that be necessary. We hope this helps.
http://bit.ly/zkfnZd
http://bit.ly/112Lu7q
http://bit.ly/LrNZiS
http://bit.ly/yLv4Z5
Oct 11, 2013 | Whirlpool GR448LXPQ Electric Kitchen Range
Wire burning smell whirlpool range. Happens when oven or top are turned on. Smoke come out under control panel.
Had the same problem with my Whirpool range. Took off the rear panel and carefully plugged in and turned on the top oven. One of the terminals on the part labeled as 'Switch, Hi-limit' started to spark, glow and emit smoke. This part had 2 blue wires running to it. One came off of the top element in the top oven and the other fed back into the black plug on the control panel. Part in quests is held on with a single screw and has a part no. of 7403P993-60
Oct 30, 2011 | Whirlpool GR673LXSS - Stainless Steel...
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
Clicking sound from control panel of my new glass top samsung electric range every 30 secs or less. as the oven is warming up to temp. It continues after it reaches temp. but not as bad....
This clicking sound is a result of the heating element cycling on and off as it tries to maintain a temperature. It heats up rapidly to a maximum, safe temperature and once the maximum is met it shuts off for a couple of seconds so it does not overheat the cooktop and/or your temperature setting. As far as the clicking, just how loud is it? If it's minimal and only fantly noticable then it's normal. If it is quite loud and annoying that may be a whole other issue. Does this information help? Let me know.
Before I forget, there should be a section in your Owner's Manual explaining that the clicking sound is part of it's normal activity.
Nov 21, 2010 | Samsung Kitchen Ranges
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Whirlpool range
hi the part # is AP 3008287 at Appliance parts pros.com infinite switch controls the top burners thanks the appliance doc
Sep 29, 2008 | Whirlpool GY396 Electric Kitchen Range
Oven or broil does not work
hi thanks for the question . the control board seems to be defective the clicking noise is the relay .but not letting power to the elements thanks the appliance doc
Sep 28, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool GR478LXPS Electric Kitchen Range Logo
386 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
