Question about Car Audio & Video
I am only useing shop bought discs it will play 1 disc and when i change to a different disc it changes the disc ok then says ready and screen goes blank for a few seconds then says error 60
    President:
  • 1,185 Answers
Either the read head is sticking on the transport mechanism or the head has not been aligned right
The head zeros to a preset position then steps out a pre-determined number of pulses which should leave it over the first sector of the disc.
If you can insert the same disk and get it to play every time then the head needs re-calibrating to make it more compatible with all CD's
If it does the first pass then rejects the second one on the same disk then the transport is not homing corectly
In both cases it is a bench job to set them up again , sorry
Posted on Nov 15, 2009
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Dvd recorder won't play disc
your recorder will normally give you 5 changes at different regions, and on the last region change that is the one that it stays on, although if you you have never changed the region go to> my computer>right click on your dvd drive>properties and on the hardware tab, your hard drive and dvd drive will show, highlight your dvd drive and click properties and click the dvd regions tab and look at the region to see wot its set at, if you still have 5 changes, it should be set at your region one, if there are no changes left you need to search and download a region free dvd programme to allow any region dvd to be played programme
Jun 10, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
Display Reads - No Read or UNSUPPORTED when using DVD
If you cant play a real dvd in it, the laser is prob out of allignment or broken, if its just dvd that you burned, try changing disc type, there is +R and -R , also if that does not work try a different program to burn discs ? good program is convert X to dvd, not free, unless your good at torrents :)
Jul 11, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to clean the lense
Hello
There is a type of disc, called lens cleaner disc. It can be bought from most of the electronic spare part selling shops at your town. It wont cost more. Buy one, and insert it into the player, let some time to play it. Most discs will play automatically, and you can see the result on TV screen. Do it for at least two times. The disc will clean the lens automatically. It is risky to clean it by hand, if you don't have experience to do it.
If you want to clean it manualy, use only 'rectifed spirit' of 'lens claeaning solution' [can be bought from electronics spare part shops]. Never use high sensitive, solvents like petrol or so, as it will damage the lens. The lens is not made up of glass. It is a plastic type meterial. OK
Feb 14, 2012 | Lite On LVW-5115GHC+ DVD Recorder
I want to play Dvd's from Europe so I want a region code free.
1. Power ON the main unit (some unlocks work with, some with no disc inside)
2. Press the SETUP button (on the top of the player) to open the setup menu
3. Navigate to the PREFER menu using the button below the screen
4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, aPREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions - it worked on my PD9012/37 that was region 1
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
Jun 21, 2011 | Philips PD7012/37 Player
Not reading the disc
need a bit more info - are you playing a movie or running software installation?
If you need to change the drive region then do the following
1. Power on your DVD Player without a disc in the drawer.
- Wait for the "Loading" screen to finish and then the display reads "no disc".
Check which region your reader was bought in. (Large Number label is located on the rear of the Player. Region 1 to 6)
-on the remote control
2. Press the "Repeat"button. The "no disc" label on the screen will disapear.
3. According to the region your player was bought in, choose from the following button sequences.
- region 1, press buttons 2, 9, 3, 3, 4
- region 2, press buttons 5, 7, 5, 3, 8
- region 3, press buttons 5, 6, 7, 3, 2
- region 4, press buttons 7, 6, 8, 8, 4
- region 5, press buttons 5, 3, 8, 1, 4
- region 6, press buttons 2, 4, 4, 6, 2
4. The number in the top left corner of the screen shows you the current region. EG "1" for the US/Canada, "4" for Australia/NZ.....etc.
5. Now enter the new number for the region you require (1 to 6)...or simply enter 9 for "Multi-region". The number in the left hand corner of the screen will change to the number you enetered. Wait for the number to dispear. It will take around 15 seconds.
6. Now power off the DVD player with the button on the front of the unit. Now each time the unit is turned on it will be in the new region...or muti-region if region 9 was chosen.
7. If you wish to change the region again...or back to its original, go through the exact same sequence until step 5. Then you enter the different region number.
If you are unsuccesfull with the above code then it may be worth trying one of the resources below.
Jul 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
CD player won't play MP3 CD's?
I have had similar problems in the past - on one computer discs burned using nero were unreliable but using Windows Media Player they were fine and on other computers the Windows programme was useless and produced unreliable inconsistent results.
I suggest you experiment with different burning software and maybe suspect the drive you are using might be past it's best.
I have several cd players in my vehicles and around my home. Only a couple of them will play all the discs and most of them are very choosy and will only read premium price shop bought discs and it is a waste of time trying to play a discount store or freebie disc, or many of my computer burned discs.
I don't know what the differences are - maybe it is the software or the power of the laser burning the disc or the sensitivity of the reading laser, but there are many differences in there somewhere. The situation is very frustrating...
Mar 19, 2017 | 2000 Nissan Maxima
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Have just bought dvp 5960 it will not play downloaded off my computer just shows unknown disc
The DVP5960 should play ANY DVD format except DVDRAM.
Do bought DVDs play ok? If so, then the problem is probably not the player.
What file type are you burning on to the disc? .AVI (DivX) & .VOB (DVD) files should be ok.
If you are using Windows Explorer to drag & drop the files to the disc, you will also need to finalize the disc.
Apr 28, 2008 | Televison & Video
Will not read disc
Adjust the trimmer below the lens.
Mar 17, 2017 | Panasonic DVD-CV51 Multi-disc DVD Player
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
