Question about Toshiba Satellite A105 Notebook
Complete power failure
I own a toshiba u300 psu30c - tp208c and for some reason my laptop keeps losing all power whenever i press the power button... i've tried everything from unplugging for some odd seconds to trying only with the A/C plugged in to no avail... my laptop just won't power on at all
  • 458 Answers
First you need to check the fan/heatsink assembly, you might need to disassemble laptop to get to it.. but it needs to be cleaned, Clean the Heatsink Cooling Fins, and Clean the fan blades...
You next should check youe AC Adapter... Use a multimeter Hold the black test prod to the outside of the plug tip and put the red prod inside the plug tip - test for positive power... Slightly bend the cord near the tip of the AC Adapter when testing to see if there is a short in the cable..
If cord tests good, then you will need to check the DC Jack, this will also mean complete disassembly down to the motherboard and visually inspect the DC Jack...which quite possibly needs replacing.
Posted on Nov 15, 2009
My toshiba u300 has no sound
Here are some things you can try.
  • Make sure your speakers are not on mute and the volume is turned up.
  • Make sure nothing is plugged into your head phone jack.
  • Restart your computer.
If problems persist try performing a hard reset.
  1. Turn your computer off.
  2. Take the battery out.
  3. Hold the power button for 5 seconds.
  4. Replace the battery.
  5. Turn your computer back on.
Jun 12, 2011 | Toshiba Satellite U300-113 Laptop Charger...
Software problem
SMART is the system that monitors the health of a hard disk, in your case  it's close to complete failure. Follow immediately what that warning message says - copy all your data to some DVD's, replace the hd and reinstall.
Oct 31, 2009 | Toshiba Satellite U300-ST3091 Notebook
Start
Some missing data or corrupetd data, that is the cause, try to re-install your OS.
Toshiba Satellite P35-S611, power up failure.
Open the processor area located under your laptop. You can detached and re attached the processor, some sort of lose contact on pins. If same problem occur, your processor may burnt out. pm me caligayanstep@yahoo.com i will assist you remotely.
Oct 21, 2009 | Toshiba Satellite P35-S611 Notebook
Connection, via D-Link Dir 615, lost after restarting computer
Did you tell Vista to "automatically connect to XXXXX network whenever in range" ?
Oct 20, 2009 | D-Link DIR-615 Wireless Router
When connected to projector i could not get the display in not in the labtop and screen
If you have not done so already, hold down the "FN" key next to the spacebar and press the "F5" key. This sill cycle through the display options. Laptop only, External display only and both the laptop and external display.
May 17, 2009 | Toshiba Satellite U300-ST3091 Notebook
I cnt install win xp on my toshiba u300 laptop .....when i start installing window xp on my toshiba u300 there came that it didnt detect any hard drive on computer ... plz tell if u hav any solution 4...
If your laptop is like mine, it'll have a setting in Bios that needs to be changed in order to support XP.
In my laptop, there was a setting called Native SATA driver or something similar of that nature.
It took me quite some time to go through forums in order to find that out. Once that setting was changed, the notebook found the hard drive and I was able to install Windows XP.
Mar 27, 2009 | Toshiba Satellite U300-ST3091 Notebook
Toshiba Satellite laptop Model 035 S611
If it is completely frozen press and hold the power button (you will lose any unsaved work) it should turn off, failing that remove the power source.
May 18, 2008 | Toshiba Satellite P35-S611 Notebook
Failed Web Camera Installtion
Encountered error during installation of the device. The driver installation file for this device is missing a necessary entry.
Apr 04, 2008 | Cameras
Toshiba Satellite A105 Notebook Logo
106 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
