Question about LG LRSC26980 25.2 cu.ft. TV Refrigerator with FM Stereo: Titanium
Lg LRSC26980TT SIDE BY SIDE WITH 13 N LCD TV: WILL NOT TURN ON (IN STAND BY MODE) MANUAL STATES TO CHECK CONNECTOR AND SWITCH ON , THEN CHANGE THE BUTTON PCB. GREAT. HOW DO I DO THIS, AND WHERE CAN I GET A BUTTON PCB
chinna_1977
  • 65 Answers
SOURCE: LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Posted on Nov 17, 2008
SOURCE: I have a LG LDF6810ST dishwasher with a tE error
Follow up to previous post.I replaced my sum seal and other nec. gaskets and reassembled.The TE code is gone and dishwasher performs as designed.I hope this helps someone with one of these POS dishwashers.Thanks
Posted on May 29, 2009
  • 3 Answers
SOURCE: 42" LG 42LC7D LCD TV stuck in demo mode?
Did you have any luck? My LG is stuck in demo mode too. Menu button doesn't work, and keylock was on as default so I can't use the buttons on the TV itself.
Posted on Nov 30, 2009
  • 608 Answers
SOURCE: my lg lcd tv keeps flashing with the stand by
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired ofcourse) and found four bulged capacitors on the PSB. Many major electronics companiesPhilips/Magnavox, Sony, Panasonic, and others were sold capacitors that failedin 2-5 years instead of 10-20. Thecapacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in allsorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional $$$$$$$??????? (Is itunder warranty?) Remember, TVs CONTAINHIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk. 2. Open your TV and find PSB. (The board that the power cordplugs into) Check for faulty caps. If you find some (bulged or leaking) bad capsreplace the entire board. The entireboard costs around $250 right now because they are in high demand right now.They can be found at tv-part.com but supplies are limited. I would definitely shop around though. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourselfit will save you hundreds. This may be your problem. If you determine that it might be. I have a Tip/How TO tutorialon this site that may also help. Itgives step by step instructions for replacing caps on PSB #715t2432-2. If this isyour board you are in luck. Here is theLink: Fixingthe Philips Turns/shuts off on its own problem. I'm working on uploading pictures to helpguide people though the process as well. Let me know if I can do anything to help. Hope this helps and if it does please rate itaccordingly. Good luck.Kaufman605
Posted on Dec 16, 2010
Testimonial: "Thanks your help has been very much appreciated..."
SOURCE: how to reset lg lcd tv
Can't get t v on
Posted on Jan 12, 2013
Tv is in stand-by mode green ligth flashes
hit the source button to change to TV mode or PC mode
Oct 28, 2013 | LG 32LG30 32 in. LCD HDTV
What should i do is my LG 42LC2RR's stand by light keeps blinking but it does turn on
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | LG 42LC2RR 42 in. HD-Ready LCD TV
How do you take the base off the bottom to hang the TV?
On the back of the tv located at the very bottom where the stand meets the base of tv there are from 4 to 6 screws that hold it in place. I am including a link to the tv's manual. The instructions for the base are located on p.13. If this helps please rate me. I do not get paid but like to help.
http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-42LG30.jsp
Dec 18, 2010 | LG 42LG30 42 in. LCD HDTV
I am trying to remove the tv stand base off my 42lg30. Can someone please help!
DETACHMENT
Carefully place the TV screen side down on a
cushioned surface to protect the screen from
damage.
Loose the bolts from TV.
you can view a larger image by clicking on this link then selecting the Manual on the right hand side
the information you will need is on page 13 of the manual
Detach the stand from TV.
After removing the stand, install the included
protection cover over the hole for the stand.
Press the PROTECTION COVER into the TV
until you hear it click.
Dec 03, 2010 | LG 42LG30 42 in. LCD HDTV
Hi, i just purchased two LG LCD TV's the 26LD350 and the 32LD350 I'm worried that it does not have an off switch and only goes on to standby mode. you here alot about tv"s catching on fire because of this....
I have never heard of any LG TVs having a fire issue.
LG added this switch to help save electricity. "Going Green".
You see, this On/Off switch was added to kill the power to the TV when not in use. This switch stops the TV from consuming power by not giving it power to be in a “Stand-By” mode.
If your TV does not have this switch, you could simply unplug your TV to give you the added satisfaction it won’t catch fire.
I hope this information has helped.
Good Luck.
May 23, 2010 | LG Televison & Video
37'' LG lcd tv, no power
I just want to clear things here.
The stand by light will remain on whenever the tv set is turned on by a button on the side of the tv.
Then use your remote to turn on the tv, but wait as it can take 10secs before you get a picture.
Nov 04, 2009 | LG 37LC7D 37 in. LCD HDTV
I can't turn off the tv it only goes into stand-by mode (both button on remote and on the tv)is there something i'm missing or do you have to turn it off at the wall?
There are no dedicated on/off switches on these TV's as in the older style televisions. It will remain will the stand-by condition unless it is physically turned off at the wall socket. This is becoming a standard set up on a lot of LCD televisions.
Apr 26, 2009 | LG 42LG30 42 in. LCD HDTV
LG 37
You can read the owners manual and do a channel scan to memory.
If you mean that just the first 13 channels are all you get, then you have to change from AIR to Cable or STD mode (again, read manual).
Sep 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Sound Problem
ok paola! the problem is the headphone connector inside the TV.. maybe did not turn back the switch to speaker mode. check the headphone connector (at inside the tv). small problem goodluck paola!!!
Sep 14, 2007 | Samsung LN-S4051D 40 in. LCD Television
Refrigerators Logo
117 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
