Question about HP DeskJet 940c InkJet Printer
Hi. I have a hp deskjet 940c. I can't replace the black ink cartridge because it doesn't come to middle. When I took out the old cartridge, it suddenly shot back into its hole, like a rabbit, and it won't come back out again no matter what I try. The colour cartridge still prints so Im wondering if there's a way I can get the black cartridge back into its slot. ANy ideas? CHeers
  • 2 more comments
  • lloydharriso Nov 15, 2009
    The cartridge won't budge, no matter how hard I try. I can't get it to the middle. I assume the printer has to be off when I try to pull it out?
    i thought so. anyway, there's no way i can move it to the centre with my hand, it's impossible. game over, new printer? or should i be able to force it?
    actually, my wife just told me the colour one doesnt work either. we turn it on, the red light flashes but we can't print at all...
  • lloydharriso Nov 16, 2009
    Thanks. I'll just go out and get a new one, save the hassle.
  • 555 Answers
Sounds like the mechanism somehow is jammed.
If you have previous experience opening printers or electronics articles, let us know, so we can provide a step-by-step guide and try to fix the issue.
If not, You may need to consider to buy a new printer (You can get a new one for $19.90 or $24.90) and forget about this trouble with the printer. Unfortunately, today Inkjet printers are more like disposable.
Posted on Nov 16, 2009
  • 11,896 Answers
Take your hand and pull the ink carriage to the center, then lift up very front of cartridge, then lift straigh up on the rest and it will come off. After snapping in new one, press power button and carriage will align itself back into place.
Posted on Nov 15, 2009
  • Nate Stansfield
    Nate Stansfield Nov 15, 2009
    Yes printer must be off or it won't budge. It will actually break if forced while it is turned on.
I have an hp deskjet 940c. I don't know if this is the same model as deskjet inkjet. Anyway what light is on or off on the front when a new ink cartridge(s) is needed?
For the HP 940c, there is only one light to indicate a possible low ink cartridge. The LED above the cartridge symbol (the only one without a button) will flash. (Note: this LED is the second from the left.) When you see the error code, open the printer's top cover. If the error is a low ink issue, the LED will stop blinking.
With the cover open, the cartridge carrier will move until the yellow arrow lines up with an icon on the printer itself. These five icons are in order from left to right (as you look at the cartridges) : tri-color ink cartridge problem, black ink cartridge problem, tri-color ink low, black ink low and cartridges OK. If both cartridges are low, replace the one indicated by the arrow. Then the cartridge carrier will move to indicate the other cartridge is low. (If only one has a problem, after you replace it, the carrier will move to the cartridge OK symbol.)
If HP offers the full-feature software for your OS, then install the software. Use the HP Deskjet Toolbox to get exactly which cartridge needs to be replaced without needing to be ready to replace both (or to monitor your ink level (approximate ink level)).
The manual for the Deskjet 940c is available as a PDF from HP: http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=125&prodTypeId=18972&prodSeriesId=35985 .
I hope this helps.
Apr 11, 2011 | HP DeskJet 940c InkJet Printer
I have an hp deskjet 940c. the colored ink is out but there is plenty of black ink however the ink light is flashing and it wont print. do I need to replace the colored ink in order to print something or...
You will need to replace the empty color cartridge to get the flashing to stop.
However you should still be able to print in BW. Check that the applications you are running are set to
BW and not color in the configuration menu. That should permit you to print in BW only.
Mar 22, 2011 | HP DeskJet 940c InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
How do you check the ink levels of the cartridges on a hp deskjet 940c
If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing when the printer’s top cover is opened. When you open the panel the ink cartridges slide to the center , as far as checking the ink level find and right click on the printer icon, click properties, and find ink cartridges and ink levels.
Thanks
Shereena.
Apr 22, 2010 | HP DeskJet 940c InkJet Printer
My HP 940C only prints in shades of red. I replaced with new HP 15 & 78 Cartridges, still have same problem!
Some HP ink refills have the exact same product number but the electrical contact tips on the back of the cartridge are not the same configuration, resulting in red ink only being printed. One example is the DeskJet color ink cartridge C1823D having multiple configurations.Find a printer just like yours that's working properly and compare the contact tips if possible. HP tech help is a joke on this one. Good luck!
Dec 29, 2009 | HP DeskJet 940c InkJet Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
My hpdeskjet 940c wont accept a 4X6 photo paper It tries but the paper doesn't slide through
Print a test page only in black. If little to no black shows, you need a black. If your color cartridge seems full, only get a new HP black ink cartridge.
Oct 03, 2009 | HP DeskJet 940c InkJet Printer
940c just prints only half the page it starts printing without the first part of page
try replacing the print cartridge. If that doesn,t work try cleaning the ink reservoir. Be careful it could get messy. use a q-tip with a little alcohol. also clean the contacts behind the print cartridge. always turn off the printer before servicing it.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 03, 2009 | HP DeskJet 940c InkJet Printer
Hp94c Installed refilled black ink but printer does not recognize
try cleaning the contacts with a wet towel
from both cartridge (black and color) and in the printer
where the cartridges get in (metal pins)
Jun 07, 2009 | HP DeskJet 940c InkJet Printer
Hp deskjet 940c printer
Hi.
I think it must be the ink blow-by, you must clear the ink path through the printer head. Try to activate the cleaning of the head pins. Just go to the printer icon then right click and click the printing preferences then look for the head cleaning menu. then try to print test by doing a cold reset.
Jan 24, 2009 | HP DeskJet 940c InkJet Printer
HP DeskJet 940c InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
