Question about EA Sports MADDEN NFL 08
How do i change the nat 3 setting on my computer so i can chat online on the ps3
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 74 Answers
(ps3) How to change Nat type 3. I found a guide online it was to complicated.
Nat 3 means that your PS3 is having problems accessing the internet connection. The best way to resolve this is to not play online using wifi just connect your PS3 directly into your router via an Ethernet cable.If this doesn't work call your internet provider and they will be more than glad to fix your problem.
Mar 03, 2011 | Red Dead Redemption: Undead Nightmare -...
I cant play online becouse of this a NATtype3 what dose this mean
Nat 3 is the result of being hooked into a router without being properly setup for data transfer. essentially it is restrictive.
There are 3 ways to change your Nat type to type 2 or 1. (Nat type 2 meaning that it is properly setup without restrictions behind a router, and Nat 1 being a direct connection to the Internet).
1.) Hook the PS3mag-glass_10x10.gif directly into the modem will result in a Nat type 1, but of course that means disconnecting everything but the ps3 and that's an unnecessary hassle.
2.) Going into the router settings and Port Forwarding the PS3's necessary ports to the Ps3's ip address.
3.) Probably the simplest (on most routers) and most effective is to go into the router and set the PS3's ip address in the DMZ (DeMilitarized Zone), essentially the router doesnt have any say from what comes and goes to the Ps3, which is good so the connection isn't hampered.
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
My nat type elimnate me from chat or accepting game invites b/c my nat type is 3
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Feb 01, 2011 | Belkin Basic Wireless Router
How do you open nat type on the ps3 ?
Nat type is actually defined by your isp..(internet service provider) some companies do not actually support gaming and therefore their service is considered "strict" by ps3 standards for multiplayer gaming online. You may have to reconfigure your pc internet security settings on the computer itself...possibly logging into your router/modem. If this is not helpful or u are unsure of how to do this, contact your isp and explain to them you want the nat type changed...basically they will either not be able to at all and then u need a new isp or they can do it in a matter of minutes and ur nat type will change and give u full access to ps3 online within a matter of hours...hope it helps and u get back to gaming!
Dec 15, 2010 | Sony Playstation 3 (PS3) Console
I have a belkin F5D8236-4 v2 and wish to change nat type from 2 to 3 so that i can play cod online. as the playstation is set to nat 3 i am rather new at all this. i have tried all sorts of forums etc for...
Step 15:Enable UPnP
Open Router setup
Dec 11, 2010 | Belkin (F5D7230-4) Router (587009)
How do i change my nat type
go on a computer.
1. in the internet address bar type in 192.168.1.1 or routerlogin.net
2. enter admin and password in the fields
3. your now in your routers setup
4. find a setting called nat
5. set it to open instead of secure
this changes your nat type to 2
if that doesnt work
1. login to router as usual, but find a setting called default dmz server
2. enter the IP address of your PS3 as the dmz server (to see what your ps3's ip is go to network > connection settings and have a look.
this should definitley make it a nat 2 - but try the first method
Apr 27, 2010 | Sony Playstation 3 (PS3) Console
Cant to get a friend to join online playing Smackdown vs Raw 2008
There is usually two reasons for this.
The first one is the game is just having server problems.
The second one is usually the problem and that has to do with your router settings causing you to have a 'NAT Type 3' connection which can cause connection issues with other players.
Having a closed or limited NAT on your gaming console will cause a variety of issues. Similar to strict, moderate or open on an Xbox 360, the PS3 offers Type 3, Type 2 and Type 1 NAT results. These break down as follows:
Type 1 - Connected directly to the internet (no router/firewall). Should have no issues.Type 2 - Connected through a router properly. Should have no issues.Type 3 - Connected through a router without open ports or DMZ setup for PS3. Everything should function properly, but you may have connection, voice chat or other issues.While most everything will function properly regardless of what your NAT setting is, your best bet is to set up your PS3 so that you can obtain a Type 1 or Type 2 NAT. Since most of us have routers at home for connecting multiple computers or devices to the internet, chances are the best we will get will be Type 2. Thankfully that's fine and everything will work properly.
If you have not adjusted your settings on your PS3 or router, chances are you have a Type 3 NAT and probably never knew it. With a few simple changes you too can have a Type 2 NAT. Order now for just $19.99. But wait, there's more. joker.gif
The first thing you will want to do is check your network connection. Head on over to the Network Settings tab on the XMB. It looks like this:
Once there choose the Internet Connection Test item. It looks like this:
You will receive a warning letting you know that you will be signed out in order to perform the test. Choose okay. If you have not made any setting changes in your PS3 or Router, chances are you will receive the following message:
The warning reads: "When the NAT type is type 3, chat or the communication features of games may be restricted. For more information, refer to the online instruction manual."
If you run the test and have Type 2 or Type 1, stop fooling around and go play some games! If, however, you have Type 3, read on for help on opening up your NAT.
In order to open up your NAT on your PS3 you will need to make an adjustment on your PS3 and on your router. First you will want to set up your PS3 for a static IP address. This means turning off DHCP and assigning your PS3 a single, static IP address. Before you start this process head over to the network tab on the XMB and choose "Internet Connection Status." From here note your current IP address, your subnet mask, your default router and primary and secondary DNS settings. Write these down, you will need them in the following steps.
To do this, visit the Internet Connection Settings tab on the XMB. It looks like this:
From here most of the settings can simply be passed through with default settings. There are two areas, however, that you have to change. The first is choosing a Custom address setting (instead of Easy).
From here, you will want to choose Manual IP Address Setting:
Remember the settings you wrote down from your status page? You will need them here. You will have to enter in the static IP Address you want to assign to your PS3, the Subnet Mask (which is usually 255.255.255.0), the default router (the IP address of your router, most often 192.168.1.1 or 192.168.100.1), and the Primary and Secondary DNS settings. You will have to input all of these numbers. This is made much easier with a DVD Remote or keyboard.
Please NOTE - You will want to set the last number of your IP address high enough that other wireless or wired items on your network will not be assigned the same number through DHCP. While DHCP had chosen .3 as an IP address for my PS3 initially, I bumped it up to .23 because I have less than 23 items in my network. If you do not have DHCP enabled on your router, you do not need to worry about this and can simply choose an IP address that does not conflict with your other devices and which is available through your router.
Once you have all of the settings input, press X to save them. Your settings will change and the PS3 will offer to perform an Internet Connection Test for you. If you let it do the test now chances are you will still get a Type 3 NAT connection. Don't fret little bear, we still have one more step.
In addition to making the necessary changes on your PS3, you will also have to open up some ports on your router. The ports you need to open are:
TCP: 80, 443, 5223
UDP: 5223, 3478, 3479, 3658
I have a Linksys Router and my port forward settings page looks like this:
Depending on what type of router you have, your settings page may look different. In order to obtain an open or Type 2 NAT, you will need to open those ports listed above.
You can see in my screen capture that my PS3 is listed with its static IP address that I set above (.23) and that all of the necessary ports are forwarded to that IP address. The X listed items above (.24) are for my Xbox 360 so you don't have to worry about those.
Once you have forwarded these ports and saved your settings its a good idea to unplug and plug back in your router. This will refresh everything on your network connected to your router. Once done head back to your PS3 and perform an Internet Connection Test. If you did everything correctly you should receive the following page:
Congratulations, your NAT is now setup and working properly!
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
My ps3 HAS A dns problem
Whenever you are dealin with a DNS error, it is a problem on your internet service provider's end. Contact them for a solution. Thanks
Dec 31, 2008 | NetGear WGR614 Wireless Router
PS3 NAT type problem using Zyxel P-660R-D1 series DSL Modem
thanks for help , the error was from user that have viruse on his pc , thanks again
Nov 11, 2008 | Zyxel P660HW-D1 Router
Ps3 ali
maybe they have to many friends or they have been blocked from another person
Feb 21, 2008 | Sony Playstation 3 (PS3) Console
EA Sports MADDEN NFL 08 Logo
99 people viewed this question
Top EA Sports Video Game Consoles & Games Experts
James Wishart
Deepak Koshy
Deepak Koshy
Level 1 Expert
param99
Level 1 Expert
Are you an EA Sports Video Game Console and Game Expert? Answer questions, earn points and help others
