Question about Hitachi 51F500 51" Rear Projection HDTV-Ready Television
Video problem Picture can be seen, but is distorted. Images are not in focus and look duplicated on screen. I have ran magic focus with no luck. Any help?
    President:
  • 4,402 Answers
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 14, 2008
Magic focus/convergence/blurred double images
Try to get an electricians help or contact a TV repair specialist.
Oct 26, 2013 | Hitachi 57G500 57" TV
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Goes through magic focus than in the middle stops and displays #5
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Feb 19, 2010 | Hitachi 46F500 46" Rear Projection...
60" hitachi 60SDX88B screen shows some green distortions in the top and bottom of the screen. Magic focus does not fix this. Help?
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Dec 21, 2009 | Hitachi 60SDX88B 60" Rear Projection...
COLOR DISTORTION AND SOME DOUBLE IMAGES ..HITACHI PROJECTION 52 INCH
You didn`t list the model number but i can recognise a convergence problem,If the magic focus or the convergence adjustement in the menu(that is the one with the crosses in the screen) does`nt do the trick then you probably have bad stk392-020 i.cs and a few resistor along with it.If your not handy in electronics you`ll need help from a repairman. good luck
Oct 30, 2009 | Televison & Video
Picture is out of focus. Tried Magic focus - didn't work. Saw color grid; appears blue is out of whack.
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
One half of picture is distorted
to create the total geometry in the tv is needed a system called Convergence.Convergence amplifiers are damaged in this unit, magic focus cannot work because magic focus works to level computer and controls the amplifiers damaged. this repair is for a technician because an adjustment is needed after the amplifier's replacement.
Oct 09, 2008 | Hitachi 61SBX59B 61" Rear Projection...
Hitachi Mo# 53uwx10ba double image
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 07, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Screen distortion
Is it a clean vertical line or a fuzzy vertical line? It could be as simple as a cleaning.
Apr 25, 2008 | Hitachi 53SDX89B 53" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 51F500 51" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
