Question about Akai PT46DL10 46" HDTV-Ready Television
Lamp light is on. lamp's are dusty? how do you clean them
  • 10,594 Answers
Lamp light is On means replace lamp in TV.
Lamp replacement procedure would be written in user manual.
Posted on Nov 15, 2009
I got a viewsonic pjd5111 projector used . it power on for aleaast 30 sec and shut down immediately temp light red and lamp light green . i hv tried everything .help
Check if there is a cooling fan. Is it rotating?
It is also possible that the filter is dusty and needs to be cleaned/replaced.
(all projectors have a cooling fan and a filter to prevent dust from reaching the lamp. A faulty fan or a reduced air flow may cause an overheat problem)
Aug 16, 2016 | ViewSonic Office Equipment & Supplies
Power light blinks red 5 time, Lamp driver Faulty. I replace the ballast no change. Can you help?
If the screen is not starting It may be your main power board, not lamp driver, you would need to check the volts on the board.
Sep 29, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
My standby/temp light is blinking and my lamp light is blinking. tv is about two years old. Just started happening out of the blue. It will come on for a few minutes. I have three dogs and it gets dusty...
check the lamp if you havent changed it before that would be the easiest place to start. if the lamp is popped you will see glass pieces rolling around in the lamp.
Dec 22, 2010 | Samsung HL72A650 Television
Picture only goes on for 1-2 seconds then goes blank with standby light flasing red 4x...was told it was the fan. Its probably dusty and would like to know how to get to it and clean it before I get ripped...
This also could mean that you need to replace the lamp. LCD displays have a lamp timer that when it reachs it max time it will not allow the unit to turn on till the lamp is replaced and the timer is reset. Check your manaul to see the proper proceedure to do this.
May 15, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
About how many hours are left when the replace lamp message comes on?
usually between 0 and 50, depending on how clean you keep the projector. if it's really dusty, the lamp could explode from overheating at any time.
Feb 07, 2010 | InFocus ScreenPlay 7205 Multimedia...
My SXRD 60" Sony LCD TV turns on. green light flashes about 6 times, then solid green. But just as screen starts to light up, turns off, solid green light turns red and blinks red four times, then stops. a...
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Oct 10, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
When I turn the TV on it comes on for 1 min or so then turns off. I get the green blinking light by standby/power button. Then it comes back on....then off again.....then on. It just comes off and on...
Has the Lamp been replaced yet if not replace it pull backoff watch Fan to Lamp if it stops running while Lamp is trying to turn on Lamp will turn OFF FAN maybe defective. For Parts Call Encompass 1-800-638-3328 Clean out all dusty dirty Fans and around Lamp housing.
Oct 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Error code U8-6 on Xerox 5320 copier
dear sir please check the exposure lamp unit may be it is dusty so clean it or check exposure lamp circuit fuse etc....
Oct 07, 2007 | Office Equipment & Supplies
Akai PT46DL10 46" HDTV-Ready Television Logo
203 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
