Question about Cycling
My son owns an Iron Horse Anzer Peak 24" mt. bike. It's a low end model. Problem: front brake arm loose within the shock? Is there a recall for this?
SOURCE: shaking/vibration in front end & steering wheel
Nor sure about the 2001 model, but on the 97 model, the track bar bolts to the frame on the driver's side. The bolts work loose. Dont merely look at it, go ahead and tighten them. There are two bolts facing upward, at the end lf the track bar. Then there are 3 nuts behind the driver's side front wheel that need to be tight. You dont have to take the wheel off so see them. I tightened all of mine and the death wobble nearly went away ....( 90%)....then I replaced the steering stabilizer ( damper). Hope your 2001 is just as easy !
Posted on Sep 25, 2008
  • 4 Answers
SOURCE: front end of truck makes a popping sound when hitting dips slow
make sure your new shocks(bolts) are cranked down tight. i left one slightly loose, and it knocked like the bad ball joint i already changed.
Posted on Jan 15, 2009
gisvc
  • 40 Answers
SOURCE: Front Shock Absorber Oil Capacity
hi,
i conacted a friend of min that works on honda bikes he stated the fork is identical to the 250cc class rebel in diamenter and will hold aproximatley 4 to 4.5ounces fork oil. hope this helps and good luck!
Posted on Mar 30, 2009
  • 269 Answers
SOURCE: 2003 dyna lowrider. at speeds above 70 mph bike
You may want to check the fork stem nut to see if it is tight enough.
Posted on Sep 09, 2009
  • 500 Answers
SOURCE: I OWN A E350 1999 12 PASSENGER VAN WITH 193000(HAS A SHIMMY)
have u had your shokes check
Posted on Sep 11, 2009
How to attach front forks?
Contact your local bike shop for assistance
Aug 13, 2014 | Iron Horse Bicycles Iron Horse 29" Mens...
How to replace front strut insert of toyota cressida model 91
Im not sure what car the instructions above are for, but it's not a Cressida. They dont have upper front control arms.
Anyways,
You remove the brake line, brake caliper, brake rotor. Then you remove the sway bar end link that attaches to the shock housing. Next remove the lower 2 shock bolts and the 3 upper mount bolts in the engine bay. Then you push down on the lower control arm so that you can remove the entire shock/spindle assembly.
Then take it to a shop to compress the spring to take it all apart.
Apr 04, 2012 | Toyota Cars & Trucks
How do i adjust the rear shock (rock shox bar)
This is a very basic Air Shock, the only way to "tune" more than adjust is by changing the air pressure, either by releasing some or adding some. To add you need a shock pump. you can get these at most bike shops that sell mountain bikes.
Mar 27, 2011 | Iron Horse Warrior Elite
My DISC pads are not lasting long.I'm using black ceramic pads. Please advice ............
Thats a good thing normally , it means the pads are doing there job properly and you are getting the braking power required , don't give up braking power for longevity!!
Dec 31, 2010 | Columbia Sportswear Columbia Anzer Peak...
My front disc brake is not working instantly... I need instant breaking performance.What shall I do? my rear disc is working properly but the front disc is slipping a little. please help
Slightly slipping disc brake:
First make sure the rotor and brake are clean and free of all oils. Any amount of oil will impede the brake working properly.
Solution #1 - Replace the front brake pads, when they are worn they will not stop as well. You can also replace with a compound that has more grip.
Solution #2 - Check rotor. If it is too smooth, you may need to take some rough grit sandpaper and make the rotor surface not shiny or smooth. You want the rotor to have a little roughness to it. If the surface is too tough to use sand paper on, then use a dremel with a sanding bit.
Solution #3 - not the most practical, but if the performance is not adequate for your needs, then you can replace the brake with a better quality brake that has greater stopping power.
Dec 10, 2010 | Columbia Sportswear Columbia Anzer Peak...
Do you think that MOTOBIKE mobils can be a perfect lubricant for MOUNTAINBIKE SUSPENSION FORKS??
You can use the same lubricants as long as they match the specifications for your Mountain bike fork. Each manufacture of fork will provide a list of recommended weights and types for the specific fork model.
In general the mountain bike will use a much lighter weight lubricant and the heat resisitance needs are far less. So in general the Motorbike suspension fluids will be too heavy.
The Fork that is pictured in the bike represented will not work well with Motorbike oils but if you have a different fork it might.
Dec 09, 2010 | Columbia Sportswear Columbia Anzer Peak...
I have a 26" Huffy men's mountain bike with shocks on the front forks. When ever I apply the front brakes the bike shakes badly and the front forks flex forward and backward rapidly. I couldn't see any...
Sounds like you have brake chatter. You need to "toe in" your pads on the front brake. Most new brake assemblies have a wedge shaped washer between the pad holder and where it mounts. If you loosen the nut that that holds the pad holder to the assembly and turn the washer you can see the relationship betwween the pad and the rim change. Turn the washer so the pad is toed in slightly(the end towards the front of the bike). If your brakes don't have the shaped washer you can put a crescent wrench on the brake arm and CAREFULLY tweak the toe in. Be gentle and good luck!
Oct 06, 2010 | Huffy Men Mountain Bike (26")
I need to know how to reattach my front shocks and handlebars to the frame of my iron horse warrior 3.3
Is the head set still attached the the frame? If so then it is simply a case of putting the fork into the headset, sit on the bike to force the fork into place then attach the spacers and stem. Use the head cap to tighten the stem but do not over tighten. It should be tight but able to turn freely.
Mar 01, 2010 | Iron Horse 2009 Warrior 4.0
1995 Nissan 240SX When braking hard i hear a clunk from the front end somewhere. Had them checked and was told there was no problem.I'm guessing thats because it has something to do with the suspension and...
brake calipers could be loose on suspension---lower track control arms---inner bushes lower track control arms---anti roll bar bushes----shock absorber broke inside----top shock absorber mounting loose--- jack it up and put a big bar on it and see what moves
Apr 02, 2009 | 2004 Suzuki Aerio
Cycling Logo
688 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
