Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Light on sensor won't come on, hence the door won't close. Unit is five years old
    President:
  • 3,197 Answers
As you probably know the sensor must be pointed at each other for both lights to come on. If tweaking them doesn't work you most likely have a sensor that has failed. Just double check the wiring to that sensor and make sure it hasn't been broken or disconnected.
Posted on Nov 15, 2009
The unit is displaying a sequence of 5 flashes with the amber light. When I try to open the door, it will only go forward and backward aprrox. 1 ft. Any suggestions on what I should do?
Craftsmsman 1/2 HP opener indicator light blinks five times ...
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
Sears Garage door opener problem - Home Forums
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
Craftsman Garage Door Opener Problem - Home Forums
Jan 05, 2016 | Building Materials
Hello, I have a 1246 1/3hp manufactured in 1996. It has stopped operating and I would like suggestions on what the likely cause is. The door worked fine until yesterday. I put the door up and it o
Your problem is a simple one ! The capacitor or starter motor as it,s called is shot , The gray cylinder that.s inside the housing of the motor is the capictor, unplug the machine and remove the capacitor and replace ! Remember to note the location of the 4 color coded wires when replacing ! This will start the motor and gears spinning again! Hope this helps you Sincerely Glenn
Feb 01, 2015 | Building Materials
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
The opener won't close. My husband said the sensors need to be realigned. Did that and still the opener halts after 2 inches and flashes the light? It is a six year old Sears Craftsman Chamberlain model?...
If the main light flashes 10 times it is a door sensor problem. If the main light does not flash then you can try increasing the down force. This is a control on the rear of the motor unit near where all those white wires go. If this doesn't help you probably have a bad infra red sensor board. This is a small printed circuit board just in front of the motor.
Apr 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
My refrigerator door comes open easily when the freezer door is closed and goes unnoticed as it is barely pushed open. I have checked the door stop down at the right hinge, it is clear. The refrigerator is...
Try to re-adjust the appliance so it is level and tips backwards slightly. You'll have gravity on your side to help keep the door closed. You will need help tipping the unit while adjusting the levelers underneath.
Also make sure the appliance is sitting on a solid surface and isn't somehow twisted, which will place stress on the box and possibly cause the issue you describe.
Make sure the unit is not overloaded and that the gasket surfaces are clean. After only 5 years, the magnetic gaskets should not be worn out.
Jan 27, 2010 | KitchenAid Superba Architect KSCS25INSS...
Censor isn't working; temperature rising in frig (freezer ok)
Hi, do you think you could provide a model number. Some of those Samsung fridges have bad control boards at the back which could cause that problem OR the other possible fault could be the cabinet light sensor by the door hinge.( I'm going to assume it is this type based on the symptom you've described)Sooo...If you remove the hinge cover at the top you may find the receiving part of the sensor is misaligned or out of place completely which will prevent the semsor from detecting the door is closed, hence the interior light remains on and the temp rises and all sort's of unwanted side affect's. That is where I would start looking, but I don't even know if your unit has a push button door switch or the sensor style without a model number. However, based on several service calls for this exact problem in the past I'd say the chances are good it's the door close sensor if that applies to your model fridge. Hope that help's, let me know. Thanks for visiting fixya today. Good luck macmarkus :)
Dec 25, 2009 | Samsung Refrigerators
Craftsman opener, 16 years old, want move, all lights are working
Remove and check the logic board for missing or burnt traces. Check closely around the small transformer. Be sure to unplug the unit before you do this.
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
HP Officejet Pro - Printer Door Open Light Stuck On
There is a problem with the proximity sensor for the top door. I have took mine off and soldered the connections over to trick it into thinking the door is closed all the time. I am trying to source a new part
May 20, 2008 | HP Officejet Pro K850 InkJet Printer
Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Jun 26, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
