Question about Sport & Outdoor - Others
How do I reset the combination on my redhead 9L60. Too many people know the combo
2 Suggested Answers
joboo1
  • 257 Answers
SOURCE: get new combo on senry dial safe
Hi, There is only one way, and that is to send a letter with the serial number to Sentry and if the info matches who is supposed to own it, they will send you the factory default combo to open it. Good Luck!
Posted on Feb 14, 2009
How can I purchase a spotting scope manual for a Redhead Pursuit spotting scope?
Call your nearest Bass Pro shop. They may be able to arrange for you to get a manual.
Jul 20, 2014 | Redhead Pursuit (18-36x50)
Tsa002 change combination
Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
Jul 04, 2014 | Locks & Locksmithing
How do you reset the combination to a Ace Solid Brass Combination Padlocks
Open the lock, rotate the shackle180 deg, and push down.enter new combo, and rotate shackle back to normal position.
Mar 27, 2014 | Ace Hardware Ace Solid Brass Combination...
Can not unlock combination lock of 'jeep' suitcase. Initial combo was 0,0,0. How can I reset the combination ?
What you want to do is just keep tension on the shackle, or the part of the lock that would open. With tension on it start at the opposite end and turn the numbers. You will notice that it will get "stuck" on a specific number. That's the last number in the combo. Turn the middle number till it sticks. Then the last. Tadaa! Hopethishelps
Feb 04, 2013 | Locks & Locksmithing
How do change the combination on Brinks Home security saft Model 5074 serial #120.0401A
How do I change the electronic keypad combination on a Brinks Model 5074? This isn't quantum physics, but I sure can't figure it out. Can anyone provide the proper sequence to reset the combination? Thank you.
Sep 01, 2010 | Sentry Fireproof Safe
I lost the instructions and don't know how to unlock using "original code" and how to create a new code
try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
Get new combo on senry dial safe
Feb 14, 2009 | Sentry Fireproof Safe
Resetting combination bike lock
Try rotating locking device 180 degrees and hold it down and set combo to 0000, then let up on locking bar. That should clear the old combo. To reset, rotate the device 180 degrees and hold down while inserting your new 4 digit code and then release it.
Jan 31, 2009 | Mongoose Toys
TV Stuck in VCR mode
I used code 191 for my combo unit
Jul 09, 2008 | Daewoo GB-20H4T2 20 in. TV/VCR Combo
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Sport & Outdoor - Others Logo
52 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
