Question about Apple iPod touch
The Backlight won't come on. i went to general settings and made sure the auto light was on.. and i even turned the brightness all the way up thinking that would help.. but nothing has changed. what else can i do for this to work?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
Try the following
Turn the ipod off and then on again.
If that does not work reset the ipod while it is connected to the power. You do this by pressing and holding the sleep/wake button and the home button at the same tme for at least 10 seconds, until either the apple logo or battery symbol appears. If the battery symbol appears, charge the ipod until it is fully charged.
Hope this helps.
Posted on Nov 15, 2009
Backlight on Flybook V5
Hi Piergiorgio,
Nothing in the registry or BIOS however, in the Flybook control center, you can manually set your brightness on the system and turn off auto backlight. That way the system will always turn on and your system will always remember the setting of the back light.
Let us know if that helps!
Feb 17, 2010 | Microsoft Dialogue Technology Flybook V5
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
Tip
Apple iPhone Battery Saving Guide The Apple iPhone doesn't have the best battery...
The Apple iPhone doesn't have the best battery life in the world but if you follow this simple guide it should provide you with a longer battery life.
1. Turn down the brightness: You can reduce the battery consumption by turning down the brightness of the screen. Select Settings, Brightness, and then drag the slider to around the 25 percent mark, or as low as you can stand.
2. Turn Wi-Fi and Bluetooth off: From the main menu, tap Settings, Wi-Fiand select the "Off" switch. Same goes with Bluetooth; if you're notusing a Bluetooth headset, make sure the Bluetooth radio is deactivated(Settings, General, Bluetooth).
3. Check e-mail less frequently: If you are using Pop Mail then you can save battery by checking it less frequently. Select Settings, Mail, Auto-Check, and pick either the "every 30 minutes" or (better still) "every hour" options.
4. Sync less frequently: If you sync with an Exchange server either turn it to manual or set it only to check periodically
5. Make sure "Auto-Lock" is on: TheiPhone will keep its bright screen burning unless you manually pressthe lock/sleep control. If you haven't already, make sure the iPhone's"Auto-Lock" feature is on: tap Settings, General, Auto-Lock, and then pick a time interval (the shorter the better).
6. Turn off the equalizer: Apple has always suggested turning off the iPhone’s built-in equalizer to conserve battery life. Tap Settings, iPod, Equalizer, then spin the roulette wheel up to Off.
on Dec 23, 2009 | Cell Phones
Hi i plug unit with battery for charging no display lcd and no light indicator colored orange . I take out battery pack and charge then it produce light orange-red indicator of unit. I noticed charging...
Hi I solved the problem by taking off the battery for around 1 hour.
I attached the battery again.
And press hold switch around 10 seconds.
The unit booted and it proceeded to auto configure and auto installed program soft wares.
I realized that the unit is self shutting off.
Solution is go to setting.go to system.go to back light menu.
on backlight on external power .Be sure to uncheck turn off backlight if devise is not used for 1 minute.
Be sure to check turn on the back light when button is pressed or the screen is tapped.
press ok to activate the setting.
For maximized battery power and optimized power usage .go also to back light and go to brightness level.
Slide the battery and power to almost the 2ndlevel .
Hope this also will be applicable to other o2 xda iis configuration.
Best regards
Jan 17, 2010 | O2 Xda IIs Pocket PC
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Backlight doesnt light
you probably need to replace the LCD screen. But there is one method that worked for me. I blew into the bottom hard and put it in sleep mode for about 5 minutes. When I turned it on again i went to settings and put the brightness all the way up and it worked
Jun 01, 2009 | Apple iPod touch
My psp has no image but it has sound
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
  • Check the Backlight Auto-Off setting
    If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on.
    To check the Backlight Auto-Off setting:
    1. From the XMB™ menu, go to icn_settings.gif (Settings) > [Power Settings] and press the icn_btnx_color.gif button.
    2. Highlight [Backlight Auto-Off] and press the icn_btnx_color.gif button.
    3. Select a time interval and press the icn_btnx_color.gif button to save. Select OFF if you wish to disable this feature.
  • Check the Auto Sleep setting
    If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on.
    To check the Auto Sleep setting:
    2. Highlight [Auto Sleep] and press the icn_btnx_color.gif button.
  • Check the Display Button
    Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen.
    The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
Aug 15, 2008 | Video Game Consoles & Games
No backlight
A couple things to try:
1st check the backlight settings
Turn on Backlighting and Control Brightness To use your device in dark environments, enable the automatic backlighting feature:
  1. From the Jump screen, press MENU t02003-15.gif then select Settings > Battery & Display.
  2. In the second group box, select the Turn on backlight when using device check box.
  3. Highlight, then select the Brightness slider to open it for editing. Roll the TRACKBALL right to increase brightness; roll the TRACKBALL left to decrease brightness. After you've made the adjustment, press the TRACKBALL to exit edit mode. t02007-55.jpg
  4. Select the length of time you want backlighting to stay on from the Turn off after pop-up menu.
  5. To use the device's light meter while the backlight is on, select the Use ambient light sensor check box.
  6. Press JUMP t02003-14.gif to return to the Jump screen and save your setting.
Now, when you press any button or key, or flip open the screen, backlighting will turn on for the set amount of time. Note that as long as you press a key or button before the set time elapses, the backlight will stay on.
Tips:
  • Even if you have not selected automatic backlighting, you can turn on backlighting at any time by pressing MENU t02003-15.gif + JUMP t02003-14.gif . The backlight will remain on for the time specified in the Backlight Turn off after pop-up menu.
  • When in key guard mode, you can turn on the backlight by pressing the RIGHT SHOULDER t02003-66.gif button.
If it still does not work, then you can try resetting the flex cable to the lcd.
Reseat the SidekickFlex cable
If that doesn't fix it then a new lcd assy will take care of the issue. they run about 45 dollars on ebay.
Sidekick LCD screens
Apr 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
Creative Labs Zen Sleek backlight went out
I think there are brightness controls in the settings, I'm not too sure lol as my player isn't in the room with me. If there are brightness settings, make sure they're turned up and your backlight is not set to OFF. If the problem persists after this, you can get in touch with Creative an I think they offer a repair service if the product is not under guarantee anymore, but if it is under guarantee, enjoy a new player courtesy of the guys down at Creative. I hope this helps^^
May 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Apple iPod touch Logo
632 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
