Question about Philips Magnavox DVD/VCR Dual Player
Phillips magnavox TV vcr combo shuts off after 5 seconds
I have a phillips magnavox TV vcr combo and when i turn it on the VCR area makes a low pitch churning noise and then the TV turns off within 5-6 seconds... its ten yrs old now..
any ideas?
SOURCE: free download user manual
i have Philips Magnavox MWD 200G model dvd player purchased in usa and put to use in India.it was rep[aired due to high voltage.later it is showing disc error for any cd or dvd whilke playing and indicvates that the play back feature nay not be available on this disc.but it plays Fuji Film DVD R.please advise me how can i solve the issue for playing the other cds or dvds
Posted on Mar 31, 2008
SOURCE: DVD player wont show picture
take the dvd out and hold the stop button on the dvd player for 5 sec (not the remote) the dvd player and that will work
Posted on May 20, 2008
SOURCE: dvd door won't open
Mine just did the same thing about 1/2 hour ago. Found this site and tried advice of gopackgo - worked perfectly!
Posted on May 26, 2008
SOURCE: DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Posted on Sep 14, 2008
salsaurbana
  • 56 Answers
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Posted on Nov 19, 2008
Need code for magnavox tv urc-4021boo
Hi, the codes you have requested;
Magnavox - 0054, 0706, 0030, 1454, 1254
Instructions to program code:
1. Turn on a desired device (e.g.,VCR or DVD player) and, if applicable, insert media (e.g., cassette or disc). NOTE: Please read steps 2 through 4 completely before proceeding. Highlight or write down the codes and device you wish to program before starting step 2.
2. On the remote control,press a device key once (i.e., VCR/PVR, DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press VCR/PVR once.After programming a VCR Combo device, you will be able to control channel selection, volume, and VCR functions. NOTE: To program control of a DVD Player,DVD Player/VCR Combo, or TV/DVD Player Combo, press DVD once.After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions. NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR) Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR) Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,then release SET.
4. Use the Manufacturer's Codes (starting on page 18) to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice. NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
the same code again.
5. Aim the remote control at the device and press POWER once.The device should turn off. If it does not, repeat steps 2 through 5, trying each code for your brand until you find one that works.
Feb 12, 2011 | One For All URC-4021 Remote Control
Progam phillips RC144 remote for verizon fios
the remotes usually to program combos ...but you may want to try the dvd ...and vcr codes ...as well
May 22, 2010 | Philips 19MDTR20/99 19 in. TV/VCR/DVD...
I need codes for univ.vcr.dvd.combo(Magnavox) Please
0456 [0914 0286] [0969 0286] the codes in the boxes are as follows the first is for dvd the second is vcr
Feb 18, 2009 | Philips Magnavox Learning Universal Remote
TV SCREEN IS JUST A BLUE PICTURE,BUT HAS SOUND
Hi and welcome to FixYa,
Offhand it would appear that the VCR section of the combo unit would require a bit of cleaning. Specifically, head cleaning. The easiest approach is to use a VHS tape head cleaner.
The other post of "tv turns on then 5 seconds later shuts off" would be the auto-protect kicking in. This indicates that a likely hardware fault exists. Try to initially reset the unit by unplugging from the mains for an extended period. Otherwise it would require opening the unit for voltage measurement/diagnosis.
Pls post back updates. Good luck and thank you for using FixYa.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
Phillips magnavox tv/vcr combo need codes to program remote
most universal remote controls will not operate the combo type units. Contact www.remotes.com for a repoacement remote.
Nov 24, 2008 | RCA Universal Remote Control
TV shuts off in 5 seconds
El problema es la casetera esta fuera de tiempo probablemente necesita cambio de la banda del carro.
Oct 23, 2006 | Emerson EWC1304 13 in. TV/VCR Combo
Tv shuts off after5 seconds
I,m sorry if not help you, but some those combo system when the Vcr have problem or stuck it shuts down, then you have to fix the Vcr frist. zcheck if the Vcr is ok. Aleixo
Aug 29, 2006 | eVision EC720E 20 in. TV/VCR/DVD Combo
Philips Magnavox DVD/VCR Dual Player Logo
163 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
