Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Firewire cables Does the cheaper firewire cables (4-pin to 6-pin) perform the same as the higher priced cables? What are the best brands to look for? Is the data and video transfer better with the higher priced cables? I would like to transfer family movies from a minDV camcorder (Sony) to my computer.
  • 4 Answers
I highly recommend that you avoid the cheapest cables. Generally speaking, they tend to fail at a much higher rate than cables in the mid to high cost range. The molded plugs crack, the end connectors become intermittent, and the wires inside the cable tend to "open" (come apart) when flexed or stored coiled too tightly. (All cables are best stored straight or, if need be, in a large loop).
Also, cheaper cables quite often have less "conductivity" and may be prone to have less "noise" (interference) suppression.
I assume your use is moderate at most (5-10 hours a week or less) in which case I beleive a mid-price cable--$25 to $35-- will work fine for you. Monster Cable is readily available online and in stores. Other brands usually have a selection of grades for the same length that you may need.
Posted on Jan 10, 2008
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
I can not download sony DCR-HC54E mini DV to PC, please assist me in details.
You require a firewire cable to connect to the PC then use Movie Maker to capture the footage.
Cameras use a 4 pin socket and computers can use 4, 6, or 9 pin sockets.
Determine which socket is on the trget computer and buy the necessary cable.
FYI: Most Laptops use 4 pin and most Desktops use 6 pin. Avoid adapters if possible.
For example; if your Desktop computer has a 6 pin socket you buy a 4 to 6 pin firewire cable. Firewire is also called iLink or IEEE 1394.
Feb 23, 2011 | Sony DCR-HC54E Mini DV Camcorder
Advice was given to me to buy firewire cable as my sony handycam DCR-TRV22E wont recognize by my mac OS X ver. 10.6.6? what type of firewire shld i buy?
I'm glad to provide the information about the required firewire cable.
All Sony Camcorders are having 4 pin firewire/i.LINK port.
You can purchase a Firewire cable depends upon the number of pins available on the firewire port on the Computer.
If you have 4 pin firewire port in the Computer, you can purchase a 4 to 4 pin Firewire cable.
If you have 6 pin Firewire port in your Computer, you can purchase 4 to 6 pin i.LINK cable.
In rare cases, it may also 4 to 9 pin.
Please refer the manual of your computer or contact apple to get the information about the number of pins available on the Computer.
You may also get back to me with the model # of the Computer so that I might be able to check the pin information.
Thanks for understanding.
If you need any further assistance, please let me know..
Feb 22, 2011 | Sony Handycam DCR-TRV22E Mini DV Digital...
Need adaptor for older Sony analog camcorder - CCD-TRV70 DC 6V
You need to get a Digital to Analogue converter such as the Canopus ADVC110 A/D Converter. (circa $225). There may be cheaper alternatives. (you might also be able to use a digital camcorder that has a built in Analogue to digital converter):
 Canopus 77010150100 ADVC110 Converter
The Canopus comes with a 6-pin firewire cable. Since your Dell Studio has a 4 pin Firewire (actually called iLink) you will also need a 6-pin to 4-pin cable or an adapter:
 Firewire 6-PIN To 4-PIN Cable
 Cables To Go - 27028 - Firewire 6-Pin Female 4-Pin Male Adapter
You hook your Sony up to the A/D converter with audio and video cables (usually supplied with your camcorder) and hook the converter to you Dell with a firewire cable. Then you capture the video using some video capture software. I don't know what comes with windows these days.
Jan 22, 2009 | Sony Handycam CCD-TRV308 Camcorder
I wish to transfer movies from a camcorder to my computer. My camera has a 4 pin connection. The computer specs state the firewire port is 4 pin but has a port the same size as a 6 pin. Can I use your 4...
First off thanks for choosing fixya.com
Since not all cables are made the same way it would be best to check the manual, or online documentation for your camera. The manufacturer probably makes a cable specifically for that camera. If the camera has a removable card such as SD or MMC you can purchase a generic card reader for your computer and simple transfer data using the card reader, In some cases this is cheaper due to the high cost of some USB/Firewire cables. Only use cables recommended by the manufacturer. This will not only ensure your warranty stays in tact but also makes sure you do not damage your camera or computer by using a wrong cable.
Hope this helps you.
Jei.
Dec 01, 2008 | Adesso ACCELL FIREWIRE GOLD 6PIN/6PIN 6FT...
How do i get my FA-66 to work via firewire?? please help!!!!!!!
u're probably trying to connect it with a 4 to 6 pins firewire cable to your laptop right?
if so, the laptop firewire connection is usually the small type (4 pins). this kind
of connection does not give Power to the firewire device.
u can buy a pcmcia card with 6pin firewire connections and usa a 6 to 6 firewire cable
and that will work. i hope. :)
Oct 06, 2008 | Edirol FA-66 Sound Card
Canon MV800 - FireWire connection
firewire is also called 1394 or dv port-card can always be added to older computer to support-cables are 4 pin to 4 pin or 4-6 pin-cam is always 4 pin -mac and most towers 6 pin-laptops are 4 pin-look for a port that looks like usb but has a trapezoid shape end
May 22, 2008 | Canon MV800i Mini DV Digital Camcorder
Firewire
Yes, you can capture camcorder video from a miniDV camcorder using a FireWire cable and video capture software. Your computer came pre-installed with Windows Movie Maker, or iMovie (if you are on a Mac).
FireWire, IEEE 1394 and iLink are all the same thing. There are 4 and 6 pin FireWire cords. My guess is that you need a 4pin to connect to your camcorder and a 6 pin to connect to your computer. But it all depends on what ports you have available.
You can get a FireWire cord for less than $10 at most computer electronics stores
Check out this FireWire guide for more information:
http://www.stashspace.com/video-editing/firewire-guide.stm
Mar 14, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
DV Out/In cable missing
You need a Firewire (also called IEEE1394) cable to transfer DV to your computer. I buy mine here, usually:
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10301
There are 4-pin, 6-pin, and 9-pin Firewire connectors. Virtually all camcorders sport the 4-pin variety. Most PC laptops do as well (if there's a built-in port) so for camcorder interface, you would need a 4-pin to 4-pin cable. Most PC desktops that support Firewire use the 6-pin cable, so you would buy a 6-pin to 4-pin cable to hook up to the camcorder. Some Apple Macintosh computers and high-end PCs may support an 9-pin port as well, which is the newer, faster version of Firewire, but offers no advantage when talking to a camcorder.
If you haven't used your computer with a Firewire device before, do make sure you have one. These are available as PCI cards, PCIexpress cards, PC cards, and ExpressPort cards. It's pretty common for a modern desktop PC to have one or two Firewire ports. They're not uncommon on laptops, but do check.
Jan 22, 2008 | JVC GR-DVM5 Mini DV Digital Camcorder
FireWire i.Link which cable?
teedoff1980,
You can buy the FireWire kit at your local electronics store or department. Some kits come with a FireWire cable with USB connectors, as well as "ends" for that cable that come in both 4 and 6-pin configurations. Make sure you ask the store rep and read the package to ensure you have the right ends. You can also buy cables that are already appropriately "ended".
Most cables are 6 pin and connect to the 4 pin port (with a 4 pin end)
Hope this helps :)
Jan 06, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
