Question about Dishwashers
Dishwasher is leaking in front on the floor during the final rinse cycle. we opened the kick plate but did not find any water farther back. We also checked around the seal of the door . did not find any leakage.
  • 460 Answers
Try a different detergent like cascade..
Posted on Nov 15, 2009
Some water is leaking under the dishwasher and on the kitchen floor during the end of the wash cycle.
Does it leak during pump-out only?
If so , must be drain hose .To see everything,remove kick plate to isolate leak. Check hose connections. Fill and drain and observe.Or run a whole cycle with kick plate off to find leak.
Good luck
Aug 15, 2011 | Kenmore 24 in. 15689 Built-in Dishwasher
I have an amana dishwasher and it wont fill with water
Sounds like you need a dishwasher water inlet valve. This part allows water to flow during the wash and rinse cycles. This part is electrical so unplug the appliance before attempting repair. Part cost about $25. It is located behind the bottom kick plate. Two screws and two slip on wire connectors and you are done.
Jan 16, 2010 | Amana Dishwashers
My d1716 continues to run, but does not move forward in the cycle. I can even open the door and it continues running. If I didn't unplug it, the motor would likely burn out. Do I need a new dial? Thanks.
Hi
I would suggest that your flood switch has been activated. There is a float on the bottom plate or base plate of the machine. If there is a water leak, the float rises and triggers the flood switch.
Once the switch has been activated, the machine will go on a continous pump.
Disconnect the power and the hoses from the machine. Pull the machine out and lay it on its back.
If there has been a leak, you will notice water pouring out the back.
See if you can open the bottom plate, and reset the floater and flood switch. Sometimes you can access this by openning the front kick plate or front bottom plate.
Try the machine again. Leave the front bottom plate out and look into the bottom as the machine is working. If you have a water leak, this will happen again and you may be able to notice where the leak is from.
Be carful not to touch the live wiring while you are monitoring the machine.
Good luck
Ash
Nov 20, 2009 | Asko D1716 Built-in Dishwasher
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Fills up the first tim but not after for the rest of the cycle.
it sounds like the fill float could be stuck in the full position and sticks during the rinse cycle check the float it is in the front to the left or right it looks like a bell, move it up and down and if necessary remove the front kick plate(s) and observe the mechanism as you move it up and down to ensure it is not hanging up.
Sep 11, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
Dishwasher leaks during rinse cycle
it sounds like you need to adjust the door latch so that the top of the door will close tighter. when in the rinse cycle try pushing door at top to see if leak stops. if that doesn't let you know something then you got me. you have changed all that i can think of. Good luck
May 01, 2009 | Dishwashers
Leaks when being unloaded
I may not have the full solution here, but to avoid (expensive) sub-floor damage, I recommend you do the following.  Assuming that the water is not coming from some dripping between the opened door at the hinge....
-Remove the kick plate that is in the bottom, front of the dishwasher.
Use a flashlight to look for wet flooring.  Run the dishwasher with the kick plate removed, watching for leaks/dripping.  It is possible for a leak to seep under the floor.  If leaking is found, do not ignore it.  Pull the dishwasher, fix the leak or replace the dishwasher.  Remove the first layer of sub-floor under the dishwasher, looking for deeper damage.
You should probably do the same with the carpeted area.  Pull the carpet back and decide if the sub-floor needs to be replaced.  A flooring expert should probably inspect.
Sorry to be such an alarmist, but I have been around floor damage that was unnoticed and ignored.
Apr 14, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Whirlpool dishwasher leaks everywhere
CHECK YOUR HOSES FOR CRACKS. BE SURE THEY ARE ATTACHED SECURELY TO THE PUMP OULET.
THERE IS ALSO A BLACK HOSE FROM THE VALVE THAT GOES UP THE LEFT SIDE TO A VACUUM BREAK ON THE SIDE OF THE TUB. BE SURE THE HOSE HASN'T BEEN DAMAGED OR DISCONNECTED. IF THERE IS SUFFICIENT SUPPLY HOSE, PULL THE DISHWASHER OUT OF IT'S INSTALLATION AND TURN IT ON. WATCH FOR WATER DRIPPING ON THE FLOOR AND TRACE IT BACK TO FIND THE PROBLEM.
Mar 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
Owen Barnes
