Question about Ricoh 3310LE Copier
Erorr code c 62
I have ricoh ft5733 and it is blinking c 62 erorr code so what can i do for it
  • 541 Answers
Error 62 means sorter is not closed . open and close your sort, the part on the left with the bins. it has a front cover and a relase that allows it to slide left away from the machin. open and close these and see what happens.
Posted on Oct 11, 2009
    President:
  • 4,402 Answers
Error code means the POP server cannot be found. Confirm the IP address of the POP server is entered correctly in the machine. If you are not receiving e-mail or using the POP server enter the loop back address, 127.0.0.1.Press user tools, then 2, then pound (#.)
  • Select 1 for system, scroll down to item 10 (network) and press "ok."
  • Select 1 for TCP/IP. Then scroll to POP server.
  • Enter the address and press "ok."
  • Exit User Tools
Posted on Jan 10, 2008
Erorr problem code sc 336
No such error code. There is a 363. That is for a bad yellow developer unit.
Sep 09, 2014 | Ricoh Aficio Mpc 3500 Color Copier
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
Ricoh Aficio Sg 3110Dn erorr code sc (20200)
Sometimes when you get an error on a printer you can just press the stop button or some have a clear button to get rid of the error code.
If that doesn't work, try unplugging the printer from the outlet for a few seconds then plug back in to reset the error code.
Dec 05, 2013 | Ricoh Aficio Sg 3110Dn - Printer - Color -...
Ricoh FT5733 what is code E63?
Exhaust blower motor error. Common problem for these older machines and quite a pain in the neck to replace. Not something that could be explained through this forum.
Mar 08, 2011 | Ricoh Office Equipment & Supplies
HI WHAT IS CODE 62 AS AN ERORR MESSAGE
Code 62 error message on this washer means that the "drain pump" current exceeds what it should be. Either the pump is faulty or (more expensive) the motor controller is faulty. Pump about $50.00, controller $300. Best of luck. 2TRP
Feb 22, 2009 | Fisher and Paykel Washing Machines
NEED SERVICE MANUAL FOR RICOH FT5733
You can go to; www.user-manuals.com . They have it for sale $14.99.
You could also go to; www.gestetnerusa.com and cross check the model, they may have a free download PDF.
Ricoh is the parent company with Savin, Lanier and Gestetner under them.
Dec 31, 2008 | Ricoh Office Equipment & Supplies
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
RICOH 2027 SC792 ERORR CODE
This seems to be a finisher communication error. If you unit has a finisher on it check the connector.
May 26, 2008 | Ricoh Aficio 2027 All-In-One Laser Printer
Ricoh 3310LE Copier Logo
185 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
