Question about Vivitar ViviCam 4100 Digital Camera
Latch on batterey door is borken,
The little tangs that hold the door down are broken off .
is ia new cover available for replacement
  • 667 Answers
Here is Vivitar's USA number: (800) 592-9541. They should have what you need
Posted on Jan 09, 2008
Samsung microwave door popped open and now won't close. What happened?
The spring attachment to the moving latch has broken off either replace the latch or drill a small hole in the latch body and attach some heavy steel wire to make a new attach point for the spring. the inside trim easily pops off and the latch just slides off.
Jan 26, 2011 | Samsung Microwave Ovens
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Camera door thats holds battery small grey latch is broken
Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Drivers door wont latch
open yor inner door panel most of the time it is a lock rod, or plastic socket that holds it in place might of broken, or simply jarred loose if slammed hard. on older cars.
shack
Apr 14, 2009 | 1998 Toyota Tacoma
I have a Canon sure shot TeleMax with broken battery box door.
Yes, it's very easy to replace, once back cover is removed.
There are no diagrams available anywhere.
You'll have to remove all screws you see and remove first front cover and then back cover.
Apr 07, 2009 | Canon Photography
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Machine saying close outer door but its closed
I'm not an washing machine engineer but I do tend to do all my own home repairs - had to fix this fault this morning,
Quite easy to fix as long as there are no broken parts in the interlock and the solenoid isn't jammed.
UNPLUG FROM MAINS
Remove the top - 2 Philips or flat blade screws - pull backwards.
Remove front door - large flat blade inserted into gap in lower door hinge at back and gently twist to widen gap while pulling the door forward at bottom.
Remove 4 torx type screws (not sure what size) and 2 long torx screws from behind the hinge.
You may want to remove the coin trap door now - it makes the job of removal and refitting the front panel easier. Remember to put a tray underneath!
Unplug the ribbon connector for the front panel from it's socket and the clips - unplug the little pipe from the middle of the front panel.
Gently lift the front cover pulling the bottom edge forward a bit to ease removal. It is not necessary to fully remove the front panel so you can leave the mains switch connected.
Unhook the emergency release strap from the pivot arm.
2 Torx Screws above and below the door latch hole secure the latch assembly. Unplug the latch from a socket past the little foam block on the front - just inside the machine.
You now have the latch. Operation is quite obvious. The door loop pushes an angled plate that swings a hook into the loop. The solenoid when activated pushes a bar down to lock the hook in place and push down on 2 micro switches wired in series as the interlock.
To strip down the assembly unplug the micro switch plugs and push a small screwdriver into the top and bottom catches.
You can now lubricate the latch and check the function of the micro switches using a meter. They a easily replaced if you can find the correct type. (Unofficially - for a home repair - if one is not working you could always bypass one - but I wouldn't condone that obviously)
If you are careful enough - the operation of the solenoid and latch can be checked and observed by plugging the unit back in and pushing the door loop into the latch - be careful of the exposed wires etc - not sure what voltages are there!!
If it's unservicable then a replacement is about £35 online.
Reassemble in reverse - nothing to point out and is quite straghtforward. Dont forget the little pipe on the back of the control panel - it's easily missed.
Hope this helps.
Darren
Mar 08, 2008 | Dyson Flowcheck CRO1 Front Load Washer
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Vivitar ViviCam 4100 Digital Camera Logo
27 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
