Question about HP Pavilion a1210n (ED895AA) PC Desktop
USB device malfunctioned on Windows XP Pro SP2
My USB device kept getting a "malfunctioned" message on Windows XP Pro SP2. I tried to reconnect using the other ports, adding a dword value, rebooting, boot in safe mode, but all didn't help.
    Problem Solver:
  • 11 Answers
Try to repair windows, only if you have tried more. like, restart the computer, or turn it off and unplug it, leaving it for a while without power, while is unplugged press the power button 2 times to get rid of the power that is on-board still. Also if you know you can jumper your motherboard to restart the boot system. any of these can help you
Posted on Nov 15, 2009
Kingston 2gb datatraveler malfunctioned
there is absolutely no problem in your pc .
your pen drive is faulty.
Feb 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Laptop does not recognize magellan 860t when connected to usb port Magellan POI file editor issues message "no unit detected".
assuming your using a known good usb cable, you need to use windows XP sp2 or greater to install any magellan. if you are using that os or greater, try a different usb port.
if that fails, restart the computer and try again.
you can also try and reset the 860 using the reset on the top and see if that will help.
if none of those work, turn the reset button to the off position till the 860 goes off then plug in the usb cable and restart the 860.
if your not using windows XP sp2 or greater, hopefully you have a friend that does.
Nov 09, 2009 | Magellan RoadMate 860T GPS Receiver
Hi, im using windows xp pro sp2 and hooking up a piano to usb. the piano comes with a special driver, but as soon as i hook it usb it installs a generic driver automatic. Then it doesnt let me "pick from a...
as for any usb device, the general rule is run/install first the driver program via the cd installation disk before plugging in the USB device. Try removing the Piano usb, restart the pc, install the cd driver, and plug in the piano.
Jul 14, 2009 | Microsoft Windows XP Professional With...
My computer which is running Windows XP pro 2002 does not recognize my San Disck cruzer 256 mb memory key. The light flashes upon inserting in to computer and then goes out and then I get message that CPU...
try to disconnect all usb devices and install it again to another port also try to install it on another PC if it workson another PC and yours not then try to remove ur O/S and install a good one like windows Xp SP2
Jun 15, 2009 | SanDisk 4GB microSD High Capacity Memory...
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
Via Vectro VT6212 adaptor not recognized by WindowsXP SP2
is the usb 2.0 card driver properly installed?,is there any conflict?
Feb 24, 2007 | VIA Vectro VT6212 (A62124) Serial Adapter
HP Pavilion a1210n (ED895AA) PC Desktop Logo
65 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
