Question about Compaq Armada M300 Notebook
Cd rom drive
My computer says everytime i open my cd rom drive"drive d: is not accessible. this folder was moved or removed"
    Champion:
  • 238 Answers
Hi there is this AUTORUN file which is not supposed to be there is missing, do this.......right click on D drive then open, then delete all the unwanted files from the root DIR.. let me know
Posted on Jan 09, 2008
  • ravi chavan Jan 10, 2008
    oops , sorrry dear. the solution was for harddisk drive not cd rom drive, what u do first is uninstall the cdrom from device manager and rescan it and let me know if it is still the same??
How to open the disk drive
Open the Computer folder in Start Menu, select the DVD Rom Icon, right click, select Eject. If a DVD or CD has exploded inside remove DVD Rom and open the DVD case. Sometimes if you open the front case door cover and access the DVD/CD drive door you will see a tiny hole to insert a open paper clip that will open the tray.
Mar 19, 2013 | HP Black Compaq Elite 8300 All-in-One...
I formatted a CD from my Gear Head Mobile Slim CD/DVD R/W removable drive. The drive shows up in all of the following: (1) My Computer, (2) the Device Manager, and (3) the task bar's removable devices. But...
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps
Apr 23, 2011 | Gear Head 8X DVD MOBILE SLIMDRIVE W/...
My laptop Emachines D525 doesn't notice its DVD/CD disk. It's also lack of DVD/CD-RW drive. How can I fix this? I'm looking forward to hearing your solution!
provided below are troubleshooting steps to help you fixing this problem, just follow each steps carefully.
- click start > run and type "regedit" w/o qoutes
- once you access the REGISTRY EDITOR kindly open therse folder (each folder contains another folder) make sure to follow the below steps carefully.
- go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
- insed the "class" folder look for {4D36E965-E325-11CE-BFC1-08002BE10318} it is the CD/DVD rom drive.
- at the right part of the registry delete "upper" and "lower" filters name
- once done close the registry.
Go to device manager
- click start > run > type "devmgmt.msc"
- click the + sign beside CD/DVD drives
- right click and select properties
- go drivers tab
- and then select the button uninstall the driver
- RESTART THE COMPUTER
After restart all should be fine now.
Cheers . . .
Mar 22, 2011 | E-Machines emachines (emachinees) CD-ROM...
The computer is detecting the CD rom but the cd rom is not detecting or reading any CDs
The laser is probably burned out or the spindle motor isn't turning.
With the price of these units, I'd just replace it.
There's not much you can do to fix either problem anyway.
A CD ROM (hard to find, but some places still carry them) can be had for $5 or $10.
For just a bit more, you could get a DVD burner.
Mar 17, 2011 | Sony (CDU701) Internal 32x CD-ROM Drive
The cd door on my dell computer model #: IN1910N keeps poping open. everytime i turn on computer it opens. then i close it and wont stop poping open
make sure that the cd rom is getting enough consistent power test all leads that are attached to the cd rom including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
also
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
only do the registry check if you cant see the drive/s in windows explorer/my computer
or it might be a registry problem
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
dont forget to vote
Feb 25, 2011 | Dell Computers & Internet
How would i fix with my icon default,, everytime i open an application... open in suggested file... i want to return it to default... application,, and my rundll32 is not working, system32
***Find a copy of rundll32.exe in folder c:\windows\system32\dllcache or in c:\windows\servicepackfiles\i386.
If you find this, go ahead and copy rundll32.exe to the system folder c\windows\system32.
Otherwise you need a windows disc to expand this file (see below).***
1.
Put the Windows XP CD ROM disk in the CD ROM drive.
2.
Click Start , and then click Run .
3.
Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4.
Restart the computer
Jan 25, 2011 | Microsoft Windows 7 Home Premium 64BIT...
Can't get into any folder because c:Windows/System 32/rundll32 .exe keep popin up
To resolve this issue, follow these steps:
1.
2.
3.
4.
2.
3.
4.
1) Put the Windows XP CD ROM disk in the CD ROM drive.
2) Click Start , and then click Run .
3) Type expand X :\i386\rundll32.ex_ c:\windows\system32\rundll32.exe in the Open box, where X is the letter of your CD ROM Drive.
4) Restart the computer.
Oct 27, 2010 | Computers & Internet
How do I get a cd rom to download to my computer from my GR-D290 camcord
Remove the CD disc from the camcorder and put in the CD drive on the computer. A windows may open automatically to show you the conmtents of the CD.
If it does not open automatically:
1. Use Windows explorer ... open "My Computer"
2. The CD will probably be listed as Drive D:"
3. Double-click (open) the Drive and each folder that appears on the drive.
4. The viseos will be listed...
5. you can copy (or "drag") these to a folder or your desktop.
Please reply with a comment if you need more information about this...
Sep 09, 2009 | JVC GR-D290 Mini DV Digital Camcorder
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
My Dvd rom has disappeared. how do i get it back
To solve this follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording application
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7)uninstall the drivers for cd drive and dvd drive from device manager and then
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that there is no yellow exclamation on the CD or DVD drive
Jun 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
Compaq Armada M300 Notebook Logo
69 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
