Question about Makita Garden
Not happy with how long my 18v lithium batteries have lasted ,Who do i contact as my 12 month guarantee is up, and screw fix wont replace them.
  • paulhirstcar Nov 15, 2009
    thank you very much hope i have as much luck as you!
  • 8,197 Answers
To make a complaint you need to contact Makita at link below. If you are nice to them and tell them the problem they will replace the batteries for free. They did it with me 2 years ago.
Here is the link.
http://www.makita.co.jp/global/network/united_states.html
Good Luck
Posted on Nov 15, 2009
I purchased a Ryobi drill with Lithium batteries (Large/with gauge, small without gauge) in June 2009. The large battery lasted about 3 months and started holding less and less charge (yellow, then red on...
Batteries must be completely dead before recharging or battery life is shortened.large battery is probably defective contact Ryobi to replace battery they while probably send you new batteries for free if you tell them you are going to stop buy their products.Tell them about both batteries they will probably replace both for no charge
Jun 12, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Makita 18v lith ion battery not charging
Push the battery in and out while pressing the trigger on the the drill to see if there is a loose connection here.
Check the battery terminals inside the drill and the battery terminals .These sometimes become tarnished and don't make contact. Clean with very fine sandpaper or wire wool. Apply light pressure as otherwise you may remove the chrome or nickel plating on the contacts.
Apr 04, 2011 | Makita BDF452HW 18V Cordless Lxt Lithium...
Ryobi Two 18V Lithium-Ion Batteries + Lithium-Ion Charger I can't get these to work! The charger does what it should but when I have a steady green light the batteries do not power my drill, when I...
You are the thrid person in the last couple of days with this same problem and i check who was posting the problems all differant people all RYOBI 18V lithium-ion batterys and they all got them for christmas. SOMETHING is not right there is now warranty on the batterys but there is one on faulty workmenship there must be a problem with this type of battery good luck
Jan 16, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
I just bought a combo 18V Ryobi blower P2102 and trimmer P2002 which also came with a charger P113 and Ryobi lithium battery. I charged the 18V lithium P104 battery 48WH till light turned solid green on...
The battery will power your equipment for 30 to 45 minutes, that is normal. What you're thinking of is the lifespan of a lithium battery. It with your battery will last 10 times longer than a regular NiCad battery. So you will be able to charge the battery and use it Hundreds of times before the Battery Life is depleted. Sounds like it's working as designed
May 05, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
How do you take apart a ryobi lithium 18v one battery
This applies to Li-ion. NiCd is probably somewhat different.
Unscrew four security screws on the bottom of the battery. If you don't have the right bit you can grind down the center pins in the screw heads and use a T15 bit.
Unscrew the hex-head screw in the center of the protruding post at the top of the battery. It may be non-standard in size but a small metric hex key wrench works if you are gentle. The four corners of the battery cover should be loose now.
There are still two plastic clips holding the top cover to the main unit near the centers of the long dimensions. Gently push a knife blade into the crack between bottom and top to release the clip on each side.
As you lift the top cover off you should push down on the contacts near the top of the post so you don't pull on the attaching wires. Eventually the contacts should pop free and the top cover detaches.
Detach the wiring harness for the status LED from the circuit board. You can now remove the combined circuit board and battery pack from the lower case.
Six screws attach the circuit board to the battery assembly, along with several solder connections, but you probably don't need to go this far. You can now test and possibly replace individual cells.
Oct 07, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
I have purchased three milwaukee screw guns in the past year and a half and all four of my batteries will not charge. when my first set stopped working i had to purchased another screw gun and within six...
The same thing happened to me. There is normally a 2 year warranty on the batteries from Milwaukee. You can't return them to the Home Depot, you have to send them back via a local repair center.
You won't be able to exchange the batteries at the repair center. The repair center sends them back to Milwaukee and Milwaukee will send replacement batteries. You will probably be able to find the closest repair center on line.
Sep 15, 2010 | Milwaukee Tool Garden
Both lithium ion 18v batteries for my Ridgid drill just up and died I've been told they are guaranteed for life but Home Depot is too dumb to find out. do you know if they are? and how do I get them...
Go to this website.
http://www.ridgid.com/Tools/Support/EN/index.htm
You can locate your nearest service center and if necessary contact them for more information.
Oct 29, 2009 | Ridgid 18v Impact Driver Rigid R842301
Charging problem
Battery defective. Seek replacement.
Dec 19, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Garden Logo
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
