Heaters
Problem for Heaters
Generic problem for all Heaters
Operating manual for MPI monitor heater
By sandyland on Jan 09, 2008
dont know how to program, looking for operating manual for MPI 441
Clarification Request
Posted by ldalton on Jan 17, 2009
monitor products inc must have removed the manual for the Model 441 from the site does anyone have this pdf or know a site to locate the manual
Posted by h2omike65 on Nov 01, 2008
I have a monitor MPI 441. It will try to start but the burner lights will flicker an it makes a "thumping" noise in the bottom of unit. Any suggestions?? Thanx, Mike
Same Problem
Mar 01, 2009
-   I need PDFoperating manual for MPI monitor 441 heater -   7nik
Jan 25, 2009
-   need parts manual for monitor heater 441 -   CHRISTINA523
Nov 20, 2008
-   I can't seem to set up programming on my heater. I need directions on how to do this. my heater is a MPI Monitor 441-   bkbessent
Oct 06, 2008
-   E 13 ERROR-   Guest
Jun 02, 2008
-   Deadband-   Guest
Best Solution
posted on Nov 11, 2008
Very Helpful)
modyinnh
Rank: Apprentice
Rating: 98%, 7 votes
Hi, whats the difference between a "Model 41" and a "Model "441" Monitor heater? Are the manuals interchangeable and its simply a generational thing?
Thanks
Paul
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Jan 10, 2008
Very Helpful)
Buffalo12980
Rank: Wiz
Rating: 84%, 1077 votes
I have a monitor 41 heater also. I downloaded a pdf file for the 441 if I can just remember the site!
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Feb 08, 2008
Very Helpful)
atwitcurious
Rank: Apprentice
Rating: 96%, 17 votes
You can obtain an electronic copy of the 441 owner's manual from http://www.monitorproducts.com/customer-support/manuals
Scroll towards the bottom of the page to find the 441 or 442 manuals.
Was this helpful?
Yes
No
5 people thought this was helpful
Solution #4
posted on Nov 08, 2008
Helpful)
jimmyj555
Rank: Apprentice
Rating: 93%, 3 votes
For helpful information about Monitor Heater repairs, see the blogs at www.jimmyj55.com
Was this helpful?
Yes
No
Solution #5
posted on Jan 19, 2009
Very Helpful)
Matt_321
Rank: Apprentice
Rating: 100%, 1 votes
Sandy,
I've got one in PDF. I forgot where I got it. Give me an email address and I will email it to you.
Matt
Was this helpful?
Yes
No
Solution #6
posted on Jan 18, 2009
Very Helpful)
dscartier
Rank: Apprentice
Rating: 100%, 3 votes
The thumping noise (more like a tick-tick-tick sound) in the bottom right hand corner is the pump starving for fuel. Shut off the monitor and tank fuel valve. change the fuel filter element on the tank,
shut off the fuel valve behind the monitor (there should always be one there), remove the fuel pump strainer cover (use a #2 phillips screwdriver and have lots of paper towels ready), and use a can of automotive carborator cleaner (outside!) to clean the strainer. Re-install, turn on the valves, check for fuel leaks and don't forget to check for fuel leaks (did I say to check for fuel leaks?). press the pump reset button on the lower, right hand side once to allow fuel into the pump. You may also have a blocked fuel line (ice or crud from moisture in the tank). If you're not up to the task, have your oil dealer come out and do it. Also, have the dealer add fuel treatment/de-icer to the tank and verify the tank gauge glass is in good shape. I am not responsible if you break the system, burn down your house or otherwise do damage to yourself, your home, barn, livestock or spill fuel.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #7
posted on Nov 24, 2009
Not Rated)
DANDE93069
Rank: Apprentice
Rating: 0%, 0 votes
NEED A BOOK FOR THE 441
Was this helpful?
Yes
No
Solution #8
posted on Oct 13, 2009
Not Rated)
barneyrose
Rank: Apprentice
Rating: 0%, 0 votes
i have a hard time resetting my monitor #500 heater on auto set
Was this helpful?
Yes
No
Solution #9
posted on Sep 13, 2009
Not Rated)
nanapat222
Rank: Apprentice
Rating: 0%, 0 votes
i have to set heat at 82 to get room temp.at 72 can this monitor 40 be calibrated
Was this helpful?
Yes
No
Solution #10
posted on Nov 18, 2008
Not Rated)
EveJB
Rank: Apprentice
Rating: 88%, 2 votes
I found the Monitor Error Message Codes on their website http://www.monitorproducts.com/pdf/troubleshooting/m.pdf
I also called their tech person at Toll Free: 800-524-1102. He called back and said E13 is usually about cleaning the screen (fuel filter). He told me to look at pages 22-23 and follow the instrux about cleaning the fuel strainer. He did say that if that doesn't work, call a repair person, but I'm going to call back if it isn't fixed.
Was this helpful?
Yes
No
Popular Solutions for Heaters
Questions and Unsolved Problems for Heaters
Answer
goodman furnases reliability
Answer
best heater for a 5,000 square foot monolithic dome
Answer
my hearthrite 17000 btu el-1 propane space heater continuously cycles between auto, manual and off... (More)
Answer
torpedo kerosene heater does not stay lit. i replaced teh ignitor and added ne kerosene. what could... (More)
8 Other Users Have The Same Problem - Continued
Comment by perez2208, posted on Mar 29, 2008
I have a mpi heater and i keep getting E 13 error message when i turn my heater on.
Comment by Guest, posted on Mar 06, 2008
Have tried to program unit, but need operating instructions.
Comment by Matt_321, posted on Jan 21, 2008
Same problem here. I tried to program the 441 without a manual, and it didn't work. You would think that you could download one from their website.
Describe your Heaters problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Heater Experts
Top Heater Repairmen
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
