Question about Dell Computers & Internet
Can't connect to internet thru 2wire modem on new computer
Just got a new dell desktop. Pluged in the cable from existing 2wire wireless modem but new computer is not recognizing or allowing access to internet?
    Problem Solver:
  • 19 Answers
Check the ipaddress. go to start -> run -> type ipconfig and hit enter. if you have a 169.x.x.x then you have an invalid ipaddress. if you have any other address go to start -> run -> and type ping google.com. if you recieve replies then the problem is browser . if you dont get replies then check your dns and verify with your isp that that is the correct address. if all checks out then call your isp and tell them they need to replace the modem wether is cable or dsl.
Posted on Nov 15, 2009
Need to connect reurbished dell GX520 to existing internet
first connect the "cat 5" cable to the dell's network card, the card has a square-ish hole with a little "cutout" in the top (for the cable's connector tab) the other end of the "cat 5" cable goes into the back of the router (you do have an existing router?) into one of the un-used square-ish holes (same cutout for the tab).
Then turn on the computer, see if the computer will "connect" to the router (that means it sees the router in computer-ish software).
IF that works then connect the router to the Modem (supplied by the "Internet Provider"... Then turn on the modem....
IF all goes well, your computer will now be able to connect to the existing internet.
Now for problems...
IF it seems to be connected correctly using the proper cat 5 cable, and it still will not work... turn off everything, start with the internet modem, then the router, then the computer... COUNT to 30 (1, 2, 3, 4... 29, 30) turn on the internet modem... count to 90 (1,2,3,4...90) turn on the router... count to 30 (1,2,3,4...30) turn on the computer... wait for it to fully boot, look down at the lower right of the screen and see if it can connect now.
IF it still doesn't connect, you may have to try another network card in the computer, or get a wireless USB "thingy" to connect to a wireless router...
Hope this helps...
May 21, 2014 | Dell OptiPlex GX260 PC Desktop
Why cant i get wifi or wireless internet to work
Bill:
depends on how u r hooked to internet. direct thru cat5 cable to modem, or wirelessly thru router? then, you must make sure that your modem is connected to web? make sure modem is connected; plug in to desktop(off) then turn desktop on; go to start, then control panel, then Network and Internet; find out if you see a connection? if so, then right click on network connection, click on Troubleshoot Issues. this will try to resolve your internet connectivity. if you still cannot get online, call your internet provider for more specific steps in fixing.
May 16, 2014 | Dell XPS 200 PC Desktop
How to install to att 2wire 2701hgb modem router
Plug one end of an Ethernet cable into the modem's Ethernet output port and plug the other end into the router's single WAN/Internet input port.
Nov 09, 2017 | NetGear RangeMax Dual Band Wireless-N...
Cannot connect my dell laptop wirelessly, will connect with a wire and will connect wirelessly at the library. The old 2wire was ok but we replaced it with a new 2wire today. Have spent 3 hours with att...
Since you are able to connect using a hardwired connection and you're able to connect wirelessly at the library, that simply means that your computer and your internet browser are fine. where is your wireless computer and your wireless located? are there any possible wireless devices interfering with the wireless signal like chordless phones, cellphone, TVs, radios, microwave oven? are your walls in your house covered with metal plates coz that would really make the signal deteriorate. the settinngs on your wireless router may also need to be reconfigured and boost up the signal of the wireless router.if only i could remotely access your wireless router, I would really walk you thru on what to check on your wireless router
Jul 07, 2011 | 2wire (1000-000057-000) Modem
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
I have a 2wire modem from att. i made a 50 foot eathernet cord, i have a eathernet transmitter teaster to test the cable to see if it is good (and it is) but i still cant get internet on the other side of...
Try with a shorter enet cable and see if you get internet, if you are able to get internet with a shorter cable then the cable might not be working fine. Else get a wireless card installed on your computer since the 2wire modem has wireless connectivity. It would be more easy and convenient to connect to wireless using the 2 wire modem.
Jun 24, 2010 | 2wire (1000-000057-000) Modem
Cable and wireless question
Not possible, since the "input" to the 2WIRE modem is a 4-wire telephone-line, not an 8-wire Ethernet cable.
Instead, spend about $40 to buy a D-Link Wireless G modem, and connect its WAN port to the cable-modem, and connect up to 4 Ethernet cables to "wired" computers, and configure the "wireless" component of the D-Link router.
May 07, 2010 | Computers & Internet
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
Jan 24, 2009 | 2wire 2700HG-B Router (2700HGB)
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Computers & Internet Logo
173 people viewed this question
Alun Cox
