Question about Canon LaserBase MF5750 All-In-One Printer
Canon MF5750 Printer won't print. It says document is in queue but nothing happening. There are no other documents listed to print. I've tried unplugging and re-plugging and re-starting my computer. The use printer offline tab is selected. When I uncheck the use printer offline, and try to print, it comes up with message saying that there is a printer error and it doesn't print. What is the use printer offline tab? Many thanks
IB4G2008
  • 3587 Answers
SOURCE: Canon Pixma MP150 service error 5100
sounds like an engine failure..from that code..is this under warranty, by chance?
Posted on Mar 25, 2008
SOURCE: unable to clear printer queue
I had a related problem. Couldn't delete a job from the queue nohow. I wound up deleting various processes (CTRL ALT DEL PROCESSES tab) and it cleared it.
Posted on Apr 02, 2008
  • 62 Answers
SOURCE: printer document in queue will not delete
1. First, try turning printer off and on.
2. Next, on the computer side, this is how you manually clear the printer queue.
1. Go to Start, Control Panel and Administrative Tools. Double click on Services icon.
2. Scroll down to the Print Spooler service and right click on itand select Stop. In order to do this, you need to be logged in asAdministrator. At this point, no one will be able to print anything onany of the printers that are being hosted on this server.
3. Next you need to go to the following directory: C:WINDOWSSystem32spoolPRINTERS.Delete all the files in this folder. This will clear all print queues(it’s a good idea to first make sure there are no other print jobsbeing processed on any of the other printers on the server becausedoing this step will delete those jobs also)
4. Now you can go back to the Services console and right-click and choose Start for the Print Spooler service!
You can also go to a command prompt and type net stop spooler or net start spooler to start and stop the service.
I hope this helps. If you have more questions, let me know.
Posted on Jan 09, 2009
  • 684 Answers
SOURCE: Document in queue won't print.
In this case what i would request u to do is:
1. Let the Printer be Connected to the Computer......
2. Click on start then Click on Run or If Windows Vista Type Services.msc Under the Run Window if XP,Under Start Search if Vista.......
3. On that Services Local Window u need to find Print Spooler just Double Click on that and Click on Stop..........
4. Now let that Window still be Open now click on that start Menu Click on Run If XP........
Type in "Spool" and Click Ok...........
5. Double Click on Printers and Delete Each and Every File Inside the Printers Folder...........
6. Now Close this Window and now u will be back to the Print Spooler Window now u can click on Start under the Print Spooler....
Now Try to Print Will Work Fine....................
Good Luck :)
Posted on Mar 04, 2009
SOURCE: error 306 is happening each time i try to print document.
I reloaded the printer driver and it worked again.
Posted on Mar 31, 2009
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
Cannot remove print que
Hello billpat281 ,
under Win XP :
go to start \ settings \ printers and faxes , select the jobs , clic on documents and cancel .
under Win 7 :
go to start \ devices and printers . Right clic on the printer , select open \ documents in queue \ select documents and cancel
Regards ,
fanaudi
Mar 05, 2011 | Canon imageCLASS MF5750 All-In-One Laser...
Why would my Canon IP4000 Printer stop printing documents; however, it will print perfectly if I use the PRINTER PREFERENCES test printing (Windows7)?
Try going to control panel, printers, and check if it says your printer is ready to print..... also right-click on your printer and click cancel all documents.... It should clear the queue, often printers won't print because there are too many documents in queue and I guess it just freezes up.... Hope this helps :)
Jan 11, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Check document, however there is no document to
check document on your canon ImageClass means that you need to check the ADF (Automatic Document Feeder) the feeder on the top of your printer. open it check for any paper inside .. if nothing turn off the printer and unplug from the wall.. wait for 30 seconds plug back in the power plug and turn back on.. let me know
Mar 31, 2010 | Canon imageCLASS MF5750 All-In-One Laser...
Printer wont print. help!!
Hi albookristin
I believe evrytime you tried to print, they all lined up in a queue for printing. If that is the case, you have to delete everything in the queue
Right click on the printer folder, look under documents, and see there are documents listed. If there are few, delete all of them. In some cases, you may have to print one at a time.
After doing all that, try to print a document. For test purposes type a one line document and try to print it.
Hope this will work for you.
Have a good day
luciana44
Nov 15, 2009 | Lexmark X2500 All-In-One Printer
DOES NOT PRINT ALL OF A SUDDEN STOPPED PRINTING AFTER RAN OUTOF OF PAPER.PUT IN MORE PAPER, PRESSED "PRINT" NOTHING HAPPEN HP S
Hi dep209
Clear all the documents in the printer queue. To do this go to the printer folder.
You can do this going to the Control Panel
Click on Printers
Click on the name of your printer to open the folder
If few documents are listed there cancel all of them.
Then turn the printer of and on again
Now try to print
Hope this will help you.
luciana44
Oct 04, 2009 | HP Office Equipment & Supplies
Printer stopped working
Turn printer on and off if that doesnt work then ust restart, sometimes things get stuck in the queue.
Apr 24, 2009 | Lexmark X1150 All-In-One InkJet Printer
Printing error
From your start menu, go to printers and faxes area. When this opens do you see your printer listed? Is it greyed out at all or maybe listed as offline? How are you connected tot he computer? Network, USB, or parallel port connection? If you see your printer listed and it has no other duplicate listings, right click the printer and go to properties, then choose the Ports tab. Verify here that the port selected witha check mark corresponds with your connection method. Example: If you are connected through USB, your selected port should say USB. Sometimes DOT4 ports will work for USB connections too. If you see this option, you can select it and hit apply to try it out. Try to print a test page after each applied change. Also, make sure that print jobs haven't built up in your queue by double-clicking your printer icon. If there is a queue of failed print jobs, select them and cancel. This might take a moment to complete. If your printer icon is greyed out, right-click it and un-choose the work-offline option and try it.
Mar 27, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Printer not printing
Go to the printer properties and make sure there is not a previous print job. Cancel all print jobs. Then send a test print to the printer.
Mar 27, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Canon LaserBase MF5750 All-In-One Printer Logo
155 people viewed this question
old marine
old marine
