Question about Nintendo Wii Console
Console not reading the disc - making a clicking sound will play downloaded games - nintendo Wii
bhiga
  • 119 Answers
SOURCE: can we play gamecubegames inside the wii console, if so how?
The Wii can play GameCube games, but you cannot play Nintendo 64 games.
Also, to play GameCube games, you will still need GameCube controllers. The Wii has 4 GameCube controller ports on it. The Wii controllers will not work for playing GameCube games.
Posted on Apr 05, 2008
  • 31 Answers
SOURCE: Brand New WII Console won't read any disc's
If Wii gives Disc Read Error, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
Posted on Mar 05, 2009
  • 5 Answers
SOURCE: 2 discs in stuck in nintendo wii console
asdfds
Posted on Mar 21, 2009
localwonder
  • 6784 Answers
SOURCE: unable to read disc message on Wii
Try a cleaning disc. this may fix this issue. if the issue remains, it will confirm a major problem within the optical assembly. you will need to replace the optical assembly in this case. it has failed.
Contact Nintendo for the optical replacement procedure.
Posted on Jul 26, 2009
SOURCE: downloading wii games & disc not recognised on wii
That's because you need a modchip inside your Wii, like Wiikey...
So you can play any Wii Game (Japan, PAL, US Games) or burned Wii Games...
Posted on Nov 29, 2009
The discs could not be read and they have no scratches and look fine then
The Wii console will not play game discs (disc is not recognized)
System displays either error message "Unable to read disc" or "Disc could not be read"
Note
Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
Verify that the console is placed correctly.
If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
Verify that the disc is being inserted properly.
If the console is placed horizontally, the disc label will face upwards.
If the console is placed vertically, the disc label will face to the right.
Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
If the disc is dirty, try cleaning the game disc. (How to)
If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Nov 17, 2012 | Nintendo Wii Console
Wii Disk Error
Unable to Read the Disc" Error, or Disc Not Recognized (Will Not Play Game Discs) Situation:
  • The Wii console will not play game discs (disc is not recognized)
  • System displays either error message "Unable to read disc" or "Disc could not be read"
Important!
  • If this problem happens very infrequently, it is normal and does not indicate a problem. A Wii Lens Cleaning Kit can be purchased to help keep the lens clean and prevent the situation from worsening over time.
  • Wii Game Discs are region locked, and can only be played on hardware from the same country where the game was released. (A European game cannot be played on a North American system, for example.)
What To Do:
  • The Wii console is only compatible with Wii and GameCube discs. It is not compatible with DVDs or discs made for other home consoles. Verify that the disc you are inserting is compatible with the Wii system.
  • An error message may display if the disc is ejected during play. Return to the HOME Menu before changing discs.
  • Verify that the console is placed correctly.
    • If the Wii console is lying flat, the game disc slot should be above all three buttons and the SD Card slot.
    • If the Wii console is standing vertically, the power button should be on the top and the console should be in the stand. Note: Only Wii consoles with model number RVL-001 are intended to be placed vertically. (Learn more)
  • Verify that the disc is being inserted properly.
    • If the console is placed horizontally, the disc label will face upwards.
    • If the console is placed vertically, the disc label will face to the right.
  • Check the non-printed side of the game disc for dirt or severe damage (such as scratches or cracks).
    • If the disc is dirty, try cleaning the game disc. (How to)
    • If the disc is damaged or scratched, it will need to be replaced. Please click here for replacement options.
  • If the problem occurs with only one game disc, there may be a problem specific to that game. Click here to check our list of specific game issues.
  • Make sure only licensed accessories are being used. Unlicensed products do not undergo Nintendo's testing and evaluation process. They may not work at all with our game systems, and they may have compatibility problems with certain games or accessories.
Situation Not Resolved:
How many games does this occur with?
Mar 17, 2012 | Nintendo Wii Console
When disc playing makes really loud buzzing or grinding sound.
My friend too faced same kind of problem ............
with his nintendo wii console it doesn't get start at all.....
If you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by downloading repair guide
Click Here to get guide
Dec 03, 2010 | Nintendo Wii Console
My wii diisc will load and play but when i get about five to ten min into the game the disc just stops and this message shows up. " the game disc could not be read. refer to wii operations manual for...
This is a common error ........this error occur due to the internal defect caused by crashes in the cd you used
you can fix this easily don't worry .......... their are repair guide available for nintendo wii console you can download it and solve your problem just like that ...... Click this link
CLICK HERE to download guide
Dec 02, 2010 | Nintendo Wii Console
Our wii send an error message saying it can't read disc
i had the same problem with my wii. I called nintendo and then had to ship it back to get repaired.
Feb 11, 2010 | Nintendo Wii Console
Our wii console will not read any discs
Sent the console to Nintendo to be repaired.
Jun 24, 2009 | Nintendo Wii Console
Wii makes a buzzing sound when discs are running
The noise is the wii working extra hard to read the disk the lens might be dirty. Your wii might also have a bomb in it.............Just kidding. I would try cleaning the inside and if all is bad send it in to get fixed
Apr 10, 2009 | Nintendo Wii Console
Wii will not play any of my games discs
Made a video showing how I fixed this exact problem on a Wii.
Mar 20, 2009 | Nintendo Wii Console
Wii wont read discs
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
160
Dec 16, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
