Question about Dell 924 All-in-One InkJet Printer
I need to change an ink cartridge. The manual says to turn on the printer and the cartridge carrier moves the center and stops at the loading position. But, mine does not - the carrier is off to the side where I can't see, or reach, it. How do I get the cartridge carrier in the center of the printer so I can access the cartridge?
  • cebooth Nov 16, 2009
    Thanks, but I had already tried it and it didn't work. The carriage moves a tiny bit but goes back to its original position at one side of the printer.
    Anyone else?
  • cebooth Nov 22, 2009
    Sorry, I posted my response above by mistake:
    Thanks, but I had already tried it (lifting the lid, as the manual instructs) and it didn't work. The carriage moves a tiny bit but goes back to its original position at one side of the printer. Anyone else?
  • 38 Answers
Did you open the lid? If you did and it still does not come to the load position then power off the printer and when you turn it back on the carriage should move across the machine at which point you will unplug it and then you will be able to move the carriage by hand to the position you need. It should move freely do not force it.
Posted on Nov 16, 2009
Ink cartridge in Z705 will not move to center of carriage for changing when top is lifted Even though the Belt is moving. Help !!!!!!!!!!!.. >:( :( :'(
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
I hope this helps.
Oct 24, 2011 | Lexmark PhotoJet Z705 InkJet Printer
Carriage for the ink cartridges is stuck, the carriage wont move to the middle so i can change the ink. i turned off the power & then turn it on , the carriage just move a little from the right and...
Aug 30, 2011 | Lexmark X2600 InkJet Printer
How do I change the ink cartridges on a lexmark 5495
Please follow the steps below on how to replace ink cartridge on the Lexmark X5495 printer:
  1. Make sure the printer is on.
  2. Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier latch to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Aug 14, 2011 | Lexmark X5470 All-In-One InkJet Printer
Have 5400- needs new black ink. How do I get to the instructions on this
You can purchase cartridges online from www.lexmark.com. Lexmark cartridges are also available in some large office supply stores.
To replace a cartridge on your printer, please follow the steps below:
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove your used cartridge.
4. Firmly insert your new cartridge.
5. Close the printer cover. Your printer will then ask you to align the cartridges.
Jul 27, 2011 | Lexmark X6570 InkJet Printer
Have an Epson NX200. Need to change ink cartridge but ink carrier will not position so I can open it.
usually you can move it manually with your hands .Turn off first your printer .once it turns off pull the carrier, pull the white tape gently to the center and just replace it ink cartridges there. Make sure its properly plug in .Once your done return the move the cartridge carrier manually from left to right 5x once your done you may now close the cover .(close it first ) And checked if its going to the center once you open the cover .
Hope it help thanks
May 26, 2011 | Epson Stylus NX200 Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
Do not know how to change ink cartridge x2650
Lift the scanner unit, and then press down on the cartridge carrier latch to raise the cartridge carrier lid. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
Remove the used print cartridge. Insert your new cartridges.
Apr 28, 2011 | Lexmark C533DN InkJet Printer
How to change printing cartridges
Here's how to change your cartridges: 1 Make sure the printer is on. 2 Lift the scanner unit. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. printmastert_25.jpg
3 Press down on the cartridge carrier latch to raise the cartridge carrier lid. printmastert_26.jpg
4 Remove the used print cartridge. Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge.
You may also refer to this link: How to Set Up the Lexmark X3600 or X4600 Series All-In-One
Apr 04, 2011 | Lexmark X3650 Printer
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The print cartridge carrier moves to the center and stops at the loading position. Grasp the tabs on the cartridge lids, and then lift the lids. Remove the used cartridges and install the new ones. Snap the lids closed and lower the scanner unit to close.
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source.
Hope this helps. Thanks.
Nov 22, 2010 | Lexmark X1240 All-In-One InkJet Printer
How do I manually center the ink cartridges on my A960 ?
The ink cartridge had jammed the carrier and prevented it from moving. I stuck my little finger in the bottom of the carrier, pushed the cartridge up a bit, freed the carrier and was able to move it manually. I replaced the cartridge and all the messages went away. The printer now works as it should. Must have been a bad cartridge.
Nov 10, 2008 | Dell A960 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
125 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
