Question about Lexmark X502N All-In-One Laser Printer
How do i get it to bypass color print and only print in black
  • 58 Answers
When you click on File, Print, click on the properties button next to your selected printer. If you look through the various menus in printer properties you should see an option to print in greyscale. Every printer is different so the option isn't always in the same place.
Posted on Nov 15, 2009
My colored ink needs to be replaced, however, I still have black ink, why will the printer not let me print in black and white, there is no grayscale.I can't print at all unless I replace the colored ink.
The issue is the printhead needs constant flow, I have seen bypasses but this damages the print head and all kinda of mess happends. The solutions here is a grey scale laserjet if your only use black ink. Your would be alot better off because this printer mix inks to make black and vice versa, So you need to fork out the bucks for the color cartridge or change the solution to toner if you do not use color. Yes there is a bypass but we are not aloud to provide that because it will dmage you unit and we cannot be liable for that Google is your friend!
Thanks and please do be considerate and leave postive ratings and feedback for your free answer today.
Jun 12, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
My Hp color Laserjet won't print unless all
You have to replace all empty cartridges...no other solution
Oct 19, 2009 | HP Color LaserJet 3500 Printer
Hp color laserjet 2600 n it will not let me print
There is an override sequence and it works well. Press the select button (checkmark) to indicate Main menu. Press right-arrow (RA) to select System Setup. Press Select , then RA to Print Quality, Hit select. RA to Replace supplies and hit Select. Now, RA to Override Out and Select. Confirm with Select again. Your 2600n will now run even with an empty toner cartridge.
Jul 08, 2009 | HP Color LaserJet 2600n Printer
Trying to print in black & white only
THis option is in the printer driver.
under Printing Preferences
Graphics
Output Color
Change this to BLACK
Jul 01, 2009 | Dell 3110cn Laser Printer
Can you force a printer to print in grayscale?
Yes, you can bypass the color printing. The software you are using for printing can help you change from colour to gray scale or adjust it in the printer properties.
May 10, 2009 | Brother MFC 420CN All-In-One InkJet...
0% color ink
We cannot bypass the color ink check, since the all-in-one uses little amount of even the color ink to print in black. Once check the expiry date of the color cartridge and clean the copper contacts of the cartridge and reinsert it again and then try to print. If the issue still persists replace the color cartridge and check for the result, if we experience the same issue even after replacing the color cartridge then the issue is with the all-in-one.
Apr 12, 2008 | HP Officejet 7130 All-In-One InkJet...
Trouble Printing
You go into your control panel and select properties, select reset ink counter and tell it you have a new color cartridge. It won't know you lied. When you choose gray scale printing it uses the colors to create black just to extend the life of your black cartridge.
Nov 13, 2007 | Office Equipment & Supplies
Cannot print in black only
It is not wise to leave the cartridges empty, causes permanent print-head damage on the empty color area. However, if you want to use the other color, say "black", bypassing the cartridge check is simply resetting the counter of the printer... download the utility file "sscserve.exe" you can search it on the internet. Install it then choose your printer on its list box, then by right-clicking on the printer icon of the utility at the bottom right of your window... you should be able to see what you need. Happy printing!!!
Oct 23, 2007 | Epson Stylus Photo R220 InkJet Printer
Lexmark X502N All-In-One Laser Printer Logo
42 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
