When i restore also i could not open my drives
Twete
    Scholar:
  • 135 Answers
Could you please explain what your problem is so I can assist you better?
Posted on Jan 09, 2008
6ya staff
SOURCE:
How to restore Outlook .pst files from a back-up drive?
Use Outlook Backup Toolbox is an all-in-one tool for backing up your Microsoft Outlook data and restoring them when necessary.
For more: https://outlookbackup.recoverytoolbox.com/
Oct 29, 2015 | Microsoft Office Outlook 2007: Windows
I changed my local disk c name and now it cant open unless i run safe mode how can i fix this?
C is the root drive for your operating system so it is not advisable to change the drive letter of C drive. If you are still able to open your computer in Safe mood then I'll suggest you to change the Drive letter of C back to C in safe mood.
I hope you know how to change it back to normal position. If not then here the steps.
Open in safe mood
Right Click My computer-------Manage-------Disk Management------Right hand side at Bottom you'll see the Bar showing Size of the Partition in blue color ------Right Click the Drive C(which was C earlier)-------Change Drive Letter--------Change ------Here select C as your drive( remeber if you have Given C as a name to other drive then remove it before doing the above steps).
Hope this will work for you. If still you are facing problem then here is noe more way to restore drive back to normal position.
Start-----All Program----- Accessories------System tools-----System Restore----NEXT-----Check Show more restore Point(In Win 7)---now select the earlier date when your computer was fine and click next.
it'll restart your computer after restore is done.
Hope this will work for you. Good Luck
Aug 07, 2012 | HP Pavilion HDX161040US Intel Core2Duo...
Changed hard drive (Mac) How to restore data from SimpleTech
If you are asking how to restore a Time Machine backup, you will need to connect and turn on your drive, then open Time Machine, navigate to the drive, highlite the backup and click on the restore button. It should then restore the files from your backup.
Feb 24, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
How do I access the hidden partition to reinstall operating system?
Turn on or restart your notebook, then press F11 while your notebook is
starting.
3 Insert the Operating System Recovery CD/DVD when prompted. The System
Recovery program starts.
Click a system recovery option
Full System Restore (Destructive) reformats the hard drive and
restores the system software as it was when you purchased your
notebook. This process deletes your data files.
Full System Restore with Backup (recommended) moves the
contents of the hard drive to the C:\My Backup folder and installs
a new copy of Windows XP. This option saves your existing data
files, but all programs must be reinstalled and the program settings
reconfigured. You need at least 4 GB of hard drive space to use this
restore option.
5 Click Next. The System Restore - Format and Recover dialog box opens.
6 Click Yes. Files are restored to your hard drive. When file recovery has
finished, the System Restore dialog box opens.
7 Click Restart. Your notebook restarts, and Windows finishes its setup and
installation.
Important
After you restore your system, it will
appear with the same files and programs
it had when it shipped from the factory.
You still need to download Windows
updates and antivirus updates to bring
your notebook’s software up to date.
8 Reconnect your Internet cable and all USB peripheral devices. You are
done.
Apr 03, 2010 | Gateway MX6214 Notebook
When I click on "My Computer" there usually shows the drives I have which is the "c" drive and the "d" drive. Suddenly I the "c" drive is gone. Maybe my kids touched the computer and accidentally deleted...
Do a system restore. Go to control panel and open it. Once open, click on system maintenance(opens new window) and click on back up restore center (opens new window)and when that window opens, on the left side of the window will be an option to " Repair Windows using System Restore." Click on that. A window may open up asking to continue, click yes and do a system restore back to the date when the "C" drive was showing. Computer should do a restart afterwards.
Mar 29, 2010 | Toshiba Satellite A135-S4527 Notebook
I couldn't restore my mini hp. How to restore factory my mini hp? As i couldn't find ways to restore it from my mini hp. By the way, my mini laptop doesn't have any CD rom drive.
Roxio BackOn Track is a suite of backup and recovery tools which includes the following: · Disaster Recovery? · File Backup? · Instant Restore? Accessing Roxio BackOn Track There are two ways to access Roxio BackOn Track?through the boot menu or through the Windows Start menu. Use the boot menu option if you cannot access Windows. You can use the boot menu to restore your computer to a previous working state or to return the computer to the state it was in before the last time it was restored. You must be able to access Windows to use the other options, such as Disaster Recovery. To access Roxio BackOn Track using the boot menu, follow the steps below. 1. Press the power button to turn on the HP Mini. 2. Press and hold down the f6 key to open the Windows Boot Manager, use the down arrow key to select Roxio BackOnTrack , and then press the enter key to open Roxio BackOn Track.To access Roxio BackOn Track using the Windows Start menu, click Start , All Programs , Roxio , BackOnTrack , and then BackOnTrack Home to open Roxio BackOn Track.Backing up your hard drive using Disaster Recovery 1. In the left pane, click Disaster Recovery to expand the options, and then in the right pane, click Backup Drive . 2. Select the hard disk drive from the drop-down list in step 1, click inside the text box in step 2 and add any comments that you want to add, select a destination drive from the drop-down list under Destination Selection , and then click the large circle button at the bottom-right of the screen to continue. 3. Wait while Backup Drive creates an image of your hard drive. Restoring your hard drive Prior to restoring your hard drive, you must have created a disaster recovery set. To restore your hard drive using Disaster Recovery, follow the steps below. 1. Shut down and power off your HP Mini if it is not already powered off. 2. Connect an external USB optical drive to the HP Mini. 3. Connect the flash drive or external USB drive that you used to create your Disaster Recovery disc. 4. Power on your HP Mini, insert your Disaster Recovery disc into the external USB optical drive, and then restart your computer. 5. Follow the on-screen instructions to select a Disaster Recovery Set and the drive or drive partition you want to restore.For more information, please see the Help within the Roxio BackOn Track software.
Mar 20, 2010 | HP Computers & Internet
How do I use the external drive to restore data on my computer
open my computer
rt click on the external HDD icon ..
click open or explore ..
you will see all the files saved ...
press CTRL+A and copy all the files and paste them in the Folder where u want to restore it...
Mar 19, 2010 | Toshiba HDDR500E04XL 500 GB USB Hard Drive
Can't get restore dvd to work?
You need to boot to the bios/setup. Set the first boot device to be the optical drive. Open the drive and put the restore disk in. Exit the bios and save your changes. Restart the machine.
The computer should boot to the restore disk and all data will be erased from the hard drive.
Jan 19, 2010 | Insignia Computers & Internet
Can not open the bpa files on my external simpletech drive
did you use special software or windows backup?? try to use the same software to restore your files. In windows you need to restore your files to special folder, you give it a name. then you open the folder and there you have your files.
Make sure you log on as the same user who backed up the files, of course one who has the right to restore the files.
Mar 22, 2009 | Dell Computers & Internet
Wd problems
Change the drive letters, worked for me. I have 2 WD My Books, I made one R: and one S: worked fine after that. On vista go to Control Panel -> Classic View -> Admin Tools -> Computer Management -> Disk Management -> Right click on WD drive and change letter. For some reason G, F, E, ect seem to run into some problems
Dec 06, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Open Questions:
Computers & Internet Logo
16 people viewed this question
Ekse
Marvin
Marvin
