Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Not drying. gas not lighting up. it looks like the glow plug not lighting up
  • 105 Answers
Is this a clothes dryer or fridge?
Posted on Nov 21, 2009
The Kenmore dry glow plug lights but the gas only comes on initially. After a few min the gas goes out and the plug glows periodically but no flame
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 27, 2011 | Kenmore Dryers
Glow plug gets red but oven will not ignite. Broiler ignites but has seperate glow plug.
Check to see if you are getting gas to the oven burner. If it will light with a match then look into adjustment of the flow plug, but if it won't light, then look at the gas valve or switch.
Jun 07, 2011 | Ovens
I replaced the timer and it still dosen't work and clothes don't get dry
you have to check the igniter fisrt, if your dryer is white you have a plug at the lower left corner, remove it,turn the dryer on and look for the igniter to glow. if you see no glow after 1 minute replace the igniter. if it glow and goes off and no gas is ignited then replace the coils.
Feb 13, 2011 | Roper RGX4634KQ Gas Dryer
Have frigidaire gas dryer that was drying yesterday but now it runs but will not heat or the gas will not turn on.
The ignitor could be burnt. When you start it very soon after it should try to ignite the fuel. Look and see if you can see the bright orange glow. If not it possible will be the ignitor is done. If it glows and no light, make sure the gas is on, If so possible gas valve issue.
Apr 04, 2010 | Dryers
My gas dryer is not heating up I checked to see if any flames is on when its running but its not coming on the timer is turning.what needs to change
All gas dryers have a gas module. The older models (very old) have a pilot light and the new ones have what is called a GLOW PLUG and it is made out of ceramic. If this glow plug is in any way broken, you will not have any heat. The GLOW PLUG is what comes on when you first turn the dryer on and it GLOWS until the gas module actually spits out a small amount of gas and an internal combustion occurs and the flames come on full power and this is what dries your clothes. If the GLOW PLUG is fine, then the gas module could be bad. ALSO, Always check for burnt wires and check any thermostats or fuses internally in the unit.
Nov 16, 2009 | Whirlpool Dryers
My Kenmore gas dryer runs but it does not dry.
Obviously make sure the gas supply valve is open and gas is going to the unit.
Then determine if the burner is lighting at all... there is a small plastic plug in the lower left of the front panel. If you remove this plug you can see the burner assembly.
When the drier powers up you should see a glow plug that gets red hot, then a click (the solenoid opening) then the burner should light and you should see a blue flame.
If this does not happen, the glow plug will go out and then in a minute or so, the process will start again with the glow plug and the click.
If this cycle repeats without ANY lighting of the burner, you need to replace the burner assembly and/or safety valve... send the model number and I'll show you the parts.
If the burner lights for a few seconds and then extinguishes, it is probably a faulty flame sensor, which is a probe extending into the path of the burner flame about in the middle of the burner assembly (It makes sure the flame is lit and if it doesn't get hot enough it closes the gas valve to avoid filling your laundry area with gas). You can try cleaning it, and then replacing it. Again if you give me the model # I can help you...
Oct 11, 2009 | Kenmore Dryers
Oven burner doesnt light
Doubt that the glow plug is bad. Gas only needs about 1100 degree F. to ignite using the glow plug method. It really seems as if there may be no gas getting to the burner. If there is no flame, you should be able to smell gas. If there is no gas smell, then I would look for the obvious such as: is the gas turned on?, Does the gas valve on the unit have a safety that is tripped? and so on. A new gas valve may be in order but make sure that it is receiving the proper voltage when the glow plug is on. Lastly, there may be a safety that is malfunctioning. If the unit does not light within a given time, the safety will "Lock Out" the unit so the place doesn't fill up with gas.
Hope this helps and good luck.
May 09, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
41 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
