Question about Car Audio & Video
I want to install it in my 2006 trailblazer ss and i need a installation manual and operating manual
  • 11,896 Answers
You can find the instructions at modifiedlife.com or installer.com along with wire kits, install kits, factory car wire diagram and more.
It is easiest to get the adapter so you don't have to cut origional wiring
POWER GROUP
Yellow- Battery (+) 12V
Solid Black- Ground (-)
Red- Ignition 12V
Blue with White stripe- Remote Wire 12V
SPEAKER GROUP
Solid White- Left Front Speaker (+)
Lined White- Left Front Speaker (-)
Solid Grey- Right Front Speaker (+)
Lined Grey- Right Front Speaker (-)
Solid Green- Left Rear Speaker (+)
Lined Green- Left Rear Speaker (-)
Solid Purple- Right Rear Speaker (+)
Lined Purple- Right Rear Speaker (-)
Posted on Nov 15, 2009
I have a 2006 trailblazer SS and im having a problem a reduced engine power light comes on and wont let the truck start until the light goes off
haynes or chilton manuals are good investments. also auto parts stores can help with free analysis
Jun 04, 2014 | Cars & Trucks
I need to change wiper blades on 2006 trailblazer. i can't get the wipers off.
The 2006 Chevrolet Trailblazer has the most common hook-end wiper arms. Purchase the replacement blades first and there will be additional instructions/illustrations on the replacement packages. Locate and press the tab or button where the wiper blade is inserted into the hook of the wiper arm and pull wiper blade out of hook. You may have to rotate and flex the blade to make enough clearance for the hook to pass through.
2006 Chevy Trailblazer Wiper Blade Installation Videos (hook end arms)
2006 Chevrolet Trailblazer Wiper Blade Size Options w/Correct Lengths & Attachments
Aug 16, 2011 | 2006 Chevrolet Trailblazer Ext
2006 Chevy SS Trailblazer no low beam lights
Either a fuse , burnt out lights, or wiring isse. Need to check it out.
Best Reguards, Premium FixYa Support
Jul 15, 2011 | 2006 Chevrolet Trailblazer
I need to replace the low beam light on my 03 trailblazer but can't find out how to open the headlight
you dont open it they install from the backside.you can go to autozone they should replace it for you for free,if you buy the bulb from them
Apr 17, 2010 | 2007 Chevrolet TrailBlazer SS
How do you change heasdlight bulb on my 2007 trailblazer ss?
twist the large plastic lock ring counter clock wise(on the back of the headlight assembly)then pull out the old bulb,unplug the wires and reverse removal instructions to reinstall.Just be absolutely sure not to touch the tip of the new bulb,the oil from your skin can cause the new bulb to fail upon installing it.
Dec 28, 2009 | 2007 Chevrolet TrailBlazer SS
2006 Trailblazer SS, the Ac belt needs replacing, but the engine belt is in the way, how do I remove the engine belt?
Remove the air intake tube, the one that goes from the air filter to the engine. On the top passenger side of the engine there is a belt tensioner. Using a 15mm box head wrench push it tword the drivers side of the engine, this will release the tension of the belt so you can slide it off, then you can get to the ac belt. It's going to be a tight fit but you can do it!
Oct 25, 2009 | 2007 Chevrolet TrailBlazer SS
2006 trailblazer 4x4 4.2, stalls while driving. Engine shuts down, whenever and wherever it feels like it. No pattern other than about every 2-5 miles, has worsened to this point over last 10 days....
ok well try this when it stalls see if spark is present and if it is not and it cools down and starts then you might need to replace ignition control module good luck
Aug 08, 2009 | 2006 Chevrolet Trailblazer
06 Trailblazer will not Start or go out of park
Check the release bearing of your transmission and check the transmission oil level.
Jun 09, 2009 | 2006 Chevrolet Trailblazer
Remove and install battery in 2006 trailblazer ss
I actually have one of these..lol It is not difficult. remove ground wire first then positive. it will have a hold down clamp on the side of the battery on one side. It will be most probably be a 13 mm. remove this and then reverse precedure to install. You will loose your memory on all your electronics if you do not supply voltage to your cigarette light plug. It will not hurt anything but your car will have to be programmed, ie radio stations theft lock on radio if it has one, and it will take your car about 100 miles to relearn and callibrate the on board computer. I hope this helps you some.
Dec 18, 2008 | 2006 Chevrolet Trailblazer Ext
Car Audio & Video Logo
26 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
