Question about Kirby Generation 3 Bagged Upright Vacuum
I broke the zipper on the cloth bag on my kirby gen. 3 can i replace this myself
  • 240 Answers
Most shoe repair shops can repair or replace the zipper. It is MUCH less expensive than buying a new bag.
Posted on Jun 28, 2011
  • 4 Answers
Yes.
To order Kirby vacuum bags, replacement parts, or cleaning products, please visit your local independent Kirby Distributor, or call:”
1-800-437-7170 United States and Canada
Posted on Nov 28, 2009
How to replace filler tube on Kirby G4 vacuum?
first take cloth bag off, held on at bottom with bag clamp, then wash cloth bag in washing machine at 40, inner hose is held on by 2 cable ties top and bottom, your new hose should come with 2 new cable ties, ask kirby agent when ordering, them simply refit.
Aug 25, 2014 | Kirby G4 Bagged Upright Vacuum
I need a manual for a kirby vac gen #3
click the link below for the manual It's a very large .pdf file, so just be patient while it loads;
http://kirby.110mb.com/docs/kirby_sentria_manual.pdf
Sep 03, 2012 | Kirby Generation 3 Bagged Upright Vacuum
How do i replace the on and off switch on a gen 3 kirby sweeper
fault will be cable not power switch, phone your local kirby enginere for fixing
Jul 31, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Kirby gen 3 wont go out of drive
cam neutral button worn, contact your local kirby agent for service or kirby.com
Apr 11, 2012 | Kirby Generation 3 Bagged Upright Vacuum
I have a Kirby Heritage 84. Great condition except the part that connects the innerbag is missing. I don't even know what it is called. I can open the vacuum cleaner bottom and see that the part is...
The Heritage 84 had two different bag assemblies available. One is a dump-out bag. The dirt simply dumps through the bottom. The other is the bagged style which has a full length zipper to open it. Inside it should contain a "bag fill tube", and a top adapter to attach the bag onto. The oval fill tube is no longer available, but a round tube can be installed with a bit of efort.
Dec 12, 2010 | Kirby Heritage II Vacuum
Plastic tube inside fabric bag broke cleanly at the base.
It can be fixed by yourself, if you are some-what handy. The part is called snap fill tube and the part number is 1900399 your local vac repair shop should be aware of this number part sell for about $9.00 to $14.00 hope that helps.
Oct 31, 2009 | Kirby Ultimate G Bagged Upright Vacuum
We have an older Kirby cloth-bag upright cleaner--inherited from family member. How do we empty the bag? The model # seems to be "Classic III"
Take the bag off (turn it counterclockwise a bit and it will slide off the exhaust). Take it somewhere outside and holding over garbage container open a latch on the bottom of the metal bag bottom part (miniemptor). Now entire bottom will open and dirt and dust will start falling out. If there is a zipper on the bag - open it and insert your hand into sort of a sock that will allow you to grab chunks of dust and push them towards the opening on the bottom without getting your hands too dirty.
Jan 26, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Im trying to replace the cloth bag on my Kirby G6. How do I release the belt that holds the cloth bag at the bottom of the assembly? It is grey and has teeth that grab when tightened on the bottom of the...
Kirby G6
Im trying to replace the cloth bag on my Kirby G6. How do I release the belt that holds the cloth bag at the bottom of the assembly? It is grey and has teeth that grab when tightened on the bottom of the unit.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There is a vinyl cover over the outside of the cloth bag and underneath the vinyl cover is a
ny tie that you have to cut off and replace with a new one and the cloth bag will slip off the bottom of the dirt cup @ the bottom of the cloth bag and remove the top cover and the bag should just come off, you can get the ny tie from any local vacuum cleaner dealer that does repairs or you can call the Kirby factory phone number listed below
http://kirby.com Contact Us
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
Apr 16, 2008 | Vacuums
Kirby
kirby style 2 bags if it is indeed a bagged unit, some where special order with what is called a shake out bag, if your outer bag has a short zipper with a cloth pocket it is a shake out bag in which you take the assembly loose from the machine and open the bottom of the metal empter and take out side and basically shake out the dirt. and use the pocket to help get out the dirt. but most of these machines did take a style 2 bag in which you unzip the outer bag and pull the paper bag away from the tube and reinsert new one onto tube and finally zip up bag
Mar 28, 2008 | Vacuums
Kirby Generation 3 Bagged Upright Vacuum Logo
416 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
