Question about Toshiba (4CH-VOUT) Sound Card
I have no sound coming from my on board speakers but I can hear when headset is plugged in. I have verified that all volumes are turned up and pointing to correct device.
  • 62 Answers
The audio jack ie the female side on the board where you plug in the audio pin should be faulty just remove it by a soldering rod and fix a new one. You should be up. Usually these fail on repeated plugging in and out.
Posted on Nov 15, 2009
Olivia tv has no sound but see picture what does this mean?
  • Make sure that your audio cables are plugged in properly to the correct ports if your audio is distorted or noisy. Every cable should be inserted completely. If you still encounter bad audio, replace the cable and then attempt to use a different device with the old cable. This will help you pinpoint the source of the bad audio problem.
  • 2
    Use the "Volume up" button on the remote or TV buttons panel to turn up the TV audio volume if the volume is quiet. If the volume is still quiet, check to see if your audio source device has volume settings. If it does, turn the up the volume on your device (see your device documentation if you need help with this).
  • 3
    Press the "Mute" button on your remote control to disable the mute function if you can't hear any audio. Once disabled, press and hold the "Volume up" button on your remote control to turn up the volume. If there is still no audio, press the "Menu" button on your remote control, select the "Audio" menu, and ensure that the "TV Speakers" are set to "On." If you are still not having any luck and are using the built-in TV tuner, open "MTS Audio" inside the "Tuner" menu and make sure it is set to "Stereo/English." If there is still no audio, verify that all your audio cables (including the antenna cable if you are using one) are plugged securely into the proper ports on your TV and audio source device (if applicable). If you are using an antenna, reposition it to a clear, open area; preferably near a window. If your audio source device has audio settings, check to make sure they are set the way they should be (see device documentation).
  • May 07, 2014 | Vizio L32 32 in. LCD HDTV
    Skype not working
    Sir,
    Click this link for more information........
    http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
    Also Check........
    On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
    This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
    But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
    Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
    Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
    You can also tick the ring pc speaker check box as this is a good backup to alert you even
    if the main speakers are off or turned down.
    Windows:
    Start-->Control panel-->Sound and Audio devices
    On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
    Your installed audio device must be present there.
    If not, reinstall audio device
    thanks
    good luck
    Oct 29, 2008 | Altec Lansing Stereo Headset with...
    Can't hear the skype ring when a call comes into my computer.
    If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
    Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
    Feb 13, 2013 | Computers & Internet
    I do not have any volume in the headphones i dont know how to turn them on or something please help me on how i can hear stuff like youtube videos or something.
    Did they ever work or are you trying them on a new computer? They don't need switching on you just plug the plug into the audio out of your sound card or motherboard, make sure the mute button isn't selected on the inline remote. Play an mp3 on your computer, make sure the volume on your computer is turned up, plug in another known working set of headphones or active speakers make sure you can hear the music, then plug out those speakers and then plug in the headphones. Do they work when you try that?
    Jan 13, 2011 | Microsoft LifeChat™ LX-3000 Headset
    My logitech x240 surround powers on but no sound comes out....what could be the problem??
    If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
    If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
    (If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
    Dec 08, 2010 | Computers & Internet
    It shows the speakers are on but no sound
    Dec 08, 2010 | HP JBL Platinum Computer Speakers
    How do i fix the volume because i do not have sound? my tv has no volume/sound. tried turning the tv up and down but still no sound
    1 - hi
    2 - check the jack for headset
    - if you heard any sound with headset = your speakers are burned
    3 - if you always use this jack for head set its maybe got problem = when push or pull the headset jack if you hear any sound from speakers your headset socket should change
    4 - if you didnt hear any sound from both (speaker and headset) it means your ampilifire should repair
    May 23, 2010 | Emerson CR202EM9 TV
    I am trying to figure out how I can prevent the sound of the game from coming out the tv. I just purchased turtle beach headphones but the sound of the game is still coming out the speakers of the tv also....
    When you set the headset up following the instructions in the User Guide, you'll have both the headset and the TV playing. All you need to do is turn off the headset to hear from the TV only, or turn down the volume on the TV to hear from the headset only.
    Jan 24, 2010 | Microsoft Windows XP Professional for PC
    Skype
    Audio Setup for Windows XP and Vista
    1. Audio settings, in Windows and Skype
    XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
    or Right-click speaker icon in system tray and select "Adjust Audio Properties"
    Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
    Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
    Audio / Sound Playback: Your on board sound/Sound Card
    Audio / Sound Recording: Your on board sound/Sound Card
    Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
    Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
    Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
    or Right-click speaker icon in system tray and select "Playback devices"
    Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
    Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
    Playback / Properties / General: Device Usage: “Use this device (enable)”
    Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
    Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
    Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
    Recording / Properties / General: Device Usage: “Use this device (enable)”
    Recording / Properties / Custom: If “Microphone Boost” is present, select it.
    Recording / Properties / Levels: Microphone volume should be centre or higher
    Recording / Properties / Levels: If there is a “Mute” button, it must not be on
    Skype / Tools / Options / Audio Settings:
    Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
    Speakers: Your headset, USB device or speakers, as you prefer
    Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
    Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
    2. Microphone and Speaker connections
    Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
    If your microphone or headset has a “Mute” switch, make sure it is not on
    If your speakers or headset has a volume control, make sure it is turned up
    For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
    A standard microphone plugged into Line In will NOT work.
    3. Check audio in Windows.
    XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
    Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
    Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
    4. Once done, test with Skype Test Call (echo123).
    Oct 19, 2008 | Computers & Internet
    I have an ABIT computer i plug my headset in and the mic works but the speakers don't ive checked an the hardare says the speakers do work but i cant hear anything. by the way its not sound turned down or...
    make sure when you click on the speaker in the bottom right hand corner that your wav volume is also turned up or nothing will come out as well. and always plug speakers ect into green plugins on computers and speakers.
    Aug 02, 2008 | Computers & Internet
    Computers & Internet Logo
    190 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
