Question about Welding Tools
Remove the trigger
How do you take the gun apart to check if the trigger contacts are worn for a Lincoln SP100 Mig Welder ( I don't want to break something in the disassembly).
    Problem Solver:
  • 7 Answers
Use a meter to check the contacts with the gun disconnected from the unit. Touch the terminals and operate the trigger to see if it is working. Vary the pressure and angle of operation to ensure the trigger is not broken internally. If you still need to disassemble the fallout is not too bad as you will be certain it was broken. Cheers.
Posted on Nov 24, 2009
I have a craftsman 20511 mig welder it will start welding without pushing trigger
Elmer, If you remove the gun assembly from the machine, if the machine is now not feeding wire, the problem is most likely the gun trigger is faulty. The switch contacts heat up and start sticking over time. If able too disassemble and clean trigger contacts. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 934 205111 Operator Manual
commin problem with wire feed welder
Wire won stop feeding
May 02, 2016 | Craftsman Welding Tools
What make & model mig gun is fitted to this machine
Mig Guns & Mig Gun Spares - The Welders Warehouse
www.thewelderswarehouse.com/Welding/Mig-Welder-Gun.html
We have Mig Guns and spares to suit a wide range of Mig Welders. ... Torches are usually Euro Fitting and are typically fitted to professional mig welding machines of ... attitudes from people one is giving money to ! its great to get good service.
[PDF]POWER MIG ®(140, 180 MODELS) - Lincoln Electric
www.lincolnelectric.com/assets/...public/.../im890.pdf
Lincoln Electricshipment must be made by the purchaser against the transportation company at the time the shipment is received. SAFETY DEPENDS ON YOU. Lincoln arc welding and cutting equipment is designed and built with ... properly fitted and with proper grade of filter plate .... Semiautomatic DC Constant Voltage (Wire) Welder.
Millermatic® 211 MIG Welder - MillerWelds
Dec 20, 2015 | Welding Tools
Wire feed have erratic speed when welding.
adjust your speed either up or down to match the amps required to weld
Jun 08, 2015 | Lincoln Electric Handy MIG K21851 Welder
My wire feed quit feeding wire what do i need to replace to make it work
Hi:
If your drive rollers are moving but can't push the wire all the way to the end of the gun, your problem could be the liner in your gun and/or the contact tip. Try to replace both. If your drive roller are not moving then check the trigger of the gun.
Oct 03, 2011 | Lincoln Electric LE 83180 Century...
My magnum 100l is flowing gas even when the power is off. How do I get it apart to look inside?
Hi:
Your gun is not the problem, your problem is the solenoid valve on your machine (welder) that solenoid valve must got dirt or debri from the hose and the closing needle it's stuck . Just replace it, it will be cheaper than replacing your gun.
Have a great day.
Jun 21, 2011 | Lincoln Mig Welder Trigger Switch Magnum...
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
My little 110 mig welder is arcing without trigger pulled
i believe that the trigger only send out the wire and does not control the arc the tip should be live as long as the welder is on
Feb 28, 2010 | Lincoln Welding Tools
I have a Lincoln 140 mig welder. It welds and cuts
Usually this is caused by a bad liner in the mig gun hose, or worn out guide rolls in the drive unit, or if this is not the case the speed of the wire might be set to high as this would force the wire into the weld causing the motor to heat up from resistance and shut it down on safty. Hope This Helps Don
Dec 02, 2009 | Lincoln Welding Tools
When you squeeze the trigger on the mig gun, the voltage on the welder drops out. There is no open circuit voltage. What do i need to check
take the gun apart and make sure there are no shorts or lose wires then check the end that plugs into the welder same as above.if all is well we'll have to go deeper.let me know....drum53
Nov 06, 2009 | Miller Welding Tools
Welding Tools Logo
94 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
