Question about Sony Ericsson P910i Cellular Phone
Touchscreen failure... I can't use my phone's touchscreen...Everytime i use my pen in it,there's no response at all...
  • djjoy Feb 08, 2008
    unable to send thru bluetooth and cannot delete items from folder
Try to unfold the phone first
Posted on Jan 20, 2008
6ya staff
SOURCE:
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
Cant use touchscreen on my zte warp sequent phone
well you mean the screen is frozen up or not responsive to your touch? if so do a Hard reset and that will fix the issue the issue ,before doing it pull out the SD card.
May 06, 2013 | Boost Mobile ZTE Warp Sequent Touchscreen...
Touchscreen driver
You need to find out what Co. made the touchscreen for that model to see if they have updated touchscreen drivers for windows 8.
Sounds like your machine was intended for XP,
Feb 10, 2013 | Tablets & eReaders
Touchscreen not responsive
i never liked touch phone.. anyway goto nokia care shop nearby to you.
Nov 30, 2011 | Nokia Cell Phones
The touchscreen us not working at all, the other buttons work
Hello
Do not put lotion on your hands and do not touch the screen if your hands are wet. Any kind of moisture can affect the way the touchscreen operates. Moisture sometimes slows the response time from the screen to the operating system.
Check for a protective sheet on the screen. If there is some kind of a film or sheet on the touchscreen, the screen is likely not able to react to all of the sensitivities of the touch of a finger as it normally would.
If there is an application open and the touchscreen seems to not be working, simply close the application and retry it. A frozen application can usually be closed by pressing and holding on the circular button located just below the touchscreen.
Completely reset the phone by holding the "Home" button and the "Reset" button for a full 10 seconds until the phone resets.
THANK YOU FOR VISITING FIXYA
Mar 07, 2011 | Cell Phones
Touchscreen is broken
Hi,when a touch screen is broken, it makes the touch response not to function again.
You will need to replace the touchscreen sensor pad.
You can take it to a Skill- full personnel for assistance.
Take care.
Aug 30, 2010 | Samsung Jet S8000 Cell Phone
Xenon Touchscreen stopped working
There is no way. My touchscreen has stopped working several times and everytime fixes itself after a few hours. DO NOT let this phone ANYWHERE near moisture or water, the touch screen is very sensitive.
Jul 17, 2009 | LG Xenon GR500 Cell Phone
The touchscreen for my treo 600 does not work!!?
plz reset the mobile and go to settings /...u will find an option for pen maximisation .....it will resolve the issue
May 11, 2009 | Palm Treo 600 Handheld
Touchscreen...
go to phones setting & reset it. master reset code is 4 times zero (0000). If code dosent work then u have to unlock ur phone by box called Cruiser. If this does not work ither ur touch screen is damage or the s/w is curropted. U have to flash it
Jan 10, 2008 | Sony Ericsson P910i Cellular Phone
Sony Ericsson P910i Cellular Phone Logo
52 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Marvin
Marvin
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
