Question about Nokia 6300 Cellular Phone
I am unable to pair my phone to the Parrott
I am unable to pair my Nokia 6300 to the Parrott handsfree in my van. The phone is finding the device but when I type in the code I get 'pairing failed'. The insallers phone was able to pair.
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My nokia 7610 says unable to perform bluetooth operation
When you get an error "unable to perform Bluetooth operation", it means that one of the Bluetooth devices is not communicating correctly. It could be your phone, or it could be the Bluetooth device that you are trying to connect to. And that will depend on the device that you're connecting.
There's a possibility that the Bluetooth requirement of your device is not supported by your Nokia phone. Example, you are trying to pair up a Bluetooth handsfree car kit. "IF" the phone does not support the handsfree profile, then you will get this error message.
So, you need to make sure that your device and your phone is compatible with each other. Second, try to pair up the phone into different Bluetooth devices, like phones, headset, etc. Doing this will let you know if the Bluetooth on your phone is working or not. If it works with another Bluetooth devices, then the problem has something to do with the device that you are trying to connect to.
Thank you and good luck!
Jul 31, 2010 | Nokia 7610
Got new car with parrott ck3100 and need code to enter into the phone .
code is 1234 you will need to delete any paired devices from the settings menu before pairing.
Jan 24, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
My nokia 6300 is finding my handsfre carkit but is
tell me more about the make and model of your car kit please.
Nov 16, 2009 | Nokia 6300 Cellular Phone
Motorola handsfree kit
these kits are not very good and they are old, you are also unable to update software to work with new phones and the mic quality is poor.
go to your paired devices on your phones and change the hf850 to not connect automatically on both the phones, this may work.
If you can get a full refund and only pay the difference for a parrot it will be worth it. Also look at the THB Bury kit.
Dan
Mar 25, 2009 | Motorola Mobility Bluetooth??ยข HF850 Car...
Unable to pair Nokia N85 to Parrot car Kit
It's possible that you need to reset the parrot - seems it might only accept pairing with one phone. On mine you hold down the red and green keys together until she tells you that she is clearing the memory, then she prompts you to pair your phone
Mar 03, 2009 | Parrot Par Ck3000 Evolution Ck3000...
Trying to pair my N95 to my parott
Which handsfree set do you have?
You can find userguides on the parrott website for several models.
These describe very well how to connect.
Normally you should just activate bluetooth on your n95, search for bluetooth devices and connect to the handsfree set. Password is 1234.
Please post some feedback.
Apr 24, 2008 | Jabra BT150 Wireless Headset
N73 not pairing with visorlite
here's the manufacturer's website where you can download the manual (it is also marketed as Supertooth Light)
http://www.supertooth.net/down_light.html
Mar 13, 2008 | Nokia 6300 Cellular Phone
Accept code for a bluetooth headset
If this solution doesn't work hold down both the volume up and down buttons on the head set for about 5 seconds whilst searching for a new paired device with your phone then when asked enter the code 0000 and connect
Sep 17, 2007 | Nokia 6300 Cellular Phone
Nokia 6300 Cellular Phone Logo
133 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
