Question about Garden
Have lanmower with peerless 6845-pg1 transmission. have lost most power. have replaced belt
  • 3 Answers
By "lost power" do you mean slower travel speed? Assuming your mower doesn't have an adjustment pulley, meaning a pulley with a bolt through it you loosen and move to replace the belt and put back in place and tighten the bolt once the belts replaced. Some do and this is where you adjust the drive belt's tension. Otherwise, when you depress the clutch pedal, underneath is a pulley or pulleys mounted on moveable plate. The plate pivots one way to put slack in the belt to disengage and the other way to tighten/engage the belt. I've seen them not fully pivot which doesn't completely tighten the belt allowing belt slippage and slower speeds. Use a spray lube on the pivot point (avoid getting it on the belt) and on spots where the plate looks to have rubbed against. This should let the plate to fully pivot again which will allow the belt to completely tighten, eliminating slippage, thus producing faster travel speed.
Posted on Dec 07, 2009
How do I install seal in the transaxle?
Require splitting the case if your trying to replace axle seals. Case is sealed with Permatex Ultra Grey sealant
Oct 16, 2014 | Craftsman Garden
Alko 700/620/600 mower brake problem with peerless 700 transmission
Hi, your problem is simple and is all to do with the brake you adjusted. Remove the two bolts, one either side of the brake adjuster, remove the brake assembly, remove clean and lubricate the two pins and the holes they slide in. Reassemble the brake assembly and adjust the centre nut so that the brake comes on and off. This should be about a quarter inch of travel on the short brake lever. Regards Phil.
Jul 23, 2012 | Garden
Murray Peerless transaxle slow forward speed. Drive belt was changed and linkages where adjusted. Very slow forward and no reverse.
I think the only logical conclusion is that your hydrostatic transmission is shot. If you know the model number, I think they
are stamped on the bottom, you can look over on ebay. There are some NOS vendors over there and they may have one. There are also mower junkyards around, believe it or not, and if you can find one you may find a serviceable replacement.
Sep 23, 2010 | Garden
Transmission is locked up.
Make sure all attachments are off the outside of the unit. If all bolts are out then if you have not try a chisel all the way around the case very carefully as it is usually stuck by the sealant that seals the unit.lol.donnyb60
Mar 23, 2009 | Mtd Garden
I have a peerless tub diverter and I need to replace it because it leaks. Where can I find a replacement unit?
the kit to rebuild the peerless diverter is very common. take the cartridge to any hardware store and ask the plumbing clerk to assist you in getting the correct kit. good luck
Jan 19, 2009 | Peerless Industries Peerless& Single...
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
