Question about Kohler K-3488-0 White Devonshire Devonshire One Piece Elongated Toilet with
We have a Devonshire pedalstal sink that is clogged and we can't snake with the P trap it just gets hung up. Plunging hasn't worked. Any ideas?
  • 119 Answers
You need to remove trap and rod from the wall opening I have had to remove many pedestal sinks in order to rod the drain
Posted on Nov 15, 2009
The tub is clogged with hair
Few plumbing issues such as Dripping faucets. Running toilets. Leaky valves. Clogged bathtubs can be solved by our own trying few things.
1)Firstly lookout for what is causing blockage such as soap or hair inside the pipeline blocking water just pull it out from pipes.
2)Secondly use a plunger(Tool used by plumber to clear clog) pour some water in bathtub to cover the plunger block the overflow of water with rag.Place the plunger over drain pull up & down 5 to 6 times.
3)Lastly if still the clog is not cleared try out with snake a long flexible steel cable wound on a handle In a sink you just feed the snake down the drain, but on a bathtub you need to feed the snake down through the overflow plate opening. Start by feeding about 3 feet of the snake into the opening, turning it as you push it forward. You will feel some resistance as you work the snake through the trap under the drain, and the turning helps to move the head through the trap. The snake should either break up the clog by pushing its way through it, or your turning will hook the end of the snake onto the clog and you can pull it out.
After trying with above if still there is plumbing issue call sewer line repair services for help.
Grease Trap Services
May 03, 2015 | Maax Home
My kitchen sink refuses to drain at all.
You'll need a pro with a large cable snake and maybe a cutter head...
I hope it's not due to a garbage disposal. I try to warn people away from those things.
Mar 09, 2014 | Washing Machines
My Glacier Bay toilet is clogged. I tried plunging, the hot water and dishwasher detergent trick, the baking soda and vinegar trick and even attempted to manually unclog it with my hand. I don't e
The clog must be down in the pipe a ways. You will have to remove the toilet from the floor and use a plumber's snake. It is not as hard as it sounds to do this, but it can be intimidating. Look up how-to videos on you-tube. You will need a new wax ring (when you put the toilet back) and you can rent an electric snake from a tool rental place. They will show you how to operate it. You might be able to get away with a hand-snake, but only if the clog is easy and kind of close. The electric snake might be overkill, but it will work even if you have tree roots causing the clog. Good luck!
Sep 27, 2012 | Home
Toilet will fush but nothing goes down drain
plunge it first ,, if after this your still having the same problem, you may have to remove the toilet and check to see that nothing has gone into the J trap in the toilet itself, toothpaste caps,, and other objects will allow a snake or plunging to work,, but the problem still happens due to an object that will slide to the side and then go back one the snake has been removed
Jul 31, 2010 | Eljer Home
Garbage disponsal in one sink backs up into another, how can I clear the clog?
Remove the trap at the bottem of the sink and clean out the 40/50mm pyp.
Must be a blocked pyp, bt might wane get a plumber for that seing the 40/50 pyp cleaner is exspensive. or thy to plunge it with hothot water and drain cleaner, bt remeber to clouse all zinks ect befor plunging to make a vacume.
plz rate my advice
Jun 13, 2010 | Home
How do I unclog my kitchen sink drain?
easy go get a coat hanger and run it down the drain into the trap and try to pull up whater is clogging it or use a plunger.
Jun 03, 2010 | 2000 Ford Taurus
It grinds, but dirty water comes up into the sink
It is clogged and DO NOT USE ANY SOLVENTS DOWN THE DRAIN. NO kitchen sink should ever have any type of "draino" put in it as you was dishes/foods in it. There is definitely a clog. Unfortunately the trap plug doesnt usually work, do you have a PVC drain? Is there a "dandy" below the sink. It will also be PVC and have a larger nut on it, If so, unscrew it and snake the drain. GL
Nov 19, 2009 | KitchenAid KSU90S0MLL 16" Undermount...
Clogged Sink, Disposal On Takes Water Down, Off, Spurts Back Up
I agree it definitly is not your garbage disposal. You could try to use a liquid drain cleaner, but in my experience those do not work all that well, especially on the type of problem that you are having. If in fact you can not take apart your P-trap, (it shouldn't be a S trap), you should look for some type of a clean out cover under the sink or in the basement (if you have one). If there is another fixture down line, or for that matter up line, are you having problems there? It is possible that you have a clogged pipe under the sink. Unfortunatly if you can not disassemble, you (or a hired prof) will have to cut under the sink to find the problem. Hope this helps
Sep 30, 2009 | Buck In-Sink-Erator BADGER 5XP BADGERVEXP...
Water clogged in HDA3700 Water backs up into sink
check the p-trap under your kitchen sink, you may need to have it snaked-cleaned. other than that, where is it tie'd in. it may just be tie'd in too close or on the horisotil portion of your sink drain, when the vertical portion above the p-trap is recomended
Sep 18, 2009 | Dishwashers
Kohler K-3488-0 White Devonshire Devonshire One Piece Elongated Toilet with Logo
43 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
