Question about Garden
I have a cub cadet 1500 series and it wont start i changed the fuel lines feul filter spark plug i can pour gas in the carb and it will fire but there is gas getting to the carb it just wont start
    President:
  • 1,627 Answers
Check and see if it has an anti-backfire solenoid in the front of the carb.If it does and the solenoid has power then you need to replace it.
Posted on Nov 18, 2009
What is the piece protruding out the bottom of the carburetor bowl on a Cub Cadet LTX 1040 lawn tractor
Fuel shut-off solenoid (anti backfire device). Check it for proper operation by removing from bowl, plugging it in, ground it against the crankcase, and turn the key on with the brake pedal depressed. You should see the plunger suck in. Turn the key off and the plunger will poke back out. Be sure you have good fuel flow to the carb through the fuel line, clean/ rebuild the carb, and test the solenoid.
Sep 02, 2014 | Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet will start but it will not stay running. It acts as if it isn't getting enough gas. Help!
Several things to check....air filter being clogged, fuel filter clogged, fouled spark plug, engine could be flooding--clean air filter service choke with carb cleaner-let set, throttle not opening wide enough, plugged fuel cap,
Sep 28, 2013 | Cub Cadet Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Cub pushmower
see if its getting spark hold the old spark plug against metal and connect the plug wire to the other side pull the rope while watching for spark if you have spark try starting fluid if fires on that then open the carb and clean inside
Aug 10, 2012 | Cub Cadet Garden
I have a cub cadet 1500 series with 200 hours! I just changed oil filter, air filter, fuel filter and spark plugs! I started up my mower and it is now running like ****! The idle goes up and down, if I...
I think runnng out gas. Your fuel cap vent and unhook fuel line from carb. and see if fuel run out. And check if fuel filter in the right direction.
May 06, 2012 | Garden
When i start the lt1042 cub cadet riding mower it smokes from the exhaust and oil is in the carb
sounds like the needle valve inside the carb has failed dumping gas into the crankcase and into the cylinder this overfills the oil and dumps it change the valve and seat change the oil a couple times add a fuel line shut off and run the carb out of gas when your done using it the newer fuel we get melts the rubber seal
Apr 25, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
2160 cub cadet that wont start.hot spark to the plugs
You've solved for some of the equation. Spark. Fuel. Air.....all in the proper sequence. Now, what condition are the plugs ? I'd change them out if they have any wetness to them. Check your fuses as well. Another thing is the 'safety switches' - located in seat, on parking brake, etc. One of these could have come undone or gone bad/loose wire. I'm thinking the latter....
Jun 20, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
