Question about Acer Aspire One PC Notebook
Our acer aspire one has xp on it and when it comes on the computer says it is missing the NTLDR, what is it and how do we fix this, this is only 5 months old
    President:
  • 2,600 Answers
NTLDR:(use with NT, 2000, or XP not 98)
Short for NT loader, NTLDR is a program loaded from the hard drive boot sectorour acer aspire one has xp on it and when it comes - 2.gif that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load.
Try the fix below and see if that straightens it out....this may be hardware related if this fix does not work as in Bad HDD.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Posted on Nov 16, 2009
Acer aspire one restore failed: wont start now
the reason its saying,,ntldr is missing is because its lost somthing from the hard drive that it needs to run,it would have lost that when it stopd loading your windows.try it again and if it gives you..repair windows ,,,then do that.and it should do it because it should fint the missing file that it needs to carry on loading.
May 04, 2014 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire one zg5 - ntldr missing. Can you help and how much is the cost. Thanks
have an acer aspire one zg5 ntldr missing and computer has no cd drive and i dont have the xp cd -rom how can i install then to get my computer back working. please someone help me
Oct 20, 2010 | Acer Aspire One Netbook
I have a Acer Aspire One Netbook it has come up with a NTLDR is missing i have restart it put it comes up the same can you help me plz
Causes:
   1. Computer is booting from a non-bootable source.
   2. Computer hard disk drive is not properly setup in BIOS.
   3. Corrupt NTLDR and/or NTDETECT.COM file.
   4. Misconfiguration with the boot.ini file.
   5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
   6. New hard disk drive being added.
   7. Corrupt boot sector / master boot record.
   8. Seriously corrupted version of Windows 2000 or Windows XP.
   9. Loose or Faulty IDE/EIDE hard disk drive cable.
  10. Failing to enable USB keyboard support in the BIOS.
Solutions are here: http://www.computerhope.com/issues/ch000465.htm
Let me know if you need some help
Sep 11, 2010 | Acer Aspire One Netbook 8.9" Notebook
I have a acer aspire one and it wond start up cause is missing ntldr have no clue what that is can you help???
The ntldr file is one of the system files that is required when the computer boots up. This file could be missing or is corrupted.
To fix this problem, please click on this link and follow my instructions :-
http://www.fixya.com/support/r4482455-repair_windows_xp
Jun 29, 2010 | Acer Aspire One PC Notebook
Acer aspire one error in oxf0000005 / NTLDR is missing
That is a windows error. You can try booting off the original installation CD and choose option for fix current installation, but chances are 50.50 if it will work or not. NTLDR is the bootmanager for Windows NT based systems (Windows NT, 2000, XP, etc). Critical system file, typically protected against altering.
The error code you gave is usually associated with windows having issues seeing / using a SATA drive. You will likely have to find the driver for our particular SATA controller, and load it when prompted as you startup off the recovery disk.
Jun 22, 2010 | Acer Aspire 5102WLMi Notebook
I have a 5 month old acer aspire one with xp and when computer comes on it shows NTLDR is missing, how do we fix this
you will need to run Recovery on it... NTLDR is needed to boot to windows.. if its missing, it won't boot to windows, and unless you have an external cdrom and can throw in a recovery disk or a cd of the same version of operating system and choose to repair.. then fixboot and run chkdsk /r...
To get to your recovery partition press ALT and F10 at boot up
Note: some aspire one's don't have a recovery partition.. and in this case .. windows will need to be reinstalled..
Nov 15, 2009 | Acer Aspire One PC Notebook
Screen says NTLDR is missing.
hello friends..
Ntldr file is essential file in order to boot system...If it is missing then your system wont start..try to repair this file from XP/vista CD .. then problem will vanish
May 12, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer aspire 5100 nfltr is missing error
The best way to cure this problem is to install a new copy of windows xp. You have ntldr missing error, that means the problem is with the os loader. If you choose to reinstall os then please try to repartition and reformat your hdd.
You can find the drivers for your laptop at
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
Nov 24, 2008 | Acer Aspire5100 Notebook
Ntldr missing
You need to do full system recovery to boot up your pc again. NTLDR is a hidden file that is needed to boot windows. Your laptop should come with a recovery disc to re install Windows.
Hope this helps.
Sep 12, 2008 | Acer Aspire 5100 Notebook
Acer Aspire One  PC Notebook Logo
127 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
