Question about HP 290563-B21 Network Adapter
My wireless adapter does not detect any reception from the router. i have another laptop at home that could easily detect reception from the router. what should i do?
    Problem Solver:
  • 6 Answers
Hey, Go to the manufactures web page and download the latest drivers for you wireless card, also please make sure your antenna is firmlay attached at the back.
Good Luck.
Posted on Jan 25, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 62 Answers
Since the laptop is connecting to the router and is having the internet access as well then clearly the problem is with the adapter or with the pc using the adapter.
Following steps can be considered :-
1)If the PC is using OS as windows XP then , click on start menu and then go to control panel and then open network connections from there.
2)Under network connections an option for wireless connection exist , right click on that option and then click on properties.
3)Under wireless network connection properties there are three tabs general , wireless network and advanced.
4)Left click on wireless network tab and check the box which says use windows to configure my wireless setting's and click OK at the bottom.
5)Then , Right click again on wireless network connection and then left click on view available wireless network.
6)List of available networks will be there , select the network you use and try connecting to it , if it gets connected then the internet access will be there.
Posted on Nov 19, 2009
Network adapter hp6505f
If your computer has a wireless network adapter, Windows will automatically detect wireless networks in range of your computer. You can see a list of wireless networks that Windows has detected in Connect to a Network.
  • Open Connect to a Network by clicking the network icon (eff2d36c-9e0d-4d1a-9859-3af14fa4ccfc_73.jpg or da12251d-1e9a-4032-afae-009876c6c5a3_80.jpg) in the notification area.
If Windows doesn't detect a network that you think is in range of your computer, it could be because of one of the following reasons:
  • The wireless switch on your computer is turned off.
    Many laptops have a wireless switch on the front or side of the computer. If your computer has a switch, make sure it's turned on. Some computers also use a function key combination to turn the switch on or off. Check the information that came with your computer for details on locating the wireless switch.
  • Your computer is too far from the wireless router or access point.
    Move your computer closer to the router or access point. If the computer is portable, try moving it around to determine the range of the wireless signal and the best place to use the computer.
    If you can't get closer to the router or access point, consider buying and installing an external antenna for your wireless network adapter. Many wireless network adapters are set up so that you can attach an external antenna to them, which provides better reception than a built-in antenna. Check the information that came with your wireless network adapter to see if you can install an additional antenna.
  • The wireless router or access point is turned off or isn't working properly.
    There are two things to try:
    • Make sure the router or access point is turned on and that the wireless signal light is illuminated.
    • Reset the router or access point by unplugging it, waiting at least 10 seconds, and then plugging it back in.
Sep 10, 2012 | NEC Computers & Internet
My HP Probook 4720S has a very wierd problem. The wireless card seems to be working properly, and the drivers are up to date.However it cannot detect the wi-fi in my office.Other laptops are connected so...
If you have a wireless router and it is connected to the DSLor cable modem then - To connect to your wireless router, the router needsits wireless settings to be configured with the SSID, encryption key etc., alsothe wireless cards and wireless adapters in all the laptops/computers needs tobe configured with these router's wireless settings. Then the laptops/desktopcomputers can communicate with your wireless router and access the Internet via the DSLor cable modem.
If the other laptops are connecting to the wireless router, then look at the wireless card configuration in these laptops and apply the same settings to your HP Probook wireless card.
Sep 05, 2011 | HEWLETT-PACKARD HP ProBook 4720s 173...
Reception very poor and sometimes nothing at all
Move the adapter much closer to your wireless router.
The reception should achieve "excellent".
Make sure that the antenna on the router is vertical,
unless you have more than one antenna.
In that case, follow the manufacturer's recommend for positioning and alignment of the antennas.
Oct 14, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I have a laptop dv9210. my wireless card does not detect internet so i purchaesed another only this one does not detect either. how do i troubleshoot. light is amber on front of laptop. other laptops in...
Click Start
Click Control Panel
Click Classic View
Click System
Click Hardware
Click Device Manager
Click the '+' in front of Network Adapters.
Are both the "built-in" and the "add-on" wireless adapters listed?
Are there any "yellow" or "red" marks associated?
Double-click one of the adapters, and choose "enable".
Repeat for the other adapter.
Failing the above, find a "geeky" friend who can trouble-shoot,
or take your computer to any computer-store, for trouble-shooting.
Nov 27, 2009 | HP Pavilion dv9210us PC Notebook
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
How does the pc wireless adapter work for laptops with embarq equipment. currently using dsl with embarq.
pc wireless adapter will work then if you have also another network like wireless router or another PC or Laptop with wireless adapter, if your going to use this wireless adapter network in pc to pc is you are going to setup by adhoc to adhoc connection, itself detect for sharing a network without any router needed, but if you do such simple network connection use wireless router, its definitely work easily. Aumatomaticall detect wireless router on your wireless adapter network.. Good luck!
Jul 18, 2009 | 2wire (1000-100016-002) Wireless Adapter
Wireless Network Detecting Problem
Check the channel reception of your laptop wireless card or try changing the channel on your router.
Apr 01, 2008 | Computers & Internet
Poor Wireless Reception on DELL Inspiron
It is likely your wireless card reception. try an external usb wifi adapter it shouldn't be expensive.
regards
Mar 01, 2008 | Linksys Wireless-G Broadband Router
I cannot detect my router
A first logical step would be to take your laptop to another wireless location and see if it will work there (you could also take the your wireless unit there to test it). Likewise invite a friend with a wireless enabled machine to visit you and see if they can see your wireless unit. There are three different types of wireless devices in common use A, B, G you need to know which your machine uses and which the wireless receiver uses and assure there is a match. Some devices support multiple types A&G, B&G and A&B&G as long as one matches between the wireless adapter and wireless router/access point assuming the others were not configured off the test should be valid.
Dec 07, 2007 | ASUS (wl500g) Wireless Router
Wireless connection
If this laptop has a wireless switch, make sure it's on.
Did you get the wireless hub?
Wireless is controlled by the wireless zero service, which should turn on automatically when your adapter is detected.
You can turn it on manually in Control Panel/Admin Tools/Services
Nov 03, 2007 | Acer Aspire 3000 Notebook
HP 290563-B21 Network Adapter Logo
261 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
