Maytag washing machine fuse blows everytime I start machine why?
    President:
  • 1,922 Answers
Either the units motor bearings are defective,the start windings are defective or the motor start capacitor is leaking or totally shorted on the motor case
Posted on Nov 17, 2009
Washing machine keeps blowing fuses
when does it blow a fuse
1 as you start the machine
2 or how long after the machine starts
3 at the end in spin
Jul 22, 2014 | Maytag Washing Machines
Maytag model ka806 won,t start. Could it be a safety switch or fuse?
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.Here is the part you need.
Dec 26, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
May 20, 2009 | Maytag SAV571EEWW Washer
4A fuse blows when door is opened
You will need to order a coor kit it comes with fuses all parts including fuses there was a door switch problem and maytag sent a door kit to replace old parts
May 11, 2009 | Maytag Washing Machines
Fuse blew on my Maytag washing machine. 1 amp only and others blow. Time to buy new or service?
yes.you can buy the switch assembly unit. it gets short and the fuse blows out.
May 04, 2009 | Washing Machines
Washer was in fill cycle and stopped
You've got a short circuit somewhere in that electrical circuit.
First, unplug the washing machine.
Replace the fuse. If it doesn't blow immediately, then there is likely a short in the washing machine, and from what you describe, it's in the motor.
If it blows, then there is something wrong in that circuit, and you can likely rule out the washing machine. Check all devices on that particular circuit, of which there can be a number of plugs.
Jan 23, 2009 | Maytag LAT3600A Top Load Washer
Maytag washer
check the resistance or grounded part in the unit. find the schematics and manually check the resistance of each part and find also which one is grounded. this would make the fuse blow.
tnx 4 using fixya,
drcool
Nov 07, 2008 | Maytag HAV3460AWW Top Load Washer
Washing machine fuse blows every couple of washes
the machine is pulling to much power.check to see if it is on a 15 or 20 amp outlet. you said you replaced the fuse. the amp size should be on it. if it is a 15 amp fuse,plug the machine into a 20 amp circuit and see if the fuse blows then. it shouldn't since it wasn't blowing everytime on the 15 amp circuit, but never put a 20 amp fuse in a 15 amp socket! the fuse can handle the load[ no pun intended], but the electrical wire would burn not blowing the fuse, thus causing a fire.
hope this helps.
wg
Feb 17, 2008 | Creda W100FW Front Load Washer
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
