Question about HP vs15 15"LCD Flat Panel Monitor
Speakers doesn't work - HP vs15 15"LCD Flat Panel Monitor
Firstly I would try increasing the monitor's volume control (found on the right hand side of the monitor).
If that does not help, check your computer's volume control is not muted.
For me however, the number one cause of no sound is the green audio lead which normally plugs into the rear of the monitor coming loose. This lead can be found just by the video lead. Could you check that that is plugged in firmly and if it is, check the lead on the PC side of things. Check that the green lead is plugged into the (usually) green headphone or speaker output jack on your computer. If this does not help, then try to borrow another lead of the same type (ask for a 3.5mm to 3.5mm lead) and try that. If none of this has helped then your monitor may be defective.
Posted on Dec 24, 2009
BOSE CENTER SPEAKER WON'T WORK
Try a different center speaker on the unit to see if it will work, One that you no is good, If it doesn,t work then you no there is a problem with the unit,
Dec 06, 2012 | Bose Audio Players & Recorders
Sound doesn't work tried settings tried turning it up ect can't hear ring tones nothing. when speaker is on when talking to someone it doesn't work.
seems your ringer (Speaker) got damage you have to replace them, install a new speaker and your phone would ring back again.
please vote me if found helpfull.
Aug 04, 2011 | Samsung Gravity SGH-T459 Cell Phone
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
When i power it on it shuts off i got a kenwood kdc-mp825
Disconnect all of your speaker leads at the head unit, make sure none are touching, then power it back on. If it still cuts out, check your ground, if it doesn't, re-connect speakers one by one and test power again. It will either cut out when you get to a speaker or wire that's shorted, or work just fine. it's protecting itself from damage by cutting off when speakers are either bad or have shorted wiring. Most common shorted wiring happens on door speakers at the hinge. If it continues to cut off without speakers connected and you have a good ground, the unit needs service. If it still plays and you find the speaker or wire that's causing the problem, disconnect the wire at the speaker and test again, if it works, replace the speaker, if it doesn't, replace the wire. Hope this helps
Jul 07, 2011 | Kenwood Sirius KDC-MP825 CD Player
The right speaker doesn't work
Make sure all the cables are connected properly.
Treble must be at mid-setting.
Jun 26, 2011 | Altec Lansing ACS 495 Computer Speakers
My lenovo y 430 has no sound for hedset & subwoofer doesn`t work. ... and right speaker works but left one doesn`t what should i do?
Make sure that the correct playback device is set as default in sound properties.
If all is well there then you could try a pair of headphones to see if the sound is working.
If headphones work ok then it is down to your built in speakers, not much you can do unfortunatly unless you are still under warentee
Jul 10, 2010 | Lenovo Tablets & eReaders
My phone nokia 5130, it doesn't work at this time. But on the following days i can use with loudspeaker only now it doesn;t work
hi :) u mean before u can use with loudspeaker,mean the speaker hearing people talking cant work ?? if now both speaker cant work,mean both speaker was apoil.pls send to mobile shop exchange new speaker.
Jul 06, 2010 | Nokia 5130 Cellular Phone
My back speaker doesn´t work,, everything is
It sounds like it's your radio if it's the OEM. To make it somple the factory radio had there separate amp muilt in each chanel so if one speaker went bad the others woudl still play. There is no quick fix other then haveing it replaced or if have it repaired.Good luck and just dubble check all the connections
Apr 08, 2009 | 2004 Dodge Durango
HP vs15 15"LCD Flat Panel Monitor Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
