Question about Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist
Cant remove the fan from the ceiling and the top ring wont turn
The top skinny ring that is made of plastic is the one that needs to turn. The metal bell shaped piece does not turn. My plastic ring would not turn either. I took a flat blade screwdriver and stuck it between the plastic ring and metal bell shaped piece. I gently pryed the plastic ring away from the bell shaped piece. The plastic ring has 4 screws that hold it in place, they are at the 8 oclock, 10 oclock, 2 and 4 oclock positions. The ring has to be turned counter-clockwise when looking up at the fan from underneath. Once the ring is off take the 4 screws out and the fan will come down.
Posted on Nov 15, 2009
  • steveocker Nov 15, 2009
    I had to pry the plastic ring away from the bell shaped metal piece. My plastic ring would not turn. The ring has to turn counter-clockwise when looking up at the fan. There are 4 screws that hold the plastic ring in place, at the 8, 10, 2 and 4 oclock positions.
I need to remove my hunter louden flush mount ceiling fan. There are no screws.
Good choice getting rid of that fan. The housing probably twist off. Could also have a ring at top next to ceiling that covers the screws at top. Just twist & pull down.
Oct 01, 2014 | Hunter Dryers
How do you remove a canopy cover from a Hampton Bay fan?
Turn off the circuit breaker supplying power to the ceiling fan. The circuit breaker is in your home electrical box and may control more than just the ceiling fan. Place a stepladder under the Hampton Bay fan.
Remove the light bulbs and light covers from the fixture, if you have a light assembly on your ceiling fan. Remove the screws securing the light assembly housing to the fan with a Phillips screwdriver. Lower the light assembly, and hold it in one hand.
Twist counterclockwise the wire nuts securing the wires for the ceiling fan and light assembly, using your free hand to separate the wires. Lower the light assembly from the fan and set it in a safe place.
Turn the screws securing the fan blades to the unit with a Phillips screwdriver. Remove the blades from the fan and set them aside. Find the screws securing the canopy to the ceiling mounting plate. Loosen the screws two complete revolutions. Turn the canopy counterclockwise and unhook it from the screws. Slide the canopy over the fan motor housing and away from the fan.
Ask a helper to hold the fan motor housing if you have a Hampton Bay fan with a down rod. Slide the canopy over the down rod until it rests on top of the motor housing. Disconnect the fan wires from the ceiling wires, twisting the plastic wire caps counterclockwise. Slide the hangar ball, at the top of the down rod, out of the mounting bracket. Slide the canopy over the top of the down rod to remove it from the fan.
Regards
Sep 28, 2011 | Dryers
Trying to remove the Hunter Stratford II 52" ceiling fan. The canopy ring rotates approximately 1/4 turn but does not release.
http://www.hunterfan.com/uploadedfiles/Support/Owner_Manuals/41803.pdf
Page 8 of the model 20761 Hunter ceiling fan shows how to remove the canopy trim ring. Ours had double stick tape holding the brushed nickel to a plastic trim ring. Dropped it, then squeezed the plastic ring.
Sep 19, 2011 | Hunter 20761 52'' The Stratford II Brushed...
Trying to remove a ceiling fan Hampton Bay model C 542 MP (CH) PBL . its flush mounted and cant get to mounting bracket.
Look for 2 to 3 screws at the top edge of the fan's ceiling cowl. Remove those and the ceiling cowl can be sled down, which will expose the the ceiling mounting bracket . They are fairly small head screws, so look carefully for them.
Hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Heating & Cooling
I can't find any mounting screws or bolts on the ceiling fan motor assembly. How do I remove it from the ceiling?
Yopu first need to drop the canopy co0ver from the ceiling mount. The cover may have screws at the very top edge. It may have screws at the bottom plate. It may have a decorative plastic ring at the very top that is conceling the mounting screws. You should be able to twist the plastic ring in an unscrewing motion and pull down to remove it.
Mar 10, 2010 | Hampton Bay 24750 Huntington III Ceiling...
How do you remove plate to remove entire fan from ceiling. Very difficult to remove.
If you are talking about the 1/2 inch ring buy the ceiling you just need to turn it clock wise or counter clock wist a 1/2 inch to remove. then you will see the screws behind it to remove fan from ceiling mount.
I hope this helps you
Sep 25, 2009 | Hampton Bay 46056 Callaway II Ceiling Fan
Access for disassembly
the vanity ring usuallu comes off one of two ways.
It may be held on with 1 or 2 small screws.When you loosen the screws you can turn the ring a little bit and it comes off. Sometimes you have to remove the screws and the ring will come off.
The 2nd method requires turning the ring counterclockwise and it comes off. If this is the way yours comes off, you can usually see 2 dimples on the top of the ring that fit into matching slots.
Oct 14, 2008 | Hunter "Lexus" Traditional 52" Ceiling Fan...
Ceiling fan
There's a rubber circle that is the damper between the blades and the motor shaft that rotates. The circle has spokes connecting the outer ring, which the blades screw into, to the inner ring which attaches to the shaft and holds it. If the spokes break you get the symptoms you describe, motor hums but no rotation, but blades can turn manually if you hand turn them them. If this is the case you need to remove and replace the blade mounting ring/damper. (About 25 bucks online)
Apr 27, 2006 | Hunter Sontera 52" Ceiling Fan with...
Hampton Bay 54 In. 5-Blade Fan, Chestnut, Autumn Mist Logo
112 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
