Question about Eureka Enviro Steamer 310 Stick Vacuum
Steamer trips circuit when pluggig in - Eureka Enviro Steamer 310 Stick Vacuum
  • 460 Answers
This product is shorted. check if it is still under warranty..and have it repaired.
Posted on Nov 15, 2009
Rainbow pn-2e circuit breaker
The circuit breaker could be defective.
Aug 19, 2016 | Rainbow E series Canister Wet/Dry Vacuum
No power
see this step: God bless you
check.gif Check the house circuit breaker to see if it tripped?
Click here if you own a Vacuflo Central Vacuum Unit continuously trips your circuit breaker
If it is tripped, then turn off your central vacuum unit and reset the circuit breaker. Then turn the central vacuum unit on. If the circuit breaker trips again, then refer to the following:
check.gifDetermine if the house circuit your vacuum unit is on has sufficient voltage required.
check.gifIf your unit has a reset button, press the button and try again.
check.gifCross the low voltage wire from the relay at the unit with a small screw driver. If you hear the relay click you need to replace your motor.
Click here to view Central Vacuum Motors
Click here to view How to replace a motor
If you do not hear a click, then you need to replace your relay.
Jul 24, 2012 | Bissell 21K3 CleanView Helix Bagless...
Circuit breaker trips with shark steam mop
figure out how many amps your circuit breaker is
then figure out what appliances are running from that circuit
if you are under...then your mop is faulty
May 25, 2012 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Why would appliances trip breaker
Without seeing it it is impossible to be 100% sure but generally this will indicate a short in the motor. If it is within warranty I would return it to place of purchase for replacement. I work as a service tech for vacuumspot and if it were out of warranty I would probably replace it as steam cleaners are a pain to repair (generally)
May 22, 2012 | Scunci SS1000 Handheld Steam Cleaner
My series 90L suddenly stopped and would not restart. A check of the circuit breaker found it tripped. The vac would not turn on when the circuit breaker reset. Using an AC voltage sensor indicated power...
From the description it sounds as if there had to be a short in the unit somewhere. This is what would have tripped the breaker. the fact that it is not tripping could mean that there is a fusible link or that the wires or whatever have burned back from the short, and are no longer shorting out.
Jul 04, 2011 | Vacuums
Trips circuit breaker will not come on
Remove from the plug and then push to reset.If the breaker trips off again the fault can be due to high current factor in the motor.
Release motor circuit to test.
Sep 08, 2010 | Oreck XL Ultra Bagged Upright Vacuum
My Sebo hoover trips the house mains sockets every time I switch it on, yet doesn't trip the kitchen mains. Have replaced filters/bag to reduce load but still no good. What should I be investigating in the...
It sounds like your vacuum is fine if it works when plugged in the kitchen outlet. It is tripping the breaker switch in the other room because the circuit is overloaded (too many things plugged in this circuit). Try unplugging some things in that room and try your vacuum again.
If it only trips when using one particular outlet, then the outlet should be replaced. I would recommend having an electrician check your wiring out.
Hope this helps
Feb 01, 2010 | Sebo Air Belt C2.1 Bagged Canister Vacuum
When turning on the unit blows the fuse every time
you need a 60amp to run this have a quilified elec in stall
Feb 12, 2009 | Polti Vacuums
Eureka Enviro Steamer 310 Stick Vacuum Logo
145 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
