Question about HP DeskJet 672c InkJet Printer
I have an IBP PC W. / XP- I purchased a cable with a usb at on one end the printer plugs on the other to plug into the 672 C- added the new driver to update the printer, the computer does not give a choice for usb port, only a parrallel, port , and printer will not respond , nor print dav dcoltun@gmail.com
  • 62 Answers
  1. Try adding the printer.
  2. Try the HP website for an up-to-date driver. However they may not be making one for that printer. Depends on the age of the printer.
Posted on Nov 15, 2009
I have an old printer model HP psc1315 all in one, printer, scanner. What I need is a software when I can scan my document. I don't have HP director and I cannot find any software in the web to be able me...
IT COMES ALONG WITH THE DRIVERS CD
TRY REINSTALLING PRINTER
FIRST UNINSTALL YOUR PRINTER COMPLETELY
REMOVE ALL CABLES OF PRINTER (USB)
REBOOT YOUR SYSTEM
HAVE DRIVER CD
PUT IT IN ROM(CD/DVD)
INSTALL PRINTER SOFTWARE
DONOT PLUG THE USB CABLE UNLESS & UNTILL PROMPTED
PLUG USB WHEN ASKED
FINISH INSTALLING PRINTER
NOW YOU CAN FIND THE SCANNER
Feb 07, 2011 | HP Computers & Internet
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
I purchased a new computer having WINDOWS 7 as operating system. I am having printer HP Officejet 4355 All-in-One and CD drive supplied for this is not compatible to WINDOWS 7 OS. What to do?
I think this printer don't have the cd software available for Windows 7, 32 or 64 bits. But you can use it with the plug & play feature of Windows. Just turn the printer on and plug the USB cable (try cables of less than 6ft and a port in the back of the PC, also avoid the use of any USB HUB). Windows will automatically recognize the printer and install an embedded driver. You will see in the control panel under printer and devices if the unit was successfully added
Sep 07, 2010 | HP Officejet 4355 All-In-One InkJet...
Problem in my DCP-165C
Dear ,First you have to remove all old installed driver of this p'rin'ter along with Paper Port also, Do not connect the printer to PC before it is asked to do So, Now installed the New Driver again , When PC shows PLUG IN THE USB CABLE than connect the machine with PC, It shows NEW HARDWARE FOUND , and then it will complate the installation,
Apr 29, 2010 | Brother DCP 165C Compact Color Inkjet...
Tried to connect my NX6310 to my printer which is a HP All-In-One series 6300 BT. Printer will not work and I used the cable USB port to USB port and picked up new drivers, Microsoft Professinal, XP
The trick with windows XP, most of the time is to install the drivers first and wait for the software to ask you to plug in the printer. Try removing the printer from your printer's folder if windows already tried to install it, reboot when it removed, then install the device drivers/software first and when asked...plug in the printer.
Nov 18, 2009 | Computers & Internet
Brand new brother HL-2140 get service call error (all lights flashing for more than 10 minutes). First time to setup. Don't know how to proceed.
You should have a manual with your new printer, please read it before doing anything with your printer. I'll try my best to show you how to set it up properly for the first time. Make sure to plug the right cable at the right place. There should be 2 basic cable for your printer to work properly; the power cord and the USB cord. Power cord is thicker than the USB cord (black). One end goes to the printer and the other to the power outlet. The USB cable is the data cable of your printer (white/transparent). One end should go to the printer and the other to the PC. First, plug the other end of the USB cable to the printer and the other end to the PC. Next, plug in the power cable to the printer going to the power outlet. Press the power button and you can now use the CD that came with the printer to install the driver. If the lights still persist, then check the toner and the tray. It should be properly fitted inside. Also check the paper, there could be a paper stuck inside.
Hope this helps . . .
Nov 08, 2009 | Brother HL 2140 Laser Printer
Printer wont install when I plug in the USB cable.
New printer would only works with the driver supports from the manufacturer only. THis is for higher printer.
May 11, 2009 | HP Photosmart C4180 All-In-One InkJet...
HP Officejet 6310 All-In-One... Problem
hi i would like to let you know that inside the box of the printer it does no include a USB cable you need to purchase it separately.maybe this is the reason why that when you plug it in the USB port it does not fit.try to purchased a USB 2.0 cable from any electronic store in your place and this will help to resolve the issue..
send comment for futher troubleshooting steps...thanks
Sep 01, 2008 | HP Officejet 6310 All-In-One InkJet...
Brother fax 8250P
First you need to purchase a parellel printer cable. You will need to install and/or download the software for this unit. Make sure you plug in the cable. one end to the printer ,one to the computer. Then when you print...make sure you choose THAT printer to download from.
Sep 18, 2007 | Brother FAX 8250P All-In-One Laser Printer
HP DeskJet 672c InkJet Printer Logo
52 people viewed this question
Seeker5211
Seeker5211
